* T6 @. ~! |* x% ^( o
' f. {9 Z& j* S; h: ^! L1 V一、STM32启动文件详细解析" p) |! D# E2 J0 u
1 \- F! |& a. w( jSTM32启动文件详细解析(V3.5.0) 以:startup_stm32f10x_hd.s为例: E( Z) `: H" a; k% y+ `/ u2 N
) I* E- g5 f) r) O! p3 R0 @;********************(C)COPYRIGHT2011STMicroelectronics********************& r/ k' A3 R0 [; r4 K; N
% Y4 ?* ~, w' I$ h7 l
;*FileName:startup_stm32f10x_hd.s
& f2 X" T3 j: ]5 A7 A0 r) k+ T* Y3 y, c4 l; c1 _ t4 Z$ J& z
;*Author:MCDApplicationTeam
+ e% T5 A6 `4 V- ~9 p% H+ N! f* W2 P$ Z
;*Version:V3.5.0
& j7 _. i+ L3 Q6 z& M4 h% C6 n. l; Y$ I; n e$ h( ^( e
;*Date:11-March-2011, r2 C$ T8 T4 N$ O5 T' \- \
6 _9 t1 x+ R0 f. V% a4 M$ u/ [;*Description:STM32F10xHighDensityDevicesvectortableforMDK-ARM
! f3 z' t, ^* ~ l' X# T/ i. |* g, l D% x* x( W# F
;*toolchain.
5 N, x8 Q6 h% A) V/ t: x- s
* l/ |, Q6 V3 U0 y. q) X1 v) X. T;*ThismodulepeRForms:
+ y% S. w) r& Z: J& e) Y
/ b+ I5 Q" c; u/ p;*-SettheinitialSP( M- j3 `) I) }0 ?5 f$ x2 E) v; x
9 u; t9 O" W8 j6 d$ c" |) v2 J
;*-SettheinitialPC==Reset_Handler
$ T- V0 C) ^2 Q2 M: e+ l! I$ `, x% l+ \% y6 g" _" C- Z
;*-SetthevectortableentrieswiththeexceptionsISRaddress
# Q: B; T0 g1 D& D% f! z# h9 D) x$ L$ ^! a
;*-Configuretheclocksystemandalsoconfiguretheexternal
]+ _5 k8 C8 Y/ G4 I
@% r: ?5 v* j; i1 b. i0 H;*SRAMmountedonSTM3210E-EVALboardtobeusedasdata
. q F+ Y1 V# u$ H* ]& m$ Z2 X
, b7 \" p; F( K;*memory(optional,tobeenabledbyuser)
. q$ }: o4 F% }- y' ~- O0 y; y& r6 u- @
;*-Branchesto__mainintheClibrary(whicheventually) |3 ~. O L- k1 Y; f
! i t7 A; o2 z8 c
;*callsmain())。
% t, U8 t, v' r
: ]. a# r0 [( I3 @% K [4 \ e;*AfterResettheCortexM3processorisinThreadmode,* ^2 B- Y. ?: m* B8 N0 t
- a9 i( l( r: L
;*priorityisPrivileged,andtheStackissettoMain.
9 v* A+ q7 m' \6 w% C* X
* Q6 {! c, Z: R, v8 e( }
- O( ~" h+ B! X& w, l$ `1 i8 U
+ S0 s% I! C7 a6 P+ N;*《《》》+ n1 C5 d3 ~2 P0 h J5 o6 R
& J2 s% `" t& `8 s7 F' f;*******************************************************************************
7 a- I3 \4 P& W8 o; i8 s5 h: [+ @# d* \: s' L4 ~" |
;THEPRESENTFIRMWAREWHICHISFORGUIDANCEONLYAIMSATPROVIDINGCUSTOMERS0 H3 H$ J, h$ `2 g% F7 M
$ J; g$ M! D5 s) [, n* X: L;WITHCODINGINFORMATIONREGARDINGTHEIRPRODUCTSINORDERFORTHEMTOSAVETIME.
6 P3 r. z1 J# d2 @! W. q8 b) j |& y8 ]2 v
! S* T; U5 z3 m7 _/ C2 G;ASARESULT,STMICROELECTRONICSSHALLNOTBEHELDLIABLEFORANYDIRECT,
9 n- z- U J, y* e C$ x1 Z
x, \' [. @4 R3 Q/ g3 t& m;INDIRECTORCONSEQUENTIALDAMAGESWITHRESPECTTOANYCLAIMSARISINGFROMTHE
5 l+ |+ M% c9 k- H7 l/ _ R( l
/ g. w& ?$ }# f# w" P;CONTENTOFSUCHFIRMWAREAND/ORTHEUSEMADEBYCUSTOMERSOFTHECODING& t U5 O, L" S3 q7 R
& i2 f9 s3 i" B% ~3 e1 E+ C0 z3 F" K
;INFORMATIONCONTAINEDHEREININCONNECTIONWITHTHEIRPRODUCTS.
- G" c1 n; _* E8 Z+ L, [* b# _6 D
_3 H3 ~1 ~2 e5 j; f1 |& x;*******************************************************************************0 \# K6 q: @8 X; R) @, A1 ? d
: n& W3 b% Y$ ^$ @7 u' i;Amountofmemory(inbytes)allocatedforStack
3 s0 J# @ q0 s% U% N' `1 b" u" y+ N. f0 R* g% O1 I! T
;Tailorthisvaluetoyourapplicationneeds
7 O1 A5 a% G! M1 F
" j* @. s* l& p; Y b1 z3 t. M;StackConfiguration;栈定义& Z: C! |4 y' [8 P0 O l# D
# a0 Y( L( R" {# Q5 X5 s% w5 w;StackSize(inBytes)《0x0-0xFFFFFFFF:8》$ z H9 V) b; |0 O4 E) c
6 W, U) `& t' w$ L- K) d& P+ l;
P( n! U! D( t! H% f0 A( A: R( ]
; S3 t4 m: L- f' Z- tStack_SizeEQU0x00000400;EQU伪指令,作用是左边的符号名代表右边的表达式
2 Q0 J3 w+ M; ^2 i' f
8 s( s0 u" W0 o9 O; i0 xAREASTACK,NOINIT,READWRITE,ALIGN=3;定义栈段:名称为STACK,未初始化,可读写,ELF的栈段按2^3=8对齐
2 E: w/ n2 G6 J9 A! n/ K* m( ?3 | s4 p" Y* f& I% \# b( F
Stack_MemSPACEStack_Size;分配一片连续的存储区域并初始化为0,栈空间:0x400个字节
$ w7 s2 v* ], y: r
- v D1 g7 g/ Q- E0 s9 U__initial_sp;栈空间顶地址
. @' I' D& [" ] s# U9 H
: w: J' p2 y3 };HeapConfiguration;堆定义
! H. U( K( \: Y" ~" R7 X3 K
$ O1 O }, c- Y0 c6 e$ D+ ? q;HeapSize(inBytes)《0x0-0xFFFFFFFF:8》
. o9 m* {2 T9 s; M7 g
. v% V- |$ M5 h2 _& @$ K;
1 J" ]% @% u3 s
+ k+ {) h3 ?0 l/ VHeap_SizeEQU0x00000200
5 f' E1 |" x& I, j
; [. S) u/ f/ ?- lAREAHEAP,NOINIT,READWRITE,ALIGN=3* R/ B3 N" I$ z$ ?9 @
8 H _( f6 k7 t- |__heap_base;堆空间起始地址
4 s9 b2 V8 G. A" ~: i& Y# j$ g1 r; Z- [. g% @' `& H% P1 x. c
Heap_MemSPACEHeap_Size;堆空间:0x200个字节5 z+ Q3 ~' }5 [- f7 i" s
, ^5 e5 \1 X2 S8 v% f' x__heap_limit;堆空间结束地址& N" \: i: s! s6 a! s, O
6 y2 `4 |( @/ ^( M5 z3 G" o
PRESERVE8 RESERVE8指令指定当前文件保持堆栈八字节对齐
' @9 o# u2 L- {, g9 |, x/ z6 n/ [, B% x0 u( O! C; x) O7 R- J3 G- N, P
THUMB;告诉汇编器下面是32位的Thumb指令,如果需要汇编器将插入位以保证对齐0 _% M2 C* R9 U/ q3 q9 a, O4 y
1 v5 `7 R7 S) R% w;VectorTableMappedtoAddress0atReset;中断向量表定义
4 J4 i; x% Q" p3 U4 f) {
1 o6 p1 f8 l$ `7 W$ _) W; H; X;实际上是在CODE区(假设STM32从FLASH启动,则此中断向量表起始地址即为0x8000000)
8 a) G& V/ k. {3 C
3 e* x: ]+ W6 V) e* sAREARESET,DATA,READONLY;定义一块数据段,只可读,段名字是RESET
- i0 {! i, v" y6 ~: K8 X. g3 v
, ^* K9 R+ p4 Q9 l+ R6 }EXPORT__Vectors;EXPORT:在程序中声明一个全局的标号__Vectors,该标号可在其他的文件中引用
' J5 X: g2 B4 c
5 w: C" F7 K- A$ V/ c# m& n |
