查看: 2759|回复: 5
[Cadence Sigrity] IBIS在Mode Integrity中出现了如下错误
发表于 2012-7-21 11:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
WARNING (line  433) - Pulldown Maximum data is non-monotonic
( M$ x7 S/ R' w' JWARNING (line  434) - Pulldown Typical data is non-monotonic
; u0 J. S0 T+ Y8 E! Q" T9 VWARNING (line  435) - Pulldown Minimum data is non-monotonic$ Q3 a2 B* G7 L# s) j. [
WARNING (line  609) - Pullup Maximum data is non-monotonic
. M3 Y. ^' \9 ^$ PWARNING (line  610) - Pullup Typical data is non-monotonic2 ?. o) C# S2 ], N0 N
WARNING (line  610) - Pullup Minimum data is non-monotonic2 B6 i% A) S* e. M" v
WARNING (line 1028) - Pulldown Maximum data is non-monotonic0 y  F1 b3 ]; L( F$ w
WARNING (line 1029) - Pulldown Typical data is non-monotonic' C) v. g7 B% M5 B" l* E* H
WARNING (line 1030) - Pulldown Minimum data is non-monotonic
% v) I7 f- A+ ^) S3 S% F' F1 fWARNING (line 1535) - Pulldown Maximum data is non-monotonic
. S) H6 X- P3 P, K& FWARNING (line 1536) - Pulldown Typical data is non-monotonic- }/ \6 M/ H" t" N. ^
WARNING (line 1537) - Pulldown Minimum data is non-monotonic
3 @4 j+ O* I; @' qWARNING (line 1717) - GND Clamp Minimum data is non-monotonic
9 S; k1 p* C* x1 F6 g( YWARNING (line 1890) - POWER Clamp Minimum data is non-monotonic
0 c, v2 y9 P3 d/ v) lWARNING - Model 'DBX_B06060B0S2AKZGBE': Vmeas timing test load parameter should be specified" q- R( N4 z  ?, C
WARNING (line 1944) - Pulldown Maximum data is non-monotonic
( v! O. J) K& s# jWARNING (line 1945) - Pulldown Typical data is non-monotonic
/ I  e5 d8 L: b2 KWARNING (line 1946) - Pulldown Minimum data is non-monotonic1 J  m. d7 F, w0 T+ S' `- K: r
WARNING (line 2153) - Pullup Maximum data is non-monotonic
3 L- t+ G: @5 EWARNING (line 2154) - Pullup Typical data is non-monotonic  c$ y2 {4 P" o
WARNING (line 2154) - Pullup Minimum data is non-monotonic4 H; O: U0 ^, {% y, @# m) W
WARNING - Model 'DBX_B08081B0S2ALZGIE': Vmeas timing test load parameter should be specified& o; o. Z) V) @9 \- T' u
WARNING - [Model] DBX_D00200B0S2AZZGHE has no description of the buffer's high state
+ V" J1 o+ M6 f& T         DC drive characteristics (no [Pullup] table).  This warning
6 L0 J  I1 h9 L( c1 @, Q7 I1 A         can be silenced by using an open drain Model_type or by
% X1 t/ y2 W4 H. u( x1 s         adding a [Pullup] table.
: D5 P% ]* g0 U' G2 T# u; m- Y% a# s7 ~
谁能帮忙解决一下,谢了。。。
发表于 2012-7-24 22:10 | 只看该作者
這個不用理會
发表于 2012-7-28 11:08 | 只看该作者
无法修改。呵呵。。{:soso_e100:}
发表于 2012-8-5 22:58 | 只看该作者
警告可以不管,把错误处理完就可以了。
 楼主| 发表于 2012-8-11 16:25 | 只看该作者
yoyof3 发表于 2012-8-5 22:58
/ \+ F" q7 ^$ F  \/ O" O警告可以不管,把错误处理完就可以了。
0 J' h$ I$ \8 l" e
谢谢{:soso_e100:}
GMT+8, 2025-8-2 13:04 , Processed in 0.125000 second(s), 23 queries , Gzip On.
