TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
Features
* r* m; w, K1 D 9V to 100V input voltage range
& u/ |5 l4 {$ S I) t% v 1.5A/5A continuous output current/ }; {+ Y3 R3 g9 U, g& J+ ?& e
95% Peak Efficiency
$ S8 d, z$ e" W6 r 400μA operating quiescent current3 x* f) _8 z6 I3 z. D# [8 O
100V 400-mΩ high-side MOSFET x! y* `0 f& Q7 {/ Y7 w8 H
Peak Current mode control
* L5 K% C! v4 `* w' y& L* l 150 kHz Fixed Frequency
7 C2 ~9 o+ v' s+ d6 R Internal compensation for ease of use! j9 |/ y- T+ I: N: X
Up to 92% duty cycle, U$ h5 [1 l: x* ?+ }
0.8V voltage reference
3 _0 l' \& h) Z' Z6 w: G2 g 1μA shutdown current0 l+ R; C9 k* Q: s5 W# X: u- G
3A/6A cycle-by-cycle current limit
, x$ K, g! O( P* i0 S; K 150ms Hiccup mode short circuit protection
$ C2 }! y# n- ]) M4 T1 eFunction
, G6 y+ q3 {2 z0 ? Thermal shutdown Function
3 G& e# ?* a0 H) v0 q ESOP-8 package: f( P# l5 T/ r0 `; h
Applications5 Y! a* W9 M/ C0 ]
Charger in vehicle, D: L A1 ~, i- g& c5 m# ]
Battery Chargers
, P2 R% k0 k" U7 R Power adapter9 _+ n# S0 j: E# |
Typical Application
' {( W$ V+ z* W1 ^: @Description
) u7 I, m) g6 @The ZCC1005 is a high voltage, non-synchronous. Y, Q. |8 ~1 v5 N3 ^% c6 C5 O( a* Y
step-down converter operates over a wide range& |( j' z6 }/ _; V% K" Y& [
input voltage
" V# A6 B( c7 U6 m9V to 100V. The ZCC1005
* t% W# r5 d) c* F Fintegrates a 100-V 400-mΩ high-side MOSFET.
3 d* J( @# P0 t( C% zThe ZCC1005 delivers 1.5A continuous load ~# v! l `! |" k
current with up to 95% efficiency. The ZCC1005
0 G3 M$ L( E$ N0 |- F* Xoperates with fixed frequency peak current control
9 f, Y9 U g' Lwith built-in compensation eliminates the need for
( k/ Q/ {( R# zexternal components.
- {8 Z4 Z+ s( N* \6 N- e1 VCycle-by-cycle current limit in high-side MOSFET- s3 o& u7 V1 _9 w
protects the converter in an overload condition.
- q/ q3 m( V2 dHiccup mode protection is triggered if the
6 h0 U! s% E: M. c( H- Xover-current condition has persisted for longer than
0 f9 H" P& f2 G- x1 T7 [1 u9 Cthe present time.. i2 Y3 ]$ @5 k' F/ O- ~3 _
The ZCC1005 exhibits protection features that: V Y: {0 K. ?( z1 K
protect the load from faults like under-voltage,8 i: ]5 ?; G% G3 @0 n# V# p1 C
over-current and over-temperature.! `% ]" B+ N5 U0 ]- _+ ^: t
The ZCC1005 is available in an ESOP-8 package.
4 }( x F( i( e) _0 f. O# f$ I! x |
