syntax error at or before "'D:\HSPACE\Demo\tsmc018\mm018.l'" "TT"
- L* x% K' A* k f1 h7 T6 b3 z, Z; X$ F. Z& @% A3 I
Syntax reference: ) K6 G2 b4 ~3 V# O
Lxxx n1 n2 <L=>inductance <<TC1=>val>
0 A# `* s' N7 |; _7 v7 V+ <<TC2=>val> <SCALE=val> <IC=val> <M=val>
$ V! k8 w \8 M5 m8 y5 V+ <DTEMP=val> <R=val>
1 k' j5 p7 e. Y+ rLxxx n1 n2 L='equation' <LTYPE=val> <above_options...>
- [$ I- p1 P2 ELxxx n1 n2 POLY c0 c1... <above_options...>3 R# K, | W$ ?: L1 w; }1 U7 `% G8 u
Lxxx n1 n2 NT=turns <above_options...>4 C7 C+ ?; k2 q$ Y6 J9 a
Lxxx n1 n2 L='equation' <CONVOLUTION=[0|1|2] <FBASE=value># E. |' r, O- |
+ <FMAX=value>>* m5 P- D1 X, I @
Lxxx node1 node2 <L=> INFINITY <IC=val>
6 X I' |; g/ a1 z8 v- [Lxxx n1p n1n ... nNp nNn
2 ?; R; y, e* N' `# T- r+ RELUCTANCE=(r1, c1, val1, r2, c2, val2, ... , rm, cm, valm)0 U. Q& E0 C# U: F" e' E) k8 L9 m7 o
+ <SHORTALL=yes | no> <IGNORE_COUPLING=yes | no>: Y% j: B! [* F4 {
Lxxx n1p n1n ... nNp nNn RELUCTANCE5 W. f) l( D, X* \
+ FILE="<filename1>" [FILE="<filename2>" [...]]
/ K8 R+ Z: t8 C# F* w/ t; p+ <SHORTALL=yes | no> <IGNORE_COUPLING=yes | no>
5 W" n3 v8 I' F" u, U& y y# K) U1 _# r, n/ n' y
新手用老师的程序运行错误!不太明白错在哪里,求解答 |
