TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
GENERAL DESCRIPTION0 D: L0 g: P5 C
The ZCC3302 is a 7.5V step-up DC/DC converter
5 l* Q6 t7 t# s* t9 Q9 a# t% O( ydesigned for driving up to single 10-series or
" O1 W& y+ W% i6 v9x3-series WLEDs from a single cell Lithium Ion-
: K* h; t2 |# r5 \/ {- Gbattery.
1 h/ r! r0 K' w7 `0 ~/ xThe ZCC3302 uses current mode, fixed frequency; z1 j' p; `, r% S. x! c( v# _+ ]
architecture to regulate the LED current, which is
' h; N! m7 Q! U) \measured through an external current sense resistor.
* f3 q9 [" A1 \) f1 Q9 n, l: Y9 r1 e4 {Its low 300mV feedback voltage reduces power loss
% ~/ J: ^4 F4 e' x% }" f' j% xand improves efficiency. The ZCC3302 supports hig-9 l9 l8 V; O. @% Y9 n6 _& G8 m
h frequency PWM Dimming through EN pin.
, o* P4 K2 j$ TThe ZCC3302 is turned off if an open-circuit condition# ~: ?! G; p( C7 V
is presented. Please be noted that open-circuit
# ^" H5 y$ E" l- ~9 @+ ncondition is not the same as over-voltage condition..
6 j6 G3 h& m9 W+ BPlease refer to the OPERATION DESCRIPTION and: b3 R" I* R, Q# I V. O/ i( B4 F
APPLICATION INFORMATION sections for more
- _" S9 j5 e7 Odetail.
9 d4 s2 v- Y% q4 |The ZCC3302 includes soft-start, under-voltage locko-
1 y* m0 r8 C. X3 \ut, current limiting and thermal overload protections.
1 c8 J' m W9 { v2 F3 d/ _$ }The ZCC3302 is available in SOT23-6 package.; ]+ }) {# F8 n" w. v; ]
FEATURES
u; g2 [! v" t' z3 C5 }& u Operating Voltage: 2.5-7.5V
) c8 i/ _$ X# |: a( ]2 O Maximum Output Voltage: 35V, capable of
8 X h; ?% I: y \driving 10-series White LED strings" K# R# k! i; A+ V6 n0 t
Maximum drive Capability: 9x3-series or8 B/ Q2 c$ T0 `$ O) c' s- `
6x6-series.9 l# ]& L- J ~5 z1 U7 Z6 a
Up to 90% Efficiency' u- `) P4 ^0 D) D" R- H
1.25MHz Fixed Switching Frequency9 K8 q2 K# [3 U# B9 ]( {
Low 300mV Feedback Voltage5 \$ h- W, x+ s* w/ l( R- s
Support PWM Dimming+ s( t0 a: p, R* ]% W) J
Open-circuit Protection
7 x& H3 H$ x! x1 r/ f UVLO, Soft-Start and Thermal Shutdown
7 S4 ^( x. \ N4 H G! ?6 g Internal 1.5A Current Limit
7 }! m3 R* e% Z7 Z( _1 b: I' Q. F0 \ SOT23-6 Package
& a. P+ a4 i @9 rAPPLICATIONS
& e9 ]' u0 K7 G0 a3 {: `) t" a* r 5~7” LCD Panels
6 J/ U: o8 L0 ?+ c: M. p Handheld Computers and PDAs1 L) l- E$ R) T' |% r. }1 Q
Digital Cameras
" x7 ]6 a+ g3 W: z p* e: E& { Small LCD Displays0 x( x) @1 B4 O) B" t0 B; [7 R
