查看: 81|回复: 0
ZCC3302 替代MP3302
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2023-5-30 17:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    GENERAL DESCRIPTION: V$ ~1 y8 h# b* s5 U3 B8 l' p
    The ZCC3302 is a 7.5V step-up DC/DC converter0 |$ m( Y" R% H: U+ U) y- g  j
    designed for driving up to single 10-series or: x- [9 T. K/ ^0 \: j  o/ L
    9x3-series WLEDs from a single cell Lithium Ion-
    ! ~4 Y* c( A2 C  \- e; }1 Abattery.
    , n, x. j3 }- q4 ^. z1 U' TThe ZCC3302 uses current mode, fixed frequency8 ~2 D# j7 z4 T
    architecture to regulate the LED current, which is9 K9 O& @2 O3 Z* V
    measured through an external current sense resistor.2 H, }, @- Q/ g% V% ^$ }& a# Y
    Its low 300mV feedback voltage reduces power loss
    ) ~8 c# \2 A. M% g9 I+ Qand improves efficiency. The ZCC3302 supports hig-
    5 I" ^) T' n9 @0 u( k% x* ]9 Hh frequency PWM Dimming through EN pin.
    ; f, y% D( D, G0 `0 z. qThe ZCC3302 is turned off if an open-circuit condition" F4 O1 v- r5 e) c8 }
    is presented. Please be noted that open-circuit- D% X# n! A; A( q& w
    condition is not the same as over-voltage condition..3 W* O1 T- A1 e+ E( X
    Please refer to the OPERATION DESCRIPTION and9 ^4 a* t) @, }6 [+ E4 V
    APPLICATION INFORMATION sections for more" A+ X* H. _- R
    detail.
    3 |. S( G7 y' ?The ZCC3302 includes soft-start, under-voltage locko-
    9 i. c! H0 _/ s# P3 _ut, current limiting and thermal overload protections.2 }1 w7 E; U: z9 {! S: N
    The ZCC3302 is available in SOT23-6 package.
    0 H7 n, W) T" oFEATURES
    8 A  P% o& ?. \$ o5 c Operating Voltage: 2.5-7.5V6 d. \& v5 Q. ]+ E6 ]/ t) Z
     Maximum Output Voltage: 35V, capable of* m- q! x6 {& C* s* I3 T
    driving 10-series White LED strings4 g( [9 h* A& b
     Maximum drive Capability: 9x3-series or" B5 A# l8 k" X9 e6 Q- Y, P
    6x6-series.5 X) J+ _9 `) U8 j
     Up to 90% Efficiency; u- k( D' J) U) ^, X
     1.25MHz Fixed Switching Frequency
    + ~1 a! z; J: q! b Low 300mV Feedback Voltage
    # m: n: Q% t7 W' H; t Support PWM Dimming
    * @  R- U1 ~- L6 G6 r! ^ Open-circuit Protection
    9 F8 A$ {. g$ ~( ]  M UVLO, Soft-Start and Thermal Shutdown
    4 S( {) _: I5 x! e1 g' a Internal 1.5A Current Limit( N# H3 a6 S* g3 M! \8 h" k
     SOT23-6 Package
      n# |$ O4 B$ [/ K% R# qAPPLICATIONS
    1 p, j. }9 Z  @! ?" p 5~7” LCD Panels# Z7 _9 D2 Y- G% S+ u
     Handheld Computers and PDAs4 _7 \0 d& C! T5 t% _( h% Z+ z
     Digital Cameras
    / s  i7 A& ?+ S, x: t; A0 l. p Small LCD Displays
    4 x4 P2 j( L6 `
    GMT+8, 2025-6-30 05:12 , Processed in 0.078125 second(s), 24 queries , Gzip On.
