查看: 6153|回复: 1
[HyperLynx] hyperlynx调Hspice时 出错
发表于 2012-5-4 21:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
帮我看个错位嘛
( E/ y& h; ?; C" ~* W1 _  **error** (E:\mentorGraphics\MyProject\hyper\PET3P_Run.sp:43) Definition of model/subckt "pet3p" is not found for the element "x1". Please specify a defined model/subckt name.
& u4 L% _$ t+ w& c& D, [: V2 _# H9 }" ~3 W
          ***** job aborted2 r4 o% v  F. P# U: A; T( t5 j: [
这是在hyperlynx调Hspice时出的
 楼主| 发表于 2012-5-4 23:23 | 只看该作者
**info** (E:\MentorGraphics\MyProject\hyper\PET3P_Run.sp:40) DC voltage reset to initial transient source value              in source        0:vinp                new dc=  0.0000D+00: h! B) y; A( a
**warning** invalid circuit pathname xrx_top.xrx.xrx_core.xdlb! x9 Z% H' k% m, m( I
0 E3 K8 ^6 U- \  N) |9 o
**error**  invalid node pathname in element ctot0
4 r3 \: y7 q  I$ ^* r5 Q2 i- |: w
9 p* y$ X+ @5 R& R. r/ p6 N6 E2 w4 H2 [( X
**warning**  associated with encrypted block(s) were suppressed due to encrypted content
# [0 D2 c: A7 D6 c2 N3 {3 i2 R. B' S" `$ S; q! z8 l+ k
/ I6 k- x2 l# ]* j% u5 M
# j( T! |) h+ i **error**  invalid node pathname in element ctot1
# C. p( |7 \4 C; V% J. |1 i
5 B! t! v, y5 \& Z) N5 d **warning** invalid circuit pathname xrx_top.xrx.xrx_core.xdlb- L" S+ L: F9 `& b/ c- q
: l* _& K: M+ a: m/ {+ f, J+ ~: X **error**  invalid node pathname in element ctot2
6 a# A* L, t2 q! i# i' X( L( L
+ E: h" q3 K) X2 T **warning** invalid circuit pathname xrx_top.xrx.xrx_core.xdlb6 M* \* F) r  a0 w& g* ?9 }
5 t! k, I/ r; f( U/ j
**error**  invalid node pathname in element ctot3           ! R0 E0 x6 J6 g9 o; y7 I# r8 }
7 g* W0 Z  Z$ {' ?( }& L **warning** invalid circuit pathname xrx_top.xrx.xrx_core.xdlb
" @9 b7 m- `9 W* d
1 L: r1 W- ?4 A **error**  invalid node pathname in element ctot4
# V2 I; K- r6 K2 h
; q4 c5 Q! Z9 w2 Y( \ **warning** invalid circuit pathname xrx_top.xrx.xrx_core.xdlb
# L" \  e$ q- M8 s% r
; v% v0 z7 v6 | **error**  invalid node pathname in element ctot5
GMT+8, 2025-7-31 12:28 , Processed in 0.109375 second(s), 25 queries , Gzip On.
