查看: 116|回复: 0
DR-AP40X9-A-Qualcomm-IPQ4019/IPQ4029-2.4G&5G
    郁闷
    2023-6-26 15:26
  • 签到天数: 24 天
    [LV.4]偶尔看看III
    发表于 2023-4-28 15:00 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    DR-AP40X9-A
    https://www.wallystech.com/Industrial_Wireless_AP/DR-AP40X9-A-Qualcomm-IPQ-4019-IPQ-4029-5G-4G-LTE-aluminum-body-dual-band-wifi-router-2.4GHZ-5GHz-QSDK-firmware.html
    BY:Wallys Communications (Suzhou ) Co., LTD
    We mainly develop high power wireless products based on Quacomm chip such asIPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/IPQ8072/IPQ8074/QCN9074 and so on .
    Description
    DR-AP40X9-A  is a 2x2 2.4G&5G high power Radio AP Router which including 1x  DR40X9(IPQ4019/IPQ4029) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);
    1 x Enclosure.
    Dipole antenna
    ■  2 x 2.4G&5G Antenna
    " P) @6 f2 I9 D2 d■  5dBi 2.4GHz/5Ghz
    8 E4 p: O& z1 t  R  q9 d■ SMA Plug inteRFace 6 V4 P, e8 r. t- y8 {1 N4 W5 v
    ■ Plastic rod of black 6 m% @4 ^7 W: O
    ■ RoHS compliance
    Enclosure
    ■  Dimension: 132x 119 x 34 mm
    ! }; p) k9 h& }' c! w3 g6 l■  Aluminum alloy material5 O' s6 M) S4 S; Z
    ■  Support WallysDR40X9
    The IPQ4019/4029 Board is capable of providing up to 10.5 kilometers of wireless transmission range on the 2.4 GHz frequency and up to 20 kilometers on 5 GHz. The integrated antenna features an omni-directional design, creating a more reliable communications link between your devices no matter where they are located in the room. The dipole antenna configuration delivers better performance at shorter distances especially when you have multiple APs located close together in the same building or in different buildings.
    ) b. [6 K8 @, B% X2 h; [. f7 V4 v
    GMT+8, 2025-7-2 14:46 , Processed in 0.093750 second(s), 28 queries , Gzip On.
