TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
GENERAL DESCRIPTION* ~$ R% M1 U I" k% [
The ZCC3302 is a 7.5V step-up DC/DC converter
$ D0 ]. s: s- a* H2 x+ x: ddesigned for driving up to single 10-series or5 N [' p. }% ^( B( G' o
9x3-series WLEDs from a single cell Lithium Ion-
G+ }$ D; U4 x; r+ g' u3 Zbattery.. M* X- V* J8 X7 }% q
The ZCC3302 uses current mode, fixed frequency: K' W3 u) s. m5 P5 z/ n9 ]
architecture to regulate the LED current, which is" T" [# p- B3 w7 I( O
measured through an external current sense resistor.; Q1 ?/ H, {+ Q4 r' y2 q
Its low 300mV feedback voltage reduces power loss
* t/ C& H$ R2 `4 C. Xand improves efficiency. The ZCC3302 supports hig-) g6 M4 x. {3 q' }5 G0 ~' ~
h frequency PWM Dimming through EN pin.
2 r0 v% `1 m" F. w0 t( ?5 |The ZCC3302 is turned off if an open-circuit condition7 X' G2 D% C. P i) ]
is presented. Please be noted that open-circuit% A3 |. m9 H4 a( c: S
condition is not the same as over-voltage condition..
7 R+ U; c" M6 K+ o5 Y' mPlease refer to the OPERATION DESCRIPTION and
7 L) S, \2 u" A' iAPPLICATION INFORMATION sections for more
4 ~, K- P3 @* V/ R7 \2 u) r. Gdetail.
, w+ ]' D% I4 T: t' ]3 t* \" x3 TThe ZCC3302 includes soft-start, under-voltage locko-
9 {6 t0 X% S+ Y' V. x$ o; k6 nut, current limiting and thermal overload protections.
2 G. ^& }1 E5 p# g$ MThe ZCC3302 is available in SOT23-6 package.
$ U9 H0 x/ X! HFEATURES% ?' P8 L" ^7 q) r
Operating Voltage: 2.5-7.5V6 l4 v2 y+ o, ^. _2 U
Maximum Output Voltage: 35V, capable of2 S' a; I0 z* k+ B% Y# t
driving 10-series White LED strings3 `/ U7 W( v1 |' H8 M4 s( M% M6 m
Maximum drive Capability: 9x3-series or; ~3 _; d2 j' f% l4 h5 n/ i# l& X2 |
6x6-series.# V" X" h; l( C; f/ O
Up to 90% Efficiency6 ?2 D- h; G& ?$ O2 x# Y% j. U
1.25MHz Fixed Switching Frequency
4 F% E4 j7 O6 ?, y3 N3 W Low 300mV Feedback Voltage* L( W4 @+ m2 S4 `" e& x' _8 j# T4 g
Support PWM Dimming
4 B- Z; T: |' o1 d' a* L Open-circuit Protection( l/ r( w. I9 M- q+ Y- k
UVLO, Soft-Start and Thermal Shutdown
: ?2 h5 y7 G( a1 U. t5 }5 T Internal 1.5A Current Limit
. @5 d! p$ J) T- S+ A SOT23-6 Package8 R8 |% E& _( x+ w: B% x3 D, z8 F
APPLICATIONS' l8 `! w* G. |4 C
5~7” LCD Panels
- D9 p; @5 z/ Y9 e Handheld Computers and PDAs$ G; N6 L& q, w
Digital Cameras
2 ~4 S- ~" V% H# {0 N: | Small LCD Displays
. Z7 F# w) H+ m; r' I* H: r! G |
