TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
GENERAL DESCRIPTION D6 |( V# P- R0 p: n- q. e
The ZCC3302 is a 7.5V step-up DC/DC converter
- j' h! `7 h z2 m& Udesigned for driving up to single 10-series or/ W# A. V. I& M8 c4 D2 P9 w
9x3-series WLEDs from a single cell Lithium Ion-7 X! ?# r, T. R. o- P
battery. j; ?) W/ ?# g4 w& E: S2 e9 E
The ZCC3302 uses current mode, fixed frequency0 t% M" q, H! h# J& q; ]+ {0 J! n
architecture to regulate the LED current, which is
4 L" N8 w4 S" ]4 v( g; V: nmeasured through an external current sense resistor.4 R6 }' d+ Q$ i
Its low 300mV feedback voltage reduces power loss1 h! Z1 N3 @" J0 J! g" h' S' Z$ C2 }
and improves efficiency. The ZCC3302 supports hig-
/ {1 n# M3 I4 C5 k& s5 W8 ?% |h frequency PWM Dimming through EN pin.
4 U9 b2 ? J" j( \The ZCC3302 is turned off if an open-circuit condition
+ l- e- O4 O; Q& O' v$ @is presented. Please be noted that open-circuit( W6 k. h! Y3 l' E! p9 {9 G, o
condition is not the same as over-voltage condition..
; U p6 z5 u; A# G: Q6 uPlease refer to the OPERATION DESCRIPTION and
: j% F! P0 H7 }; N MAPPLICATION INFORMATION sections for more1 Z1 z1 L+ Q$ H/ N/ P
detail.
$ L7 S+ Y" b3 p; h8 N( KThe ZCC3302 includes soft-start, under-voltage locko-" ]$ D6 z5 g2 j' Y; [1 w
ut, current limiting and thermal overload protections.- h2 ~0 d8 }& [$ X' h6 E
The ZCC3302 is available in SOT23-6 package.
1 r1 r% v5 E- V1 ?/ W2 BFEATURES2 S8 Q3 h% j8 i7 n
Operating Voltage: 2.5-7.5V7 C; X% D2 z2 a& K. y% M6 W- @
Maximum Output Voltage: 35V, capable of8 r x/ M+ O3 h, W# Q1 S" T! E
driving 10-series White LED strings
' M/ l) {, P8 G/ v+ u' H; F Maximum drive Capability: 9x3-series or
3 {3 c5 w& }* }4 B6x6-series.( D4 j4 L; N2 s5 {2 U* {6 T% _* T; p: S
Up to 90% Efficiency/ G1 _! G: C6 E* l6 G3 z0 m
1.25MHz Fixed Switching Frequency; c+ u8 \0 ]- o5 ?
Low 300mV Feedback Voltage
" }+ C0 u4 E; g) W3 E# D Support PWM Dimming& d" W0 x+ q. [5 V4 H$ }. f
Open-circuit Protection
* d% q9 ?( |9 w' `( M UVLO, Soft-Start and Thermal Shutdown
$ {0 i! a" R1 n# @6 r' ^) v1 F9 U/ ]1 \ Internal 1.5A Current Limit
7 @! w9 e; K/ u/ S. @- q0 k' i; ], | SOT23-6 Package) `; \" Z2 d) ?% s O
APPLICATIONS
4 y) j' l" Q9 a3 P1 e 5~7” LCD Panels( O$ J& ^/ @; [( @# d
Handheld Computers and PDAs6 w" j3 j ?. S( s1 ? z7 ?
Digital Cameras
! Y; [$ {4 V" H' X5 S Small LCD Displays
0 s( e5 `- P! }0 J6 J |
