查看: 107|回复: 0
IPQ6010+QCN9074/QCN9024 M.2 2.4G/5G moudle WPA3 Encrypt up to 1201Mbps
    2023-2-7 15:43
    发表于 2023-4-20 13:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    $ R8 [1 [1 U% z
    # B% {* D9 ]2 Q
    IPQ6010 wifi6 wireless solution
    / ?- t- L- Y: Y1 N: w& P- w! g
    - w' l( h& a& q* e) V0 r- i- S
    High peRFormance: IPQ6010 is equipped with Qualcomm's own Kryo processor, which supports multi-core processing and has a dominant frequency of up to 1.8GHz, providing excellent wireless performance and processing power. " P# R% l! c4 S; l+ F& |. O
    0 V: y9 t6 L" b
    Wi-Fi 6 Standard support: IPQ6010 supports the IEEE 802.11ax standard, also known as Wi-Fi 6, providing higher wireless speeds and lower latency. IPQ6010 is also backward compatible with devices that support the IEEE 802.11a/b/g/n/ac standard.
    6 w( H* e  F% T  I8 |
    # e" V- j* t9 E2 n/ `
    MU-MIMO technology: The IPQ6010 supports the multi-user multi-input Multi-output (MU-MIMO) technology to communicate with multiple devices at the same time, providing higher network efficiency and performance. ; A# g4 V6 T3 n; V- @1 T0 L: y. c
    . i& b9 S% u0 D# o" M. gStrong security: IPQ6010 integrates Qualcomm's own security technologies, including WPA3 encryption, 802.11i security protocol and advanced authentication and data protection functions, to ensure the security and privacy protection of network connections. 2 w4 |( W; F: Z  B
    ( T- @) M& e, c
    Comprehensive Network management: IPQ6010 supports Qualcomm's Network Manager software platform and provides advanced network management and optimization features, including intelligent bandwidth management, traffic scheduling, device management, and Quality Service (QoS), providing more control and optimization options for network managers. + }" g- g7 q2 D
    4 u8 v, h' n- `! H8 P+ P- {5 e
    Rich hardware interfaces: The IPQ6010 provides rich hardware interfaces, including Ethernet, USB, UART, SDIO, etc., to facilitate the connection and communication with various external devices. 6 u# c+ |* {( R  Q8 a4 X
    * D1 D5 h+ j4 N# P  v+ e( v
    Comprehensive application scenario support: The IPQ6010 is suitable for a variety of application scenarios, including routers, gateways, Repeaters, wireless base stations, industrial controls, and smart homes, providing flexible deployment and integration options.
    8 z! @; G, b0 ~1 [/ W
    # Q: l6 y& d6 z" W
    IPQ6010 supports a variety of frequency bands, including but not limited to the following: 4 N8 Z: {. T( i0 h: E) P
    " Z$ X2 h% G" r$ x' i8 K# L, g2.4GHz band: IPQ6010 supports IEEE 802.11b/g/n and provides wireless speeds up to 600 Mbps in the 2.4GHz band. 5 K& R6 h+ ~9 U5 C! Z
    4 T7 ]: q6 h# g/ e
    5 GHz band: IPQ6010 supports IEEE 802.11a/n/ac/ax standard, providing higher wireless speed and performance in the 5 GHz band, up to 4.8 Gbps.
    3 z+ L0 m5 _. [% B9 q2 ^
    ! Z. T  u+ F! J9 D9 Y( ^9 E0 L6 GHz band: IPQ6010 supports the emerging 6 GHz band in IEEE 802.11ax standard, providing more wireless spectrum resources to support higher wireless speed and capacity. This is advantageous for providing high density wireless network connectivity, such as in public places, enterprises and high density residential areas. 1 H3 y, W& A. J
    9 y7 T8 p1 q. H" n$ c
    4 B% m2 l4 q& Q6 d2 d
    It and QCN9074/QCN9024 M.2 card implementation performance:
    % I( |% B' R2 x1 `% D
    9 B4 G/ K& ?  j6 w5 ZQCN9074: QCN9074 is an M.2 format Wi-Fi 6 module for embedded devices and mobile devices such as laptops, tablets, industrial control devices, etc. It uses a PCIe interface to connect hosts and supports high-speed and low-power wireless connection. It is suitable for embedded devices to implement Wi-Fi 6. 5 G( J7 q9 X# c4 o
    ! Z! r  a0 e9 i$ r" L5 e
    QCN9024: QCN9024 is an M.2 format Wi-Fi 6 module designed for use in industrial control, Internet of Things devices and embedded systems. With its small size and low power consumption, it is suitable for wireless connectivity in embedded devices. - Z8 `' V) A* ]- g$ E+ a
    0 u+ G" F" _1 g' \$ f# U& D' m$ KThe performance of the IPQ6010, QCN9074, and QCN9024 varies according to the application scenario, configuration, and usage conditions. Generally speaking, IPQ6010, as a high-performance Wi-Fi 6 chip, can provide higher transmission rates, lower latency, and better network capacity. It is suitable for network devices requiring high-performance wireless networks. QCN9074 and QCN9024, as embedded modules, may have some choices in size, power consumption and performance, and are suitable for embedded devices and Internet of Things applications., C2 h9 {/ j4 A$ P
    ( A6 Z, d2 F& b* L
    ; s) D4 F5 j  F. A. ?Wallys software technology advantages:
    4 T# w5 U- X+ e+ u+ p9 r
    # [- C1 z& `4 z" M! j  b3 K9 YWallys has 10 years of experience in software development and is very experienced in uboot, Linux, wifi protocol, wifi performance, OS and other systems. It mainly uses Qualcomm chips to develop important software such as drivers and kernels, and has the ability to modify and compile to meet customers' different wifi functional requirements. Meanwhile, it participates in openwrt organization and code development. wifi5 product DR40x9 has been officially supported by openwrt.
    ; M- U' |- E& ]1 O! k
    + _( D( e7 z; G
    Hardware technology advantages:
    ! a: ~2 o0 H% l  @. u+ B+ v) g; D
    6 D2 f. @" O+ v! p+ oWe have a strong hardware design team, and experienced people know that the most difficult part of hardware design is RF circuit design, baseband, etc., while wallys team made 0 error to achieve signal integrity, such as frequency conversion of network card, from 2.4G to 900M, which is a technological breakthrough.
    ! |- Y& o; U/ M$ \5 T
    ( S7 m$ z) j& E+ S+ `Clients: TIP,Facebook, Openwrt, etc
    : N, ~: P4 l( y! H( x; h
    % p; R% K6 \' ?! Q" B3 ~& qEmail:sales@wallystech.com
    / x5 v/ H5 S. O! V
    5 c  g/ ^! o5 x- W# k5 e
    WEB:Wallys 802.11ax, wifi 6, IPQ4029,IPQ4019,IPQ6018,IPQ6000.Router board, wireless card.Access Point.& @: F% r2 z, T/ v
    $ x( C- Z; z2 T; M8 X7 `
    ! ^9 O% F' W5 y
    GMT+8, 2025-7-2 22:52 , Processed in 0.093750 second(s), 28 queries , Gzip On.
