TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
本帖最后由 Heaven_1 于 2023-2-27 17:03 编辑 w# o* R4 B- F0 {# y9 y1 f
$ V+ N# S' i4 r+ U$ [
FEATURES
8 p+ H, Z/ w% y8 `+ L, P■ Three-channel PMU:Buck,Boost
+ p# q7 t6 B" T; q3 Z5 hand
0 S# o+ I7 I( B/ O' t( uSuper
+ m1 `9 ]' k( b' O" ~/ Lcapacitor charger+ l5 N+ N1 O# R" e
■ o4 C" D, R. Z7 _/ N, C
wide working range: 5V-40V1 K- a2 X2 T6 N' K+ N# p! r
■ 3.3V 450mA Output Power for Buck
W# ^* K2 E; G■6 [% Y6 O# g# Q6 D k7 W4 o" r
12V 500mA Output Power for Boost at 2.7V* ]0 a9 n% M5 P& H: o6 v& R1 @8 B
Input
9 q; z/ T+ |# h0 { v■' O6 ]9 Z' H: c+ y! a0 q
1% accuracy for Charger CV voltage and up1 R9 x( U d2 B( u
to 150mA constant charge current9 P3 T; k$ S0 Q% i! }+ g1 _
■& h* j0 g5 |- o3 v4 s% h
High Efficiency PFM mode at light load for
1 d0 w% u2 `2 G9 U7 s% ~7 s. @. [4 ]Buck
& S0 h- Y4 c+ {7 v; A) r■ Enable pin to auto-switch boost and charger% ~" L; M7 M/ g! F6 g4 h. D
■' g' c* l& Y; U$ b `9 M+ V
Available in ES0P8 and QFN3x4-24 Package0 h7 m! x9 _3 F9 H- G. _ q
APPLICATIONS
5 y1 n/ X1 n% Z& w5 {6 I [■ PLC modules
0 {9 H' E5 ]; Y4 F■ Power Meters
7 [) e5 b, f3 V■ Any system that needs super capacitor as a, J0 U- z, Q! K3 Y- }
backup power
X; {: f: s" u9 GDESCRIPTION
, g$ @/ Z4 i/ I) b4 Q. PZCC4200 is a three-channel PMU that includes a" o# A& _6 R% E5 n2 |% F
40V input, a high efficiency synchronous buck
) T' Y/ {; o8 ^$ o mconverter, a low startup, high efficiency 18V
7 }( [& l1 [, |- `2 r1 ^boost converter and a super capacitor Charger.
1 f4 I2 n% u5 \& OThe buck converter withstands input voltage up
C& ?9 Q; b; V ~) o2 F+ R# e. J7 Rto 40V and delivers a 3.3V output with up to 450mA. {$ q+ Y* N4 O9 d
current. The boost converter is capable of
4 z, @& q+ ?- a7 H4 K1 c% Yproviding up to 500mA to 12V output from a single
) C% S- c# E/ A) x. w5 v6 g: `cell super capacitor or a battery at 2.7V. A
: u2 W. d( N/ X4 f" Y9 \* }linear supercapacitor charge is also integrated with a very high accuracy CV voltage.8 r, `* @5 p- ?
The output voltage of boost can be adjusted by: [4 e6 v( ]4 |7 N* S% a: W3 W
external resistor divider. All three power
: B$ E H+ T' j2 I$ qmodules are packed into a single ES0P8 and
( U5 R4 R# x, H& c1 j$ C0 iQFN3x4-24 package,beating the discrete: L( @4 @7 B- [
solution in features, peRFormance, size, PCB
% H( @& o2 z. ^. i6 M. klayout and cost
+ T4 D" e& O9 l' D" o9 f |
