不太懂,IBIS仿真,请问这个问题是不是modelcheck的版本问题
- t; z7 v m+ Y' X, Y3 R7 T6 C$ e+ \& K; T
* ~' I- m7 k2 y. k. ~, t===================================================& }6 ~; V: s) R6 u: T$ V! l
Results of the most recent parse:
9 q- R2 Z: c E- ?. ?$ PIBISCHK4 V4.1.1
" j$ R3 \7 x) H1 G! d
9 G, l7 a1 K( W$ k; X9 e2 m* O) g0 B2 Y8 Z$ s
, b+ `: s- C8 a8 K: \Checking D:\Ca\directory\GM8182_CORE\i_k4t1gxx4qf_bcxx1p0.ibs for IBIS 4.1 Compatibility...% g9 o; r6 P1 g$ r
5 e4 E0 [) d+ |9 `1 c: \
) B' _, @( F5 [5 F- ~
- q" H( d4 P) S* p/ GERROR (line 5) - Illegal IBIS_Version '4.2'.) W! u4 P5 F+ `# f; a( T
6 ~ k0 x. ]% O' @/ K7 m
ERROR (line 6) - File_name string 'i_k4t1gxx4qf_bcxx1p0.ibs' is too long, truncating to 12 characters.6 H# ]8 g+ x2 `8 j" T5 b
0 q9 T* t+ [' H7 C
ERROR (line 6) - File_name 'i_k4t1gxx4qf' must contain one period.
$ D' P: P3 z( P( \% d
' d4 F( S# c* B0 x* X( pERROR (line 6) - File name opened 'i_k4t1gxx4qf_bcxx1p0.ibs' not the same as File_name 'i_k4t1gxx4qf'.
) t: ?* N! `+ L* a) F" r9 R8 u! e4 J* g
ERROR (line 301) - Invalid Keyword: Model_Selector& B9 G4 H. d4 b* [; w" _
, ~" k5 `8 e: OERROR (line 303) - Data for unknown keyword.8 ^/ z+ Z9 s! F8 g+ q. g
2 Z2 |. I: f' b* R8 a" Y& kDQ_FULL_ODT_OFF "Full-strength I/O driver (ODT OFF)"
: C1 V1 B- z: [1 {9 h2 X8 w# G! v3 _4 P* W" x
ERROR (line 304) - Data for unknown keyword.8 G: f: V- \" d+ K" t# A
! y) Y$ Y9 }# ?* w- NDQ_HALF_ODT_OFF "Half-strength I/O driver (ODT OFF)"3 O3 h. e; l* a8 A" V/ k
/ u, Q3 p p. A& z6 eERROR (line 305) -
5 L m8 D# p# h0 `- j* Y, Q* r' O
& z. s; o, L8 I Data for unknown keyword.( @% |: v- K% o D7 z" R8 S
& w) v0 J }! J! W3 Y
DQ_ODT_50 "I/O driver (ODT 50ohm)"/ y8 f) }+ T# ^* e' I, c
1 ?& z1 |, N8 w2 fERROR (line 306) -
: j7 A/ }* v1 d9 {, @1 \. f# m8 b5 ^# n5 W( }* ?* Q* G6 ^
Data for unknown keyword.$ V& `6 U. \5 r8 M8 m0 b
0 g6 s/ V) C6 I4 x% ~+ q
DQ_ODT_75 "I/O driver (ODT 75ohm)"
( O5 h1 O( \$ F- k x
. d8 ?. E0 z: ~% K$ ~ERROR (line 307) -
5 O- Y2 W. C, ^$ s0 m6 V! k7 G) i& ]6 Y; J, F! L, O) d
* ~# K1 c3 W) V) Q6 ?: J4 @3 n" A! F& I; ?" _1 R/ d6 J+ S
DQ_ODT_150 "I/O driver (ODT 150ohm)"
1 ^0 P2 ~9 g: L; \% l& U: m; [: ~8 }) K6 b4 I O5 \" V2 x
ERROR (line 309) - Invalid Keyword: Model_Selector- K9 C# ], h9 p" u) Q, n
% p% r* f+ O j9 v
ERROR (line 311) - Data for unknown keyword.( \2 R: q _$ a+ b g" s
! b. s/ A* c9 m5 g' w& X/ ]; S# xDM_ODT_OFF "ODT e OFF"
3 |7 l, v* P6 E' Q! }- {& k- f; r9 Q8 A
ERROR (line 312) - Data for unknown keyword.
& I- p1 T. v& @0 g+ j8 B
: B0 K+ |/ k: J6 e1 aDM_ODT_50 "ODT 50ohm"
$ z. o9 t3 d+ w0 C- x, M
V2 m7 h! c1 a/ _ s2 rERROR (line 313) - Data for unknown keyword.
- j2 T. A3 @3 L0 y0 r3 Z
: L6 o! g4 X! \/ rDM_ODT_75 "ODT 75ohm"! i9 U1 g- H0 a+ P d5 P
- G3 I5 @5 X' _& s: r9 ^; ~ERROR (line 314) - Data for unknown keyword.
' R; A# x: s* D6 N ~" h7 |8 s( D9 i t/ Y. P
DM_ODT_150 "ODT 150ohm"
9 ?2 j! J9 i! r7 U# l5 d, d5 u' Z3 Q0 u0 E2 U
WARNING (line 354) - Pulldown Maximum data is non-monotonic5 n7 j5 I+ q; h6 P8 g3 ^: \
' {# Q5 P3 i' I6 @7 S Q6 c
WARNING (line 355) - Pulldown Typical data is non-monotonic
3 l# o1 H V. g* P) l: G# |% }
+ _& n$ [2 G$ uWARNING (line 357) - Pulldown Minimum data is non-monotonic
; K3 `8 @& Y2 ~ H6 t$ P" U
" P% |9 P) n3 O4 F, pWARNING (line 458) - Pullup Maximum data is non-monotonic0 O) `& |5 H5 k1 E* @
) W% H3 I+ N2 Y% E( ?0 L
WARNING (line 459) - Pullup Typical data is non-monotonic+ W& g9 ~7 i* a
3 Z, ^( \4 i3 WWARNING (line 462) - Pullup Minimum data is non-monotonic
7 ?/ x1 r. F# g1 t- n, Y5 Y# d$ x6 [/ ]6 S. H- E
WARNING (line 2870) - Pulldown Maximum data is non-monotonic6 Y: Y9 K1 W, a$ j9 j
3 _) t9 l: k3 N
WARNING (line 2871) - Pulldown Typical data is non-monotonic
% U9 T' h- P( @+ D4 N
- w! X7 ] R/ ?3 ?! E- zWARNING (line 2873) - Pulldown Minimum data is non-monotonic
3 X% L7 L, o% s0 P: Y7 j3 c3 R7 w! k! E& z4 u
WARNING (line 2976) - Pullup Maximum data is non-monotonic
; T; {" }% F1 F2 L: z+ z2 g/ }, N/ i( V$ \. ]$ s/ _; `+ I" k
WARNING (line 2977) - Pullup Typical data is non-monotonic: a3 q" L: i" |9 Y
: z# ]/ e9 }, N
WARNING (line 2979) - Pullup Minimum data is non-monotonic
+ m3 X, R* W6 c% `* b. I E* V7 U( C. }6 D; g& Y/ P+ J" m* d, [
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'A8' not defined.
1 J6 b- r! M$ I/ E
[! C, W0 L! eERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'B1' not defined.
N: i+ G$ A3 ?1 x8 e" i5 j/ J8 W1 i) G/ M% E
ERROR - Component 'K4T1G164QF': Model 'DM_PIN' for Pin 'B3' not defined.
- @! c$ _: U$ o6 Z1 q5 [5 p4 m9 k" I" q0 x% n
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'B7' not defined. D% C' u5 g" O$ {
8 t$ W$ P5 N( s D1 a8 _* Y# o+ w
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'B9' not defined.+ W a/ g k4 f* H* Z6 u
( _* l! W6 F7 \5 a
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'C2' not defined.4 a# h: F6 k9 C X* \/ _
" @ }; M9 E: ?2 o6 PERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'C8' not defined.* M. b: }0 L3 y e
/ y. ]% F& S$ G$ g: m Z) m/ c
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'D1' not defined.. Y: z7 A1 b7 a3 p2 T: t) n" J. ~) B
; g& r! G9 u% a
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'D3' not defined.) c! L# r5 U' m$ U2 @
; y2 O$ s0 J' G3 f: Y' {4 ]ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'D7' not defined.6 L& j# n; y: Z
E8 h1 e) D6 U. g/ h2 lERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'D9' not defined.
9 @6 d7 s0 d- j! N
, `3 H2 F" F; I3 eERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'E8' not defined.
6 x* J. p% F2 T+ V
9 s& m6 P- e* }5 @2 g3 \# wERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'F1' not defined.
3 a9 N9 V- l' x5 M
7 C& A0 d/ Y/ y9 QERROR - Component 'K4T1G164QF': Model 'DM_PIN' for Pin 'F3' not defined.
: F* _1 |7 v8 t5 h( @- N: x9 U4 h- V, o/ P$ D
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'F7' not defined.5 M [4 p" R& k; y( T4 }
p/ V( C; i/ j: d _0 o ~8 H4 _2 _
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'F9' not defined. I0 n9 b0 o9 O6 I
. ~4 P& D9 {9 R7 I) p
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'G2' not defined.
: V7 N, N0 V# {! [+ G" z, b- ?, p7 J! e/ B! T, ^, ^
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'G8' not defined.! ~( Z1 t: C1 v0 s& v0 D& h
9 A, Q, N6 O, d8 A, b# Z; n
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'H1' not defined.+ D. O7 H# K2 R! z
' `' s0 K; O& y! x# Q: @: m2 q
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'H3' not defined.6 ?( X# c5 U" K; r; ^ Z5 ~
$ x8 k; X: h2 x" J1 q$ j
ERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'H7' not defined.4 x7 J; t$ @) }: n
3 R" E5 G: r+ t- y2 pERROR - Component 'K4T1G164QF': Model 'DQ_PIN' for Pin 'H9' not defined.+ p6 i$ w7 y4 m5 Q
2 o$ p$ C! Q/ B1 T- ?9 jERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'A8' not defined.
- Y n5 `7 B9 S6 J
6 a" v' c2 S% r h/ f" gERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'B1' not defined.4 g9 ]! K+ k* \$ X: |
! ]: j0 q- P5 }3 ]ERROR - Component 'K4T1G084QF': Model 'DM_PIN' for Pin 'B3' not defined.7 J5 f0 H/ ^9 S( j
4 S' _- X9 } K$ O" W/ |7 i% Q0 yERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'B7' not defined.
, A9 D, O- e& ~+ }6 {$ G7 |
# h& _; B' l4 U5 K( k! ~ERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'B9' not defined.* k5 m, J8 `' m
( P/ f% R; C: m0 C2 W
ERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'C2' not defined.
: H$ ?3 E' X7 e; K3 `8 A! T9 a- T% b- n9 R' W
ERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'C8' not defined.
0 L# z/ {6 F* O: o; _2 a1 N' d# L8 g0 h3 s. q/ A
ERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'D1' not defined.6 z# v" N. ]2 ^6 |& j9 A. ^
% Y5 Q9 f( O0 m) O+ q
ERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'D3' not defined.
3 _& _' J" P5 {3 ~3 a2 O' Y3 f% D% i+ H) m6 f& \$ m
ERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'D7' not defined.+ I6 [1 R. u" y* X/ t) a0 s
; ~. N4 p! [5 {$ h# X
ERROR - Component 'K4T1G084QF': Model 'DQ_PIN' for Pin 'D9' not defined.
3 _( o0 ]2 B" u \2 i3 m
3 D: H B/ a2 Y: ]7 BERROR - Component 'K4T1G044QF': Model 'DQ_PIN' for Pin 'A8' not defined.7 F6 m, Y* I9 {- v% p8 S
# b4 I4 A8 O8 ]# R1 n$ JERROR - Component 'K4T1G044QF': Model 'DM_PIN' for Pin 'B3' not defined.
% R$ R2 @9 s' s+ i' u M" N, i& r& \" w
5 u* w# \% l/ FERROR - Component 'K4T1G044QF': Model 'DQ_PIN' for Pin 'B7' not defined.
" _! {, ?$ X0 w; S3 y2 P, T
3 L }9 o: X; ? o/ T n$ S9 D7 \ERROR - Component 'K4T1G044QF': Model 'DQ_PIN' for Pin 'C2' not defined.
1 u6 T1 p8 P2 O# `) F
3 X" H" \( H7 TERROR - Component 'K4T1G044QF': Model 'DQ_PIN' for Pin 'C8' not defined.
6 C$ i1 V$ B" W; p& |- ^
: ~, R7 ~5 w3 Y5 l7 C6 S, ]" R) O1 S) EERROR - Component 'K4T1G044QF': Model 'DQ_PIN' for Pin 'D3' not defined.' W0 c5 [# q8 f( O% ~
7 t3 H1 m* x/ n) {ERROR - Component 'K4T1G044QF': Model 'DQ_PIN' for Pin 'D7' not defined.+ l; Z6 B$ v, b' a: W; x; S% W- e
4 T/ l( Q6 d9 u$ Y7 i8 CWARNING - Model DM_ODT_150 not referenced in any [Pin], [Model Selector], [Driver Schedule] or [Series Pin Mapping] sections." I3 O+ J& V; a
: C; k! j3 J$ A. O
No more warnings will be generated for un-referenced models
& I9 G# X% [* a! \+ g& b
7 Q! H6 _6 f, n! c/ D9 Y7 r3 K. j# Y$ }
v2 J7 H. k5 Q5 {
Errors : 553 \8 K) U8 I8 F( m1 B/ L0 v
( O. R; ?9 K. X1 ?. E9 z8 i* yWarnings: 13
/ e- h% w% ? V. i# l
* k* W0 v9 F- D2 m% V9 D" m; b
1 k" T. M: f% j5 [% Z' c
# A; ^8 k0 T6 @8 O/ v4 ~. ^; tFile Failed |
