查看: 96|回复: 0
Wallys/QSDK/IPQ4019 and IPQ4029 chipsets support 20 km remote transmission
    郁闷
    2023-6-26 15:26
  • 签到天数: 24 天
    [LV.4]偶尔看看III
    发表于 2023-4-24 15:25 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    The IPQ4019 and IPQ4029 chipsets from Qualcomm are designed for high-peRFormance Wi-Fi networks, providing advanced features such as MU-MIMO, beamforming, and enhanced spectral efficiency. These chipsets are suitable for a wide range of applications, including enterprise, industrial, and residential wireless networks.
    When combined with the Wallys WiFi5 Industrial Wireless AP DR-AP40X9-A, these chipsets can provide exceptional long-range connectivity. The DR-AP40X9-A is designed for outdoor use and is equipped with high-power radios and antennas, allowing it to cover a large area with a strong Wi-Fi signal. With the IPQ4019 or IPQ4029 chipset, the DR-AP40X9-A can deliver reliable and high-speed wireless connectivity over long distances, making it an ideal solution for industrial applications, remote locations, and outdoor environments.
    ' L" o% C) k3 P; N
    2 p# l: r9 E! x1 B) `6 l- S
    Description
    DR-AP4029(Outdoor) is a 2x2 2.4G&5G high power Radio AP Router which including 1x DR40X9(IPQ4019/IPQ4029) Board;1 x Onmi Antenna; 1 x POE Adapter(24V^1A~48V^0.6A);1 x Enclosure.
    Panel Antenna
    ■  2 x 5G Antenna
    ■  5G: 17dbi
    DRA25 Antenna
    ElectricalProperties :
    Frequency Range:2.4~2.5&5.15~5.85GHz
    Impedance:50Ω
    VSWR:2.0 Max (≤2.0)
    Gain(peak):6±0.5dBi
    Polarization:Linear; Vertical
    Physical Properties :
    Cable:RG-141 Cable
    Connector:N-type PLUG
    Antenna CAP:ABS
    OperatingTemp:-40℃~+65℃
    Storage Temp:-40℃~+75℃
    CableTemp:<+250℃
    Enclosure
    ■  Dimension: 275x140x48mm
    ■  UV Protected and Durable ABS Radome
    ■  IP67 Waterproof Level
    ■  Support Wallys  DR4029% B2 g/ A( W- e1 E! L
    DR-AP4029(Outdoor) is a high-power radio AP router that operates on both 2.4GHz and 5GHz frequencies. It comes with a DR40X9 board, an Omni antenna, a POE adapter, and an enclosure. The panel antenna of DR-AP4029 includes 2x 5G antennas with a gain of 17dbi. Additionally, the DRA25 antenna has a frequency range of 2.42.5&5.155.85GHz, a peak gain of 6±0.5dBi, and a linear vertical polarization. The antenna is connected using RG-141 cable and N-type plug connectors. It can operate within a temperature range of -40℃~+65℃ and can withstand cable temperatures of less than +250℃.
    The enclosure of DR-AP4029 has dimensions of 275x140x48mm and is made of UV-protected and durable ABS Radome material. It has an IP67 waterproof level and supports Wallys DR4029.
    . U7 A: ^' j8 l5 ^
    GMT+8, 2025-7-2 14:15 , Processed in 0.093750 second(s), 28 queries , Gzip On.
