查看: 78|回复: 0
Wallys miniPCIe wlan modules/ QCA9880 /2.4G&5G
    郁闷
    2023-6-26 15:26
  • 签到天数: 24 天
    [LV.4]偶尔看看III
    发表于 2023-5-16 11:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    Mini PCIe (Peripheral Component Interconnect Express) is a small form factor expansion card inteRFace that offers several advantages over other interfaces:
    & E$ s1 B) F; N6 N- lSmall size: Mini PCIe is designed to be compact, which makes it suitable for devices with limited space, such as laptops and small form factor desktops.
    / _2 ?/ j+ C" W1 e+ x; p' uHigh speed: Mini PCIe supports high-speed data transfer rates, which makes it ideal for use with devices that require fast data transfer, such as wireless networking cards, solid-state drives (SSDs), and graphics cards.
    + }9 ?8 C2 K8 u6 ^- D) c  wPower efficiency: Mini PCIe is designed to be power-efficient, which makes it ideal for use in portable devices that rely on battery power.  ?2 Z" B( v* Q3 h5 f3 L8 _
    Standardization: Mini PCIe is a standardized interface, which means that it is widely available and compatible with a range of devices.3 j$ Q0 S- Q$ U: S! y6 m
    Flexibility: Mini PCIe supports a range of different peripherals, including Wi-Fi cards, Bluetooth cards, SSDs, GPS modules, and more. This makes it a versatile interface that can be used in a variety of different applications.
    Antenna connectors: These modules come with antenna connectors, usually in the form of small coaxial connectors. The antennas are used to transmit and receive wireless signals, ensuring proper reception and transmission of data.
    Compatibility: MiniPCIe WLAN modules are compatible with devices that have MiniPCIe slots. These slots are commonly found on laptops, small form factor desktop computers, and embedded systems. However, it's important to note that MiniPCIe slots are not as prevalent in modern laptops as they used to be, as newer laptops tend to use smaller M.2 slots for wireless modules.
    Upgradeability: One of the advantages of MiniPCIe WLAN modules is their ability to be upgraded or replaced. If a device's wireless capabilities become outdated or require improvement, the MiniPCIe WLAN module can be swapped out for a more advanced module without replacing the entire device.
    Best regards
    DR900VX
    https://www.wallystech.com/Network_Card/DR900VX-Qualcomm-Atheros-QCA9880-3T3R-MIMO-802.11ac-Mini-PCIe-Wi-Fi-Module-Dual-Band-2-4GHz-5GHz.html
    Qualcomm-Atheros QCA9880 chipset
    2.4GHz max 26dBm & 5GHz max 25dBm output power
    IEEE 802.11ac compliant & backward compatible with 802.11a/b/g/n
    3x3 MIMO Technology, up to 1.3Gbps; a' m- s1 |+ _9 P
    Mini PCI Express edge connector
    RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
    Supports Spatial Multiplexing, Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes, Maximal Ratio
    Combining (MRC), Space Time Block Code (STBC)
    Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
    Supports Dynamic Frequency Selection (DFS)
    FCC,CE and IC Certification
    . w7 [1 Z3 G9 R' p- I2 O5 F
    GMT+8, 2025-7-2 23:57 , Processed in 0.078125 second(s), 29 queries , Gzip On.
