刚学定时器,还不是太明白,定时器延时时间太长动态数码管就不显示了,老师不让用延时函数,我就不会做了。定时器怎么工作我倒是知道,但是具体怎么用我不懂,网上查了好多,也没搞清楚。2 o! o! B( K O8 c1 q$ K; l' \
#include
* {- R$ K6 t$ a! B; l* V#define uchar unsigned char5 ~8 s. Q& c7 t) s0 q, r% G
#define uint unsigned int7 J8 b d- K0 a% n
uint i;
8 u$ f/ I: g! G6 I8 R) g
6 }5 H) V! Z3 G' J0 A* {) Nchar ctime=0;
3 D5 @9 K! C. | G3 |: I2 J: x- Buchar code led[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};" ]4 a! [+ K) T/ i. g" ~
/* void delayms(uint ms) //延时函数,延时一段时间' `, ^4 Z P) K; I+ \! q7 @9 I4 Z
$ A7 [3 X: X$ P, H% c7 S1 R1 _ uint j;
2 m: A9 w9 |8 {* C: q while(ms--)
, w# x# u6 ~. N" q9 ?7 x- w Z {for(j=0;j<120;j++);9 A) A6 n2 [+ h) {' Y; v! M' U& k
( o( B2 [! @; y } */
/ K& N, n& C+ t. R$ q# G2 Lvoid main(); u7 T( a6 O' F% ~+ z$ i
& E0 W3 ]4 _6 r" w& z; ` TMOD=0X01; //设定定时器为工作方式1: q. b+ k) D8 @1 G3 n
TH0=(65536-45872)/256; //装初值,11.0592 MHZ晶振定时50MS,计数值为45872
i' g5 T. t$ H$ z" M8 w TL0=(65536-45872)%256;
+ V0 }; s% a5 W8 y EA=1; //打开总中断 G! R( }, ^5 F3 ?
ET0=1; //打开定时器中断; B; |! ]- @. L( l4 p0 }9 b
TR0=1; //启动定时器0; {8 C j: u j( v% P
P2=0xff;( s1 X8 r9 a+ w$ h) b0 A
while(1)
S$ H+ l8 o0 Q2 d {! a8 A$ I3 E& b$ ^0 {
/* P0=led[ctime/10];' {+ v" q. X% E% S. ]6 a$ k1 z
P2=led[ctime%10];
3 y6 |3 ?) a- R */
- [4 M; ~+ M& M: ~8 }. R P2=0xfb; //P2.0引脚输出低电平,DS0点亮
$ Q" Q9 R# ^0 S0 R5 ] P0=led[ctime/10%10]; //数字1的段码& Y# V( j! [5 g' q
// delayms(10);& t- e ` `8 ]# l+ A* c
7 |( I4 g; q: n; [6 L2 A P2=0xf7; //P2.1引脚输出低电平,DS1点亮" f/ ?0 `! s# D( ?+ H
P0=led[ctime%10]; //数字2的段码/ y5 r: k5 e+ D0 |
// delayms(10); z' {& B0 w+ T; [4 b7 W
}( v+ g: f: ^9 m" b
! x# F( i( t# Z8 L- D; g' x9 z* v+ |3 y9 M% @! c
0 v' m c4 a4 W# E! W void time() interrupt 1 //定时器0中断服务程序
6 f, g7 M# n6 c: a{) v) @: ]! J- d& `
TH0=(65536-45872)/256; //重装初值, {1 ~; l( {0 M5 p, M
+ `7 q9 T3 t. v. @$ R3 l r+ N i++;; A, Y4 w3 h5 X. L# q
if(i==20) //如果i=20,说明1s时间到* J& u- O9 t9 ~' x! n" o& B
+ i9 I# n( A4 b: q4 W3 D i=0;8 X2 ]4 O: f' F/ C/ f
" {: o9 f2 Q) _% ~9 O0 f% d5 { ctime++;
! O5 u( }+ }' d- O& D4 g) p1 O if(ctime>99)
9 r5 r3 @" L4 @, j# l. a" ] {
$ G( ?' M/ h( H$ t! p ctime=0;
" W; ~8 I: V& X) d4 {. V/ S. Z }
# b, o' i7 [( Y: L8 q } 4 d3 j; x: ]8 u' p! G$ f
) V0 [1 ^+ X' Y0 m4 I |
