DR9074-6E6 D) l& H8 z1 D
https://www.wallystech.com/Network_Card/DR9074-6E-Wifi6E-Qualcomm-QCN9074-Single-Band-6GHz-4T4R-M-2-E-Key-InteRFace-802-11ax.htmlhttps://www.wallystech.com/Network_Card/DR9074-6E-Wifi6E-Qualcomm-QCN9074-Single-Band-6GHz-4T4R-M-2-E-Key-Interface-802-11ax.html
- \! }; g* j: g1 S
: \" c, d `# KFeatures6 @% e2 T8 ?9 a+ ^/ w! o$ f# Y
■ Qualcomm Atheros QCN9074/QCN9024 ! X$ z; Q. W& J; w& ]& V
■ 6GHz, max 23dBm per chain, up to 4949Mbps
9 K. w$ V1 \5 b @1 {8 R o! z■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
" D+ u8 [/ E. _, G1 a, Y■ 4 spatial streams (4SS)
. H- R+ [6 R3 l" N% ?5 k4 v' A+ q# S■ M.2 E Key Interface
+ L/ S- n% d# {/ Z: Z! {■ PCI Express 3.0 Interface ![]()
* d# G5 ]. A, F( T/ l. |QCN9074 and QCN9024 are both model numbers of Qualcomm's system-on-chip (SoC) products, which are used in mobile devices such as smartphones and tablets.The QCN9074 is a newer and more advanced SoC compared to the QCN9024. It is based on the 5nm manufacturing process and has a more powerful CPU and GPU, as well as better support for advanced connectivity features such as Wi-Fi 6E and 5G. In contrast, the QCN9024 is based on the 8nm manufacturing process and is a slightly older and less powerful SoC. It still offers good performance and features, but it may not be as advanced or efficient as the QCN9074. In summary, the main differences between the QCN9074 and QCN9024 are their manufacturing process, performance, and support for advanced connectivity features.
; f1 J7 X; s; t7 r9 b/ K7 ]QCN9074和QCN7024的区别
( C* r* l/ g1 A M* s( U8 \' X![]()
: u Z$ v0 u8 W% [, j
* q* L6 Q! E2 ]+ |# `) o 5 }& s1 r" {) a+ U
