查看: 256|回复: 1
ZCC4200三通道PMU 带线性充电器的Buck和Boost变换器替代ETA9073
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-12-29 17:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    * w, d8 Z6 r  D, b
    1 T' F( \& S# wFEATURES
    6 ]" U) c7 B% d( ], F# _0 j■ Three-channel PMU:Buck,Boost
    # z+ C# Q! {$ R6 r" G" q4 y7 p& F0 Dand' D+ H5 I. y# W4 n
    Super
    - C& m% S& r. w3 wcapacitor charger% q) l3 h4 \) @" ]8 [1 F& M; Y: a
    ! ], b% B- @& O+ t; L- p9 Z. twide working range: 5V-40V
    ' p  r+ I# C: h■ 3.3V 450mA Output Power for Buck
    7 c. u5 A1 O0 S" J% p- m
    ( a. ?1 C  m7 r4 Y12V 500mA Output Power for Boost at 2.7V
    2 `3 ]$ ?) Z/ }3 h" |0 eInput
    3 y$ g& V" n2 C
    6 l$ H( h( X) _: p  R! d% N! w1% accuracy for Charger CV voltage and up( a* D, u) A1 u0 a
    to 150mA constant charge current0 \; @- j1 S& w. @9 S. P
    ) R' V' N/ H- }6 }3 b
    High Efficiency PFM mode at light load for
    9 J- N$ Y& A# lBuck
    # `$ v$ R* s9 b/ [& T■ Enable pin to auto-switch boost and charger+ o: a/ z' h+ v
    9 L& ~3 X( P$ R* C$ R' L; N: X1 {Available in ES0P8 and QFN3x4-24 Package
    . v8 x! n# {* m* k- X0 z/ ZAPPLICATIONS
    3 H0 K$ G* ~* t$ j( B5 X( V% U■ PLC modules* J, P9 E( O9 g4 @
    ■ Power Meters7 \; H3 Q0 B5 ?
    ■ Any system that needs super capacitor as a, O3 C$ t* t4 A# j/ m6 k
    backup power# Q8 e* t2 N$ B0 y# {. G
    DESCRIPTION8 R7 G4 x9 }/ H' c0 R
    ZCC4200 is a three-channel PMU that includes a8 P/ x: A) F. S+ A# H
    40V input, a high efficiency synchronous buck& a9 ]# Y, s# h$ ~' m& u
    converter, a low startup, high efficiency 18V
    : c& g5 e( c! u( T0 Vboost converter and a super capacitor Charger.
    / H& {! a" L% h7 ]; p2 XThe buck converter withstands input voltage up- c; C2 x) j/ v) s% b) y
    to 40V and delivers a 3.3V output with up to 450mA
    * W' C4 I1 e9 ^current. The boost converter is capable of
    . t  z+ b  |* @! B+ \' h* eproviding up to 500mA to 12V output from a single
    / H' c& ?. G8 h1 hcell super capacitor or a battery at 2.7V. A
    / |  E& o  @5 Alinear supercapacitor charge is also integrated with a very high accuracy CV voltage.
    ! d: f# \9 H/ v0 V; [% }* k% n: U" b' SThe output voltage of boost can be adjusted by" k- A" q* O7 s" @) L3 w- E
    external resistor divider. All three power
      y& S0 W1 \  b4 Rmodules are packed into a single ES0P8 and- g" k0 I% x! b; s9 S( b9 j% D. x
    QFN3x4-24 package,beating the discrete
    $ n- w2 b% b1 l7 V: ~2 E7 psolution in features, peRFormance, size, PCB
    ! W0 _# o- B7 }1 P0 F% ], [layout and cost2 l9 r& D. z& U( ~6 h- U
    2022-1-29 15:04
    发表于 2022-12-30 10:53 | 只看该作者
    ZCC4200是一个三通道PMU,包括40V输入,高效同步降压转换器,低启动,高效率18V升压转换器和超级电容器充电器。
    GMT+8, 2025-10-11 10:03 , Processed in 0.140625 second(s), 23 queries , Gzip On.
