查看: 231|回复: 1
ZCC5160-同步降压芯片60V /3A V2.0(1)
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-12-1 17:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    本帖最后由 Heaven_1 于 2022-12-1 17:28 编辑 $ F8 y# r2 b0 N# N
    , [% D  S+ T. w. zFeatures
    " x/ @8 ]( m) |; y2 V+ u3 _( `3 `, `3 U- C1 {3 f' l
    20-μA Quiescent current in regulation
    & [# q$ k, l; H# K7 b: n9 a) u( M, E* H9 u1 d* o9 h
    Input voltage range: 4V-60V
    7 `. K; N; Y: _* _5 W# _& L$ G* i% t6 P
    + w, l  W" P/ Y& G3 i- |Output voltage range: 1V-VIN
    2 k% @, s8 n; L: S3 y
    ) K$ \6 ]) w& E( [+ C1 L9 d7 A0 gIntegrated upper and lower power MOSFET
    ' S* w1 s3 G; V5 smaximum current: 5A0 f$ H  h# b& m+ D& _# J+ U
    : `# e; U* k+ M# Y. w+ c
    Adjustable frequency range: 200KHz~2MHz
    6 _. l6 I! n. S7 ^
    4 Y( P; N, _4 E9 `2 r. @Automatic switching of CCM/DCM/PFM mode
    / {3 F3 O% O* h( ^$ H, @
    & E1 Z8 ?- j3 s3 GAdjustable soft-start time and Output voltage
    " Z9 L! }/ w' z2 Q, J3 ttracking capability( V2 E* X! i9 u& u  V
    $ a& A% i# _' T( m( V7 W
    Automatically switched bypass linear power% z$ x. ~- D1 P) L1 r' e
    supply
    6 G" n3 i* A9 }
    / z- t& \: y; I, [& ?6 ~Provides ultra-low input and output dropout
    5 @4 B9 k* [7 k  }7 \( ^/ [5 Mvoltage close to 100% duty cycle0 `, ~3 f4 ]# O& i% k6 G
    5 A2 N7 [* E* u: G& EInternal Compensation
    # d3 x  d- V+ ~" z- y% [& F
    $ d) O# D' c4 g0 QPower-good flag$ H) K/ a; V. l, e
    3 B' e  w- i- v9 w0 i2 w  _. K- ^Dynamic Frequency Stretch Technology
    . S% j' L# H% o
    : r. ~' E. ^5 W# z: d( M) hSupport large capacitive load start-up
    . i- C7 z7 ^+ p; p0 T& i+ M/ j# \  v3 n8 \" t
    Protection function: UVLO/OCP/SCP/OTP/OVP; t7 j. M3 w/ ]* Q& {/ l
      q6 b1 d" V3 s' N% BOperating junction temperature range: -40℃ to
    7 e6 d2 I4 I% q7 w- j+125℃
    ) e7 q" w" @+ ?% ?- \, w' ~# V; {+ a6 k
    All pins have ±2000V (HBM) ESD protection0 r8 c9 G; h; k+ n) l3 H
    6 G  D* G! ]7 `! b* JETSSOP 16-Pin Exposed Pad Package
    5 M$ G  u* a* d; I+ |Applications2 p. B  ?' V. e; [; l: f- i
    & o! u* ?3 v5 h6 A5 dIndustrial power supply
    7 L( N" }& Y: C' e' C
    & m, a, `: g& N* E7 HWide voltage input range power supply( T2 G& B) K5 m, }( @! D) c) X
    3 }) q( }( v# q
    Low ripple low noise power supply, R! S  i( C- o9 H, Z
    ' @$ `2 F, R( ~; J- C: G8 z! Z
    Automotive electronic power supply
    ; t0 h+ d6 o2 M" r7 w+ vDescription0 t8 H- {: P' f8 A$ n" L
    ZCC5160 is a step-down DC/DC regulator with an4 n% O# d5 P4 D0 t4 G1 j3 P$ @
    internal switch, featuring SKIP control mode, which
    " d1 W. {! o( u9 ]combines low quiescent current with high switching
    ; b. s/ t0 a4 F* Y: r( {frequency to achieve high-efficiency regulation over a
    2 [; [. W1 `1 G2 c+ H/ ewide range of load currents. SKIP mode uses a short
    $ J' X% |& U% `- O5 r! {- g* n"burst" cycle to switch the inductor current through
    , |3 V& F; @7 y5 ?9 ]the internal power MOSFET, followed by a sleep
    ) A. k. `9 S" D# L1 `7 Wcycle in which the power switch is turned off and the; V( n: {: d- o$ L
    load current is provided by the output capacitor. At0 h. J. a! O# w$ O$ k  Y2 @
    light loads, burst cycles are a small fraction of the
    5 G5 J8 v. h# c! wtotal cycle time, minimizing average supply current
    , L, ^* D/ S% r4 L" E2 zand greatly improving efficiency at light loads.9 x# a9 v! ]- N
    ZCC5160 has a wide input voltage range of 4V-60V,
    9 Q1 K' ^* _0 `8 I1 Pthus minimizing the need for external surge
    / h* c3 d3 G2 R; I0 Q- Bsuppression components. Making it the best choice
    ( B0 N; N; P) X2 E  Qfor wide input power range industrial and high cell
    ; F. p4 k5 P6 {# L+ W/ icount battery pack applications. ZCC5160 is ideal for
    2 o3 ?# j6 M0 ^use in the 48V automotive power bus range.
    / d1 n" t& [0 OZCC5160 features low-value 100mΩ high-side and1 m, _( r, a) I4 v; S" F
    80mΩ low-side MOSFET that provide at least 3A
    ; G' z/ Y3 D/ P4 q; J; Toutput current capability with excellent load and line! k2 u6 B$ @; Z8 |
    transient response.) t5 q7 H- E. R' F; }4 |
    Additional features include: soft-start, thermal+ V0 F- `6 }5 |$ T$ B
    shutdown, UVLO undervoltage lockout, gate driver
    - x& ]! D6 J! m7 z' T1 C7 Wundervoltage lockout, maximum duty cycle limit timer,
    + n: ?& C0 ^5 P; q" S% pand current limit shutdown timer. It also integrates( }/ Q5 f$ [( L$ m' ~9 w: f
    output short-circuit protection, providing HICCUP
    4 P! K( U4 r4 o3 U1 ?5 Bmode when the FB voltage is low to avoid9 ^& n1 g8 w0 z2 }+ @' r3 O% M
    overheating during short-circuit.
    发表于 2022-12-1 18:44 | 只看该作者
    串联线性稳压电路主要思路来自于基本线性调整模型。在输入直流电压和负载之间串入一个三极管,其作用就是当输出阻抗发生变化引起输出电压同步变化时,通过某种反馈形式使三极管的发射极也随之变化,从而调整输出电压值,以保持输出电压基本稳定。
    GMT+8, 2025-10-11 16:31 , Processed in 0.140625 second(s), 23 queries , Gzip On.
