#1 ERROR(ORCAP-36004): Conflicting values of part name found on different sections of "U3".
3 U" I) X6 s8 \. W5 v$ qConflicting values: S3C2440AL_3_BGA289_S3C2440AL_ & S3C2440AL_2_BGA289_S3C2440AL_
# F2 Q# s: K. D( n6 P% [Property values of "Device","PCB FootPrint", "Class" and "Value" should be identical
6 q/ |$ B0 H: |4 M on all sections of the part.
) l# e# L) n8 l" @生成网表的时候,这个问题如何解决?我的U3是分成三个部分的(A,B,C),我觉得主要问题估计是在Conflicting values of part name found on different sections of "U3".这一句上,后面几个值我看了应该都是一致的,请哪位好心人帮忙解答一下。。 |
