TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
5 S' K% q7 R% f2 P* d) n/ y5 |& ]% N r; O+ P
Features
% s% o1 d$ i! _5 x$ {7 J4 U! x J; P2 S/ S 9V to 100V input voltage range+ y7 {" Y4 w: d3 k1 p# x/ a
1.5A current limit
Y$ M" |, m; w) A/ b) y- Q5 G 1A continuous load current* h4 ^) d2 z" m8 f5 V' y, a
95% Peak Efficiency
) L. N6 R; @( B* V1 ~/ {6 l 400μA operating quiescent current% |; r* ?' Q- L2 Q1 n2 n% j
120V 400-mΩ high-side MOSFET$ i) F1 R( i$ S8 h3 `; J
Peak Current mode control K9 t& J3 Z" d' r' k' g8 U7 S" \, ~* k4 t
150 kHz Fixed Frequency
4 R8 f3 I% u* |2 b2 Y Internal compensation for ease of use
7 g3 M4 x8 ~+ w8 v; w Up to 92% duty cycle
y; h" U0 p( e/ x 0.8V voltage reference' N) ?3 _0 G0 B1 i$ E. z1 B
1μA shutdown current r6 i& H7 F) j' Q
150ms Hiccup mode short circuit protection' r; U& A4 U" @) j% n
Function; A# A0 M8 S4 E/ }3 \! D8 R9 ^
Thermal shutdown Function
& r* Z4 P) Q7 C* n D ESOP-8 package. d' g9 {) M: b- m0 O# u' { r# K$ t
Applications1 m, e9 E0 k2 d Z/ A
Charger in vehicle
$ p9 t& p, g8 S. N4 E2 P Battery Chargers
7 w+ q3 e8 W E' X9 l ? Power adapter
& |( ]) J) Z/ _' ]/ f% n" V/ c% ETypical Application
7 p) I% Z$ ] j' }Description ~; X9 _' A6 z8 z7 ?: h, h7 c0 {
The ZCC1001E is a high voltage, non-synchronous' S$ ?4 h! f/ U. G
step-down converter operates over a wide range
, U8 E; W. h; F7 {input voltage 9V to 100V. The ZCC1001E3 n5 }. Q4 g! s G
integrates a 120-V 400-mΩ high-side MOSFET.
5 K* o" U2 w4 [1 F) u( P- |3 \The ZCC1001E delivers 1A continuous load1 y3 S) p' V7 ]8 z; ~6 Q, a
current with up to 95% efficiency. The ZCC1001E$ a3 d D+ j3 \5 K
operates with fixed frequency peak current control2 x% G. q5 _0 q9 R; S+ s/ Z
with built-in compensation eliminates the need for% T5 M- Y S9 r& r w
external components.
" o8 X& I/ V: O! m9 f" |Cycle-by-cycle current limit in high-side MOSFET
Z* T2 l5 B; K5 @; h0 Hprotects the converter in an overload condition.
- a3 L3 t$ c5 s) x+ nHiccup mode protection is triggered if the over0 H% D' \1 O' q/ M5 H
current condition has persisted for longer than the I- F6 D4 ^7 m% \7 G ^! V/ r
present time.
6 M4 o0 r9 q0 ?2 f) o9 F& j4 LThe ZCC1001E exhibits protection features that* l0 V0 ^3 l6 e. q' \- b# G! X* x
protect the load from faults like under-voltage,. K, M0 p/ M; J3 W5 v. ^7 V
over-current and over-temperature.
- I) R+ B# x+ y% w3 q( RThe ZCC1001E is available in an ESOP-8 package.$ p1 b' U2 z6 k
