查看: 88|回复: 0
Wallys/IPQ5018 + QCN6122/QCN6102: indicates a powerful networking solution.
    郁闷
    2023-6-26 15:26
  • 签到天数: 24 天
    [LV.4]偶尔看看III
    发表于 2023-6-6 09:50 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    The combination of "IPQ5018" and "QCN6122" refers to two different components used in networking devices.
    IPQ5018: IPQ5018 is a system-on-a-chip (SoC) designed by Qualcomm Technologies. It is specifically designed for networking devices, such as routers, gateways, and access points. The IPQ5018 SoC provides high-peRFormance processing capabilities and features to support various networking functions.
    QCN6122: QCN6122 is a wireless networking chip developed by Qualcomm. It is designed to provide Wi-Fi connectivity in devices such as routers and access points. The QCN6122 chip supports the latest Wi-Fi 6E standard.
    The IPQ5018 and QCN6122 are two cutting-edge wireless networking technologies that are set to revolutionize the industry. Let's take a closer look at what they are and how they work.
    IPQ5018:
    https://www.wallystech.com/Routerboard/DR5018-wifi6-Qualcomm-IPQ5018-2T2R-2.5G-ETH-port-802.11AX-MU-MIMO-OFDMA-supporting-QCN9074-wifi-card.html
    The IPQ5018 is a system-on-chip (SoC) designed specifically for high-performance Wi-Fi routers. It is based on a quad-core ARM Cortex-A53 processor, running at speeds up to 1.8GHz. The chip also includes an Adreno 506 GPU for improved graphics performance.
    One of the key features of the IPQ5018 is its support for the latest Wi-Fi 6E standard. This standard operates on the 6GHz frequency band, providing faster speeds and less interference than previous standards. It also supports up to 8 spatial streams, which means it can handle more devices simultaneously without slowing down.
    The IPQ5018 also includes advanced security features such as WPA3 and enhanced Open. These features provide better protection against hacking and other security threats.
    QCN6122:8 n3 A- m0 H. |+ ^
    5 s6 d8 Y; L* b: ~0 [6 A2 _
    The QCN6122 is a cellular modem designed for use in 5G networks. It is based on the Qualcomm Snapdragon X55 5G modem and supports both standalone (SA) and non-standalone (NSA) modes. This means it can operate independently or in conjunction with existing 4G networks.
    The QCN6122 supports download speeds of up to 7.5Gbps and upload speeds of up to 3Gbps. It also includes advanced features such as 5G carrier aggregation, which allows multiple 5G carriers to be combined for even faster speeds.
    The QCN6122 also includes support for multi-mode operation, which means it can switch between 5G, 4G, and 3G networks depending on the availability of each network. This ensures that users always have a reliable connection, regardless of their location.
    Wi-Fi 6E: Wi-Fi 6E is an extension of the Wi-Fi 6 (802.11ax) standard. The "E" stands for "extended" and refers to the use of additional frequency bands in the 6 GHz spectrum. Wi-Fi 6E offers faster speeds, lower latency, and higher capacity compared to previous Wi-Fi standards. It allows for less interference and more available channels for devices to communicate, resulting in improved performance and better user experiences.
    In summary, the combination of IPQ5018 and QCN6122 indicates a powerful networking solution that combines a high-performance system-on-a-chip (IPQ5018) with a Wi-Fi 6E-compatible wireless networking chip (QCN6122). This combination can provide advanced networking features and support for the latest Wi-Fi standards in networking devices.
    1 Q5 @# ^. m2 h+ _+ }* J
    GMT+8, 2025-7-2 04:24 , Processed in 0.093750 second(s), 28 queries , Gzip On.
