查看: 138|回复: 0
ZCC3325替代REF33XX
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
     楼主| 发表于 2024-11-22 17:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    Features
    1 T9 R, ]3 _! m3 W( t. XLow Quiescent Current : 10uA Wide Input Voltage Range : 2.6V to 6.5V Extremely Low Dropout Voltage : 85mV (typ) High Output Current : ±5mA Low Temperature Drift:30ppm/°C(max) Fixed Output Voltages : 2.5V High Initial Accuracy : ±0.15%(max) Available Packages:SOT23-3- O& d" O% o7 E/ k! z( ^
    Description
    , i  d+ d% a' [4 o" `The ZCC3325 is a low-power,precision,low-dropoutVoltage reference family available in SOT23-3packages8 [: _" u, f$ w5 W  @' }1 d% U
    Applications
    # c' m7 J1 `) l5 Q7 YData Acquisition Systems Medical Equipment Test Equipment Hard Disk Drives Sensor Modules Tablets and Smartphones" f' Q# ?8 {" G! ]3 `- n+ |
    GMT+8, 2025-11-5 08:44 , Processed in 0.140625 second(s), 25 queries , Gzip On.
