SYM_NAME | COMP_DEVICE_TYPE | REFDES |
1PTP25S | TP_TP_1PTP25S_.025"DIA._TP-SM25 | TP301;TP302;TP303 |
2P0201R_POLV1_RF | IND_POL_V1_HIND_POL_V1_2PIN_2_1 | L2 |
2P0201R_POLV1_RF | IND_POL_V1_HIND_POL_V1_2PIN_2_4 | L8 |
2P0201R_POLV1_RF | IND_POL_V1_HIND_POL_V1_2PIN_2P0 | L9;L10;L11;L403;L404 |
2P0201R_POLV1_RF | IND_POL_V1_HIND_POL_V1_2PIN_2_2 | L401;L402 |
2P0201R_POLV1_RF | IND_POL_V1_HIND_POL_V1_2PIN_2_3 | L405;L602;L603;L604;L605 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_0.5PF_105 | C37;C48;C405;C408;C413;C414;C415;C416 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_10PF_105- | C38;C39;C44;C56 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_2.2PF_1_1 | C64;C74;C81 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_0.1UF_105 | C65;C66;C67;C304;C305;C601;C602;C603;C604;C605;C606;C607;
% j7 C I. o0 ]: q7 w' D7 MC608;C609;C610;C611;C612;C613;C614;C615;C616;C617;C618;C622;
5 c) z0 X2 r4 w/ vC624;C626;C627;C628;C629;C632;C638 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_1.3PF_105 | C77 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_DNI_105-3 | C80 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_NO LOAD_1 | C306;C307;C419;C641 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_1.8PF_105 | C401;C418 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_1000PF_10 | C402 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_2.2PF_105 | C403;C404;C406;C407 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_0.2PF_105 | C409;C410;C411;C412 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_NO LOAD_2 | C417;C636;C637 |
2P0201R_RF | CAP_HCAP_2PIN_2P0201R_NL_105-35 | C630 |
2P0201R_RF | RESISTOR_HRES_2PIN_2P0201R_0_10 | R15;R16;R23;R24;R306;R307;R312;R313;R401;R602;R603;R604;R607;R608;R609;R611;R612 |
2P0201R_RF | RESISTOR_HRES_2PIN_2P0201R_3.3K | R19 |
2P0201R_RF | RESISTOR_HRES_2PIN_2P0201R_DNI_ | R31;R32 |
2P0201R_RF | RESISTOR_HRES_2PIN_2P0201R_10K_ | R301;R302;R303;R304;R305;R309 |
2P0201R_RF | RESISTOR_HRES_2PIN_2P0201R_3.09 | R308 |
2P0201R_RF | RESISTOR_HRES_2PIN_2P0201R_NO L | R310;R314 |
2P0402R | CAP_HCAP_2PIN_2P0402R_2.2UF_105 | C68;C69;C70 |
2P0402R | CAP_HCAP_2PIN_2P0402R_0.1UF_105 | C301 |
2P0402R | CAP_HCAP_2PIN_2P0402R_NO LOAD_1 | C619 |
2P0402R | CAP_HCAP_2PIN_2P0402R_10UF_105- | C631 |
2P0402R | RESISTOR_HRES_2PIN_2P0402R_0_10 | R27;R28;R29;R601;R610;R613;R614 |
2P0603R | CAP_HCAP_2PIN_2P0603R_22UF_105- | C302;C620 |
2P0603R | CAP_HCAP_2PIN_2P0603R_4.7UF_105 | C303;C621;C623;C625;C633;C634;C639;C640 |
2PSM106X87RV1 | IND_MAG_HIND_MAG2PIN_2PSM106X87 | L601 |
3SCOXSV4 | COAX_2GS_COAX_2GS_3SCOXSV4_COAX | J2 |
4PSM67X39R | FILTER_BP_2G_4PIN_4PSM67X39R_53 | FL401 |
4PSM130X102N | CRYSTAL_4PIN_2G_V1_4PSM_4PSM130 | Y301 |
9PSM83X122N197V2 | EEPROM_9PIN_1P1G1SLG_V1_9PIN_9P | U302 |
17PSM120X120N197V1 | FEMWLAN17PIN1NC5G1SLGV2_17PINV1 | U2 |
52PEDGS315 | CONN_PCIE_MINI_1_1_52P_52PIN_52 | J301 |
69PSM319X319N157V1 | PROTO_QCA9887_69PIN_69PSM319X31 | U301 |
HOLE-150R102-2 | HOLE_4_HOLE-150R102-2_HOLE | X1 |
SHIELD-Y7970-T | SHIELD 2PIN_2_SHIELD-Y7970-T_SH | SH1 |
