查看: 78|回复: 0
ZCC3302 替代MP3302
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2023-6-29 18:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    GENERAL DESCRIPTION
    - [! ]& U! y, ^; [3 dThe ZCC3302 is a 7.5V step-up DC/DC converter
    7 Y/ `9 a! _  P5 B4 j8 Tdesigned for driving up to single 10-series or0 c8 |% \3 f" y
    9x3-series WLEDs from a single cell Lithium Ion-
    5 q4 f* ^; J+ qbattery.
    . z8 f! D& t. aThe ZCC3302 uses current mode, fixed frequency
    2 o. ]2 |  {" Barchitecture to regulate the LED current, which is
    4 r8 U+ J" J! I# X4 ]1 emeasured through an external current sense resistor.; F# p) f2 ?' B* w. B
    Its low 300mV feedback voltage reduces power loss
    ' g. s  V& f& mand improves efficiency. The ZCC3302 supports hig-. r* F5 N: r. V3 @
    h frequency PWM Dimming through EN pin.
    9 M/ P# _! x, N- ^, ~The ZCC3302 is turned off if an open-circuit condition2 L! Q/ Y& `5 ]; f2 A
    is presented. Please be noted that open-circuit& Z$ u  Z. G( |
    condition is not the same as over-voltage condition..; `3 h8 @, y  i) k5 @7 Y
    Please refer to the OPERATION DESCRIPTION and
    4 m0 S* ]' K0 `+ i/ |APPLICATION INFORMATION sections for more2 i% l; m+ x4 E! @
    detail.
    ( F! b. D. r- aThe ZCC3302 includes soft-start, under-voltage locko-
    7 _- W! w6 z: |+ c& U! c& q3 eut, current limiting and thermal overload protections.+ W% |, U- z/ I2 j% X' ~
    The ZCC3302 is available in SOT23-6 package.! E0 M1 ]* s& T8 v; X6 C& \
    FEATURES" W% Y- E$ V# d/ q, ~
     Operating Voltage: 2.5-7.5V
    1 J& c$ {/ f6 a2 }) A Maximum Output Voltage: 35V, capable of
    % p& F9 m5 z7 I# Q+ J( bdriving 10-series White LED strings8 @+ c' }. u& ^* {$ c( \/ [
     Maximum drive Capability: 9x3-series or8 }& b+ v8 `0 z, ~$ p. H
    6x6-series.. R4 }# f- g1 {0 ]( c
     Up to 90% Efficiency
    ; U* g+ X4 }7 G- B8 t4 \% A 1.25MHz Fixed Switching Frequency
    $ j. b+ C# U5 s8 c, e8 Y Low 300mV Feedback Voltage/ I8 X% ^; D' H* f
     Support PWM Dimming
    ' y% ]% b0 {$ K7 j* ` Open-circuit Protection
    : H" i, B# Y3 ~' G/ D2 Y7 ~; D UVLO, Soft-Start and Thermal Shutdown) V$ y$ D" g4 j
     Internal 1.5A Current Limit
    , y( c" J5 j+ y+ m SOT23-6 Package  F0 z1 W+ @" A# s; t4 g6 {4 ]9 ?
    APPLICATIONS7 `) @; Z0 i7 J6 W+ n6 f: z
     5~7” LCD Panels9 t4 a* N+ Y+ |" c
     Handheld Computers and PDAs
    6 d5 O# F$ i- U6 D0 y Digital Cameras  F' y+ I: S6 R. N9 m; l3 B0 R
     Small LCD Displays
    + e4 `. w& z6 E7 I& a
    GMT+8, 2025-10-11 23:14 , Processed in 0.140625 second(s), 24 queries , Gzip On.
