查看: 292|回复: 1
WALLYS/dr6018 vs dr6018s/ipq6018/ipq6010/ipq6000/ind...
发表于 2022-12-8 10:38 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
& P( x+ p  |8 X9 {0 x. ^; L8 T3 W: }" s' T/ x
dr6018 vs dr6018s/ipq6018/ipq6010/ipq6000/SFP/ OpenWRT 2x2 2.4G&5G industrial wifi6 moudle
6 g# N, D" j% p7 f
Next we will introduce our DR6018 and DR6018S. This board is similar in many hardware. Let me give you a brief introduction to their differences“
1. Ethernet Ports: DR6018 has 1 x 1Gbps Ethernet Ports&OE3 x 1Gbps Ethernet Ports and 1 x 2.5Gbps Ethernet Port. DR6018S has 1 x 1Gbps Ethernet Ports&OE 1x 1Gbps Ethernet Ports
2. DimensionR6018 is 185mm x 116mm,DR6018S is 125mm x 105mm x 20mm
Common point:
. v. T/ H  }: I; K* }6 B  K( |
their chips are IPQ6018/IPQ6010/IPQ6000. In addition, their boards have 2 * 2 2.4G and 5G. My colleagues also support Openwrt and our QCN9074 network card.
. f! p$ A2 B: b5 l9 O7 b' B
The following recommended wireless intelligent WIFI6 routing scheme based on Qualcomm IPQ6018
Since the release of the WIFI6 specification, the launch of new products in the mobile market has regarded it as a standard configuration, and routers are also facing the demand for product upgrading. When consumers buy new products, they have decided whether to support WIFI6 or not How to choose an appropriate platform from many chip solutions as the focus of future R&D has become the primary task of many R&D personnel
Today, we will introduce a weight scheme of Qualcomm platform for your reference
As a mid tier product of Qualcomm WIFI, IPQ6018 is suitable for covering high-end household products and enterprise level routers. It has strong peRFormance, flexible and rich software function configuration, and can be freely combined to form a differentiated series of products. It reserves the ability to upgrade WIFI6E
The following is a detailed introduction to the scheme process
Hardware schematic diagram
# v2 w' f; W, E( Z; @" Y
1. DR6018
QCN9074 WiFi 6E Card OpenWRT, IPQ6010,802.11ax,
- v3 O" S( m/ o3 m( d+ L: O5 [6 J$ B
2x2 2.4G&5G 2.5Gbps Ethernet Port Support OpenWRT SupportUECTEL RM500Q-GL&Support:
* Y% v2 d  A, Z! b3 N
Symbol
Parameter
CPU
Qualcomm-Atheros IPQ6010
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V power supply
LED header
FFC/FPC Connector
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Bluetooth
optional
Nor Flash
8-32MB(normally is 8MB)
Nand Flash
256MB
DDR
1GB
Dimension
185mm x 116mm
1 y1 e' k+ U$ i- W' U: U
2. DR6018S
QCN9074 WiFi Card IPQ6010,IPQ6018 802.11ax
, Q4 {0 T. |1 J$ J1 \# h
Support OpenWRT 2x2 2.4G&5G
Hardware Specifications
/ A1 t8 ^, _# m8 a0 ]
Symbol
Parameter
CPU
Qualcomm-AtherosIPQ6010
CPU Frequency
System Memory
Ethernet Port
1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot
1x SD Card Slot(Option)
USB /header
1x USB 3.0 Port(Option)
POE
DC Jack
24V~48V power supply
LED header
2.0 pitch pin header
Serial Port
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
4 x MMCX Connectors
Nor Flash
8MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension
/ m" C5 ?6 z1 D- Z. g
This is Tina from Wallys, we are a Mfg of networking devices like cellular routers, NICs, CPE/AP, antennas etc
Our current products portfolio are based on Qualcomm and Mediatek platforms
Hardware customization and software integration is our speciality, OEM/ODM turnkey solution, aslo, we can work with you under JDM mode to develop new products together
By sending this text, i am seeking an potential business opportunity with you
If you are interested or looking for any networking hardwares, feel free to share me your detailed requirements, i can do a proposal accordingly
Thanks for your prompt attention and looking forward to your favorable feedback
Sincerely,,,
+ g9 B! n$ I$ J. c/ ^# l. c- T  X& j, g& r' `/ x( c4 W
( s3 R; }. [) e* j% U. x
发表于 2022-12-8 14:26 | 只看该作者
高通的什么芯片,怎么那么宽的电压!
GMT+8, 2025-10-11 17:14 , Processed in 0.140625 second(s), 23 queries , Gzip On.
