( G" ?; `9 V n$ C7 ?% U b; N# W/ W- ]# }
Bypassing is the reduction of high frequency current flow in a high impedance path by shunting that path with a bypass, usually a capacitor (in this case, Cbyp). Bypassing is used to reduce the noise current on power supply lines.( N f/ m; y. I9 A! W# `6 w* a
' [/ S+ J( N/ N9 l9 p% Q4 |4 S% B- O( MDecoupling is the isolation of two circuits on a common line. The decoupling network is usually a low pass filter and the isolation is rarely equal in both directions. Decoupling" @: B' k' D; @% e- I
is used to prevent transmission of noise from one circuit to another. In the figure a bypass capacitor, Cbyp, is shown along with the decoupling circuit, Ldec and Cdec. This is because in practice bypassing is always used when decoupling.
3 x0 G% M$ w+ Q4 l' Y$ \. ? f+ S) C, I6 d/ z0 @
Most circuits require bypassing, not decoupling. Using decoupling techniques to accomplish bypassing will give disappointing, if not disastrous, results. Complete understanding of both concepts is vital. We begin with bypassing.
# i( n$ a B4 {* `! r9 C" t" a9 I$ b! X9 `% x
7 [$ b8 }, [: `, n/ W
4 G/ q& B+ ^( U9 J
