查看: 773|回复: 2
AD Version 23.5.1Build: 21 更新摘要
发表于 2023-5-19 06:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Version 23.5.1
Build: 21 Date: 18 May 2023
Schematic
52479
For multi-channel designs, the index of the channel was being added after the suffix in diff pair net labels, causing them to no longer be treated as a diff pair. (BC:19519)
52766
The Convert Cross Junctions tool would sometimes create manual junctions, which are no longer a supported object type.
53444
For a specific multi-channel design, the index of the channel was being added before the suffix in diff pair net labels, with ECO changing the diff pair net names.
54365
The PNG graphics for alternate parts were not being generated when creating a PDF of schematic prints from an Output Job.
54426
In the scripting system API's ISch_Document inteRFace, using SchDoc.IsLibrary would lead to the error "Undeclared Identifier:IsLibrary" being encountered.
54656
In some cases when working with a schematic document, the error "EOleException: Ö¸¶¨µÄ²ÎÊýÒѳ¬³öÓÐЧֵµÄ·¶Î§¡£ ²ÎÊýÃû: Unhandled value for TUnit: eDXP" would be encountered.
55224
In some cases, an Access Violation (at address 000000013F274036 in module "ExtensionManager.DLL") would be encountered.
PCB
51492
In some cases when working in the PCB document, the error "EInvalidAccessToObject: Object accessed after being destroyed" would be encountered.
52518
Added support for defining Custom Thermal Relief connection points for pads and vias.
53554
Section View functionality is now available when viewing a PCB in 3D.
53650
In some cases, the error "EInvalidAccessToObject: Object accessed after being destroyed" would be encountered.
54361
When running a batch DRC including Signal Integrity rules, an Access Violation (in module altium.PCB.DataModel.X.dll) would be encountered.
54372
Pin contour information was not being included for custom pad shapes in generated ODB++ data. (BC:20552)
54577
Added the option "Preserve route path" to the Retrace Parameters region of the Gloss And Retrace panel which, when enabled, preserves the exact trace geometry during Retrace. (BC:20402)
54630
The "Apply to Polygon Pour" option was missing from the Creepage design rule when defining rules in the Constraint Editor's document view. (BC:20587)
54747
Repouring of polygons would take a lot longer if logo graphics had been added to the Top and/or Bottom copper layers. (BC:20171)
54819
When viewing the Assembly Drawing output (in an OutJob) through the new Print Preview dialog, the display of some mechanical layers was being mixed up.
54865
Optimized and increased performance when dragging vias, especially in large designs.
54883
Optimized and increased performance when removing net classes, especially in large designs.
54901
For a specific design, closing the PCB document resulted in an Access Violation (at address 000000016831354C in module "ADVPCB.DLL").
54908
Optimized and increased performance when making changes to and saving the layer stack, especially in large designs.
55124
When opening a PCB containing pads with Slot Hole Size > Length, the error "Assertion failure (D:\Build\X2\Main\x2\rtl.epd\RT_Geometry.pas, line 13723)" would be encountered. (BC:20897)
Multi-board
54408
When importing changes from a child PCB project into the parent multi-board project, Mated Parts/Pins data was being cleared instead of updated.
Draftsman
50911
When copying a callout in a specific Draftsman document, the error "System.InvalidCastException: Unable to cast object" would be encountered.
51398
The Description field in a placed Drill Table was not being correctly populated with the description defined in a Pad/Via Template.
54549
In some cases when reconnecting an RDP session during board update, the error "SharpDX.SharpDXException" would be encountered.
Harness Design
53134
Accelerator keys have been added to the menu entries for harness design objects (in Wiring Diagram and Layout Drawing), facilitating placement using shortcut keys.
53510
The 'Clear Filter' command is now available on the right-click context menu in both Wiring Diagram and Layout Drawing documents.
53566
Added a new Harness Covering object for use in the Layout Drawing to place covers over bundles with the ability to tune the length of the cover graphically.
53577
When using Ctrl+Z to undo movement of a connector in the Layout Drawing, the graphical link between that connector and its connection point was not being included in the undo.
53665
Support is now available for adding user-defined parameters to a Connection Point object in the Layout Drawing.
53766
The Edit » Select » Connection command was not functioning correctly in the Wiring Diagram and Layout Drawing editors.
53850
Support is now available for adding user-defined parameters to a Layout Label object in the Layout Drawing.
53851
Added ability to define the background color for a Layout Label object in the Layout Drawing.
54315
When attempting to cross-probe from the BOM document to the Layout Drawing, the error "The method or operation is not implemented" would be encountered.
54350
Added Designator and Comment properties to the Harness Bundle object in the Layout Drawing.
54500
Multi-line text is now supported for the Layout Label object in the Layout Drawing. (BC:20469)
54576
For the Draftsman Connection Table object, column names WireDesignator, WireColor and WireLength have been renamed to Designator, Color and Length, to align with BOM and Wiring List tables.
54740
In nested multi-board projects, a harness project would always import data from the top-level multi-board project instead of the multi-board project to which it was associated.
55008
Updated the icons associated with the Harness Bundle, Connection Point and Layout Label objects in the Layout Drawing.
Platform
54553
In some cases when accessing the Home page, the error "System.Exception: Cef.Shutdown must be called on the same thread that Cef.Initialize was called" would be encountered.
54690
In some cases, Altium Designer would be terminated by Windows if the file "Project Group 1.DsnWrk" was not accessible.
54818
Menu entries for creating a VB Script Unit/Form were not presented when enabling the Legacy.Scripts.SupportOldLanguages Advanced Settings option.
54840
Altium Designer would terminate when trying to create a new PCB project and including the extension (*.prjpcb) as part of the project's name.
Data Management
52525
The menu to create a new project based on active process definitions (workflows) was not visible when the Home page was the active document tab.
52975
With File Locking enabled, using the "Revert to" feature from a Commit event tile in the project's History view would result in an error.
53462
It is now possible to add a comment with an image to a General Task.
54252
Commit tag and release names are now displayed for comments when accessed in Altium Designer.
54506
In some cases when using the Library Importer, the exception "System.Exception: Get component type tag list error" would be encountered.
54542
In some cases when opening a managed project, the error "System.NullReferenceException: Object reference not set to an instance of an object" would be encountered.
54554
In some cases, the error "System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation" would be encountered.
54666
For a specific design project and Git repository, the preparation stage when using the Project Releaser would take over three minutes.
54692
When scrolling through the list of templates in the Edit Templates dialog, links to Component Types were being removed from the Component Templates.
54752
An "Access Denied" error would be encountered when opening a document of a Workspace project, while connected to a different Workspace (not the one in which that project resides).
54764
In some cases when adding a Part Choice to a component in the Single Component Editor, connection to the Workspace would be lost and the error "Vault is disabled" would be encountered.
54832
The redundant 'Install from server' and 'Edit' controls have been removed from the Data Management - File-based Libraries page of the Preferences dialog.
54844
It was not possible to define a component type for a component template that had no name.
54855
It was not possible to fully migrate, with history, a rehosted Workspace (that used an external SVN repository) to the Altium 365 Workspace's native Git repository (Versioned Storage).
54869
The Save All command on the right-click context menu for a project's Source Documents entry (in the Projects panel) was not available after having modified a source document. (BC:20766)
54875
When switching component templates for a component in the Component Editor (SCE mode), required parameters from the previously chosen template were still shown as mandatory. (BC:20772)
Import/Export
52872
When importing a specific xpedition library using the Import Wizard, 3D bodies with a height of 0mm were incorrectly set to a height of 0.254mm (10mils) in the resulting PcbLib.
54089
In some cases when importing orcad and PADS designs/libraries using the Import Wizard, an Access Violation (in module "Importer_PADSOrcad.IWZ") would be encountered.
54093
In some cases when importing OrCAD designs/libraries using the Import Wizard, an Access Violation (in module "Orcad7ld.dll") would be encountered.
54657
In some cases when importing a 99SE design database (*.ddb), the error "EOleException: Compilation controller doesn't exist" would be encountered.
Simulation
54101
Added support for interactive probes to investigate a circuit and see real-time updates to the data in the generated SDF file. (BC:19869)
54434
A redundant and partially visible control at the bottom of the Measurement Plot dialog has been removed.
54435
When viewing measurement data in a Measurement Table (chart), the horizontal scrollbar was not working correctly.
54493
A redundant verification was being performed when switching between the analysis results and the Schematic document.
54520
The redundant option "Show Sim Data panel" has been removed from the Document Options dialog for the Sim Data Viewer.
54589
Added support for multi-bit DAC and RAM Pspice digital model primitives (and their related timing models) and Bidirectional Transfer Gate PSpice digital model primitives (PBTG, NBTG).
54716
In some cases when working with the Sim Data Viewer, the error "EOutOfResources: Error creating window device context" would be encountered.
55025
When trying to print from an SDF file containing multi-variable analysis results, errors would be encountered along with some waveforms not visible in the print preview.
55056
Variable R, L and C components in a sub-circuit were not being processed correctly when running a transient analysis, leading to an error in the format "unknown controlling source edq.c".
/ L$ e. f* _" k. I" g1 P7 ~4 j8 e7 }
    郁闷
    2020-11-23 15:19
  • 签到天数: 104 天
    [LV.6]常住居民II
    发表于 2023-5-19 07:02 | 只看该作者
    发表于 2023-5-23 14:22 | 只看该作者
    谢谢楼主分享!! I" [. u7 A' k8 e9 j6 p4 T
    GMT+8, 2026-5-7 19:08 , Processed in 0.156250 second(s), 24 queries , Gzip On.
