TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
M1 w& I2 ^; R* U; G; ?
1 j- n k# U8 o+ zFEATURES$ T. e# `9 z# D7 W4 Q% c
■ Three-channel PMU:Buck,Boost
" a! F$ @) }' h9 sand
) {' R! W* `% p5 ASuper( }4 n( o, k; A. F3 |4 M
capacitor charger# i5 K4 D C" j3 ^% l9 g
■: N! G8 y0 K- _: e
wide working range: 5V-40V
" c* F9 r! T6 V& b■ 3.3V 450mA Output Power for Buck
7 b- a# M( J4 _■
6 H2 ]" F0 u/ U12V 500mA Output Power for Boost at 2.7V
. |& g" R/ t% P& ]9 XInput1 ^9 _4 a( `3 G9 ?7 D
5 k: `$ B8 e x+ k1 |1% accuracy for Charger CV voltage and up
, b) A+ j! }& L8 Z n0 T/ b6 Mto 150mA constant charge current( o$ x1 H+ g, q' _1 Q! k6 F
■) Y5 x+ v2 Y* j3 h% {
High Efficiency PFM mode at light load for
4 h( ]3 w' |$ k; U4 iBuck$ y/ R$ v1 B" e8 a6 t6 c
■ Enable pin to auto-switch boost and charger
& L) D- E6 r, ~# r) S$ E! m, E■0 w# x4 ^8 P q0 t6 C
Available in ES0P8 and QFN3x4-24 Package2 A# |( K3 o& v' Z
APPLICATIONS
5 p8 \! O% W- N% _' C9 y6 w■ PLC modules
+ b# _% L+ K, Q! U■ Power Meters/ Z( l- i% B; o6 [0 U8 g
■ Any system that needs super capacitor as a1 l% e G6 G9 b2 I, o5 c h6 f
backup power
- X" `: w- L, {/ i; a UDESCRIPTION
1 U3 {/ |- |" L0 a; t6 c' a& D' Y9 Y) n( zZCC4200 is a three-channel PMU that includes a7 `- w% A2 B2 [. F8 J
40V input, a high efficiency synchronous buck- S9 t, Z# H" F9 b6 L
converter, a low startup, high efficiency 18V( k& s5 i" h& ~4 Z$ S
boost converter and a super capacitor Charger.
* i/ G) I1 e6 x- }# a* ]* q8 A& q7 aThe buck converter withstands input voltage up+ W0 ~. J- T" w! M# \2 `, r
to 40V and delivers a 3.3V output with up to 450mA
$ W' f4 J' w/ \current. The boost converter is capable of
9 m: Z9 A: v; Sproviding up to 500mA to 12V output from a single4 \7 @7 j" V" C6 i. B- B; w
cell super capacitor or a battery at 2.7V. A0 q" q# y5 {7 b$ z. m: x* B
linear supercapacitor charge is also integrated with a very high accuracy CV voltage.% c: M% Q& F* Y8 z8 j" ~* @. D
The output voltage of boost can be adjusted by4 r6 F; g" G: p( n1 P5 b
external resistor divider. All three power5 Z1 W7 \/ j3 Q1 h' {9 m( l; Z& l2 v
modules are packed into a single ES0P8 and
$ d& A0 b& e( P/ C5 _, x- gQFN3x4-24 package,beating the discrete
$ t' i: y" m0 S# a: A3 usolution in features, peRFormance, size, PCB4 q; M4 C" t6 {8 r0 j
layout and cost
" o2 }; W+ F* b; Y/ l' p( H |
