TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
Features
# O9 }2 e1 h ^; Z" Z0 @; a 9V to 100V input voltage range3 c+ g& g2 `/ m t0 C" p
1.5A/5A continuous output current
2 n# M: `, M8 ]0 q2 D 95% Peak Efficiency9 s$ |: Y' R4 w3 b+ E
400μA operating quiescent current0 ^- Z. T& _& s0 P7 I( ^9 V5 t
100V 400-mΩ high-side MOSFET# ~8 i* f! q; }7 U2 q
Peak Current mode control
: d6 R9 f* |; ]" H 150 kHz Fixed Frequency: q( m) ]- {0 \
Internal compensation for ease of use
+ j6 d- V# R6 a8 A/ g, A Up to 92% duty cycle' o; i* w" X7 N9 F8 d' [6 l
0.8V voltage reference2 t3 k' ?) @. e+ H7 {' O
1μA shutdown current7 n6 c8 h% t, K! j
3A/6A cycle-by-cycle current limit
# {; v# a' |9 N 150ms Hiccup mode short circuit protection
2 Z9 ~0 x' ^2 m1 K$ bFunction
& q( P7 e6 O+ `9 C* l Thermal shutdown Function H( b+ D" d- S: F6 a' N! k6 n
ESOP-8 package- N; J/ O& }: w9 {
Applications
; z( |* \( k8 Q; k$ J$ ~ Charger in vehicle
0 \! h4 I! q5 ~! Z5 i) q Battery Chargers
' Z# n9 X: g: ~9 G' O# o: ? Power adapter
" |4 N+ S+ x' sTypical Application3 k, b+ G2 {$ l, r
Description3 V( _* X: R1 C% t8 _( L
The ZCC1005 is a high voltage, non-synchronous. [9 w& j) C+ l
step-down converter operates over a wide range
- J" V) g* `4 ^2 m/ Rinput voltage7 p, ?5 m+ K( M( N! ]2 b3 X
9V to 100V. The ZCC1005
6 Y1 m1 O; F& ointegrates a 100-V 400-mΩ high-side MOSFET.
4 P: w: r7 W% oThe ZCC1005 delivers 1.5A continuous load( j8 z) D6 L$ E" C
current with up to 95% efficiency. The ZCC1005& O# X, K/ ]5 t8 g L5 [
operates with fixed frequency peak current control
( t1 m3 X+ ^. z) ewith built-in compensation eliminates the need for' T( u6 |) m8 s/ v r% G3 I
external components.9 d a9 \, T# B
Cycle-by-cycle current limit in high-side MOSFET
) A, u. h( ]' @protects the converter in an overload condition.* v+ q$ D3 y+ ]; q% G8 e
Hiccup mode protection is triggered if the
! Z# c" X5 W1 q0 u( J; l vover-current condition has persisted for longer than
3 p7 q C4 s$ \' Fthe present time.
) T5 b! f: Z8 l; F% h3 hThe ZCC1005 exhibits protection features that3 e$ J* m& W0 c4 W P
protect the load from faults like under-voltage,8 e: ^7 g4 v8 w1 X8 X
over-current and over-temperature.
+ q' L. _: f' T5 _5 P K' lThe ZCC1005 is available in an ESOP-8 package./ q+ m: R& _4 s5 t
