查看: 211|回复: 1
wifi7-IPQ9574 up to 12 spatial streams 10.8 G MUMIMO achieve faster speeds le...
    2023-2-7 15:43
    发表于 2023-3-20 15:05 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
    wifi7-IPQ9574 up to 12 spatial streams 10.8 G MUMIMO achieve faster speeds less congestion
    Wi-Fi 7 is not yet a formalized standard cutoff date (September 2021) and is still in the development phase.    However, there are already some companies working on developing Wi-Fi 7 chipsets and devices.
    As for Wi-Fi 6E, which is the latest standard for Wi-Fi, there are already several routers and devices that support this technology.    Some of the applications of Wi-Fi 6E include:
    High-density environments: Wi-Fi 6E can support more devices and deliver faster speeds in high-density environments such as airports, stadiums, and shopping centers.
    Home networking: Wi-Fi 6E can provide faster and more reliable wireless connectivity for homes with multiple connected devices.
    Virtual and augmented reality: Wi-Fi 6E can enable high-bandwidth applications such as virtual and augmented reality experiences.
    Gaming: Wi-Fi 6E can provide low-latency connections for online gaming.
    Enterprise networking: Wi-Fi 6E can provide faster and more reliable wireless connectivity for businesses and enterprises.
    The seventh-generation WiFi network is capable of speeds up to 30Gbps, more than three times the 9.6Gbps speed of WiFi 6. Compared with Wi-Fi 6, WiFi 7 will introduce CMU-MIMO technology to support up to 16 data streams, changing from 8 lanes to 16 lanes, no problem interplanetary highway. Besides the traditional 2.4GHz and 5GHz bands, WiFi 7 will also support 6GHz bands, and the three bands can work simultaneously.
    The IPQ9574 is a Wi-Fi 6E (802.11ax) chip designed by Qualcomm for use in wireless routers and other networking devices.   It is part of the company's Networking Pro series and is based on the company's 64-bit quad-core ARM Cortex-A53 architecture.
    The chip supports up to 12 spatial streams and can deliver speeds of up to 10.8 Gbps.   It also includes Qualcomm's Multi-User Multiple Input Multiple Output (MU-MIMO) technology, which allows multiple devices to connect simultaneously and receive data on the same channel.
    The Wi-Fi 6E standard introduces support for the 6 GHz frequency band, which allows for faster speeds and less congestion compared to the 2.4 GHz and 5 GHz bands.   This makes the IPQ9574 particularly well-suited for use in high-density environments such as apartment buildings, offices, and public venues.
    Wallys is the most worth working with because Wallys has over 10 years of experience on qca WiFi chips, from ar5414 to ar7161, with full access to the chip's code.
    As a result, Wallys can help customers solve many of the problems that customers encounter on WiFi.
    Wallys has also developed special protocols such as tdma over WiFi and fast roaming. You can run WiFi within 20 kilometers, and you can even disable ack to expand WiFi range.
    Wallys can also develop a 4.9Ghz narrow band, such as 5/10Mhz.
    Wallys is a professional company in WiFi and can solve any technical problems you have, so we can help customers to make a lot of innovative products
    发表于 2023-3-20 16:00 | 只看该作者
    要是中文就好了,英文还得翻译 ,挺麻烦
    GMT+8, 2025-11-6 01:58 , Processed in 0.140625 second(s), 26 queries , Gzip On.
