本帖最后由 Heaven_1 于 2023-3-28 09:17 编辑 0 k/ z0 i7 h1 ? Q1 q
+ N+ u. Z: [0 A" `
睿普康集成电路是一家专注于 4/5G 通讯芯片、数据通讯及物联网领域 SOC 芯片及解决$ i; K: M* E. |. R+ q
- J4 \* y6 v+ v. |- I, o1 ~
" o7 ] |9 m8 j& v) g. p# n9 z方案的设计公司。公司目前 90%以上为研发人员,其中硕博学历者 20 人左右, 有着多
' G. _4 z; G. p' H' l0 Y' M( j1 v' ?# Y
7 \2 t0 V a% i1 E年服务于国内外著名芯片设计公司的经历。睿普康公司为客户提供 LTE CAT1 芯片及! w% R7 {9 z* h/ m& V+ g
0 A, J' B! ^; O9 y" b. q' B; u
& M/ D+ Q/ Z9 m0 q2 s5 a9 N' L, lCAT1 模组、以太网交换及 PHY 芯片、无线传输、电源能效管理等具有自主知识产权的! J* r% C' ^$ e/ r! m; g- s
) z s+ m6 j9 b1 q9 ]" r& a- C7 a% P1 C1 G4 T, Y2 w. Q: H
系列芯片及其解决方案。
+ q, v( V0 _' c) t8 `/ \! s# i" W' E6 s; Z
1 General Description0 ~+ V5 ]- A- S, E7 {! i
The RPC8201F is a single-chip/single-port 10/100Mbps Ethernet PHY transceiver that6 O; s) g$ s U0 Z- v, l4 y
supports: 2 [5 I/ `3 E7 M1 N! D' ?
• MII (Media Independent InteRFace)
( L2 ]/ J3 I& w8 R9 g• RMII (Reduced Media Independent Interface); N/ W$ B, q2 D! S3 x& _
The RPC8201F implements all 10/100M Ethernet Physical-layer functions including
) {9 i0 o9 z) p# ~: K( A; mthe Physical Coding Sublayer (PCS), Physical Medium Attachment (PMA), Twisted Pair
5 f, i/ x+ M& o! w" E4 u5 OPhysical Medium Dependent Sublayer (TP-PMD), 10Base-TX Encoder/Decoder, and
, u& c. D7 ]& z+ bTwisted-Pair Media Access Unit (TPMAU). The RPC8201F support auto MDIX.
- S" _0 I, U& p) l, f8 a- \The RPC8201F uses mixed-signal processing to perform equalization, data recovery,
! c* J3 @* P9 U4 A' Qand error correction to achieve robust operation over CAT5 twisted-pair cable. 7 F9 ?; q6 R0 s
The RPC8201F offers integrated built-in self-test and loopback capabilities for ease of
4 p. a/ Q9 l4 Y6 `# R7 D! Muse, and innovative and robust approach for reducing power consumption through EEE, 2 X& k5 I+ M& [4 V5 F/ D
WoL and other programmable energy savings modes./ j. `, c: i( j. E
/ D- e; P9 r t$ [9 I
详情请看附件规格书
/ f, ^* o) j2 c {6 r, I1 X- n( \, i% {
