TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
; d: U2 P+ O, j1 W9 A
- }+ e( g( l g& ~Features1 r. R& Q" d5 S( f4 ?
9V to 100V input voltage range3 O' C' H# P+ {9 a: q7 {4 {
1.5A current limit
: I# m- G2 ~% m" B2 @: c 1A continuous load current- D" x% a5 K+ O# F0 U+ g
95% Peak Efficiency
3 _% `+ p8 s. j# Y: _# w 400μA operating quiescent current
; `5 |/ e5 ^3 Y! |" s 120V 400-mΩ high-side MOSFET
\4 N) e4 h6 x- W Peak Current mode control
6 y' a" c4 `+ \ 150 kHz Fixed Frequency
( M; Y; s: `& B9 }& a Internal compensation for ease of use
5 E. ~/ C4 u# t Up to 92% duty cycle
' p) ?7 H/ O, S' S$ i, g7 j% P 0.8V voltage reference
9 ?9 [1 v& N/ f4 \$ v 1μA shutdown current
2 e, w" V0 Q+ |7 Q 150ms Hiccup mode short circuit protection$ ^ Z1 T2 N) S3 f$ p* c
Function0 [2 F; D; Z0 x! k' V5 J
Thermal shutdown Function
* f: b; w$ E' o* B4 p& Q ESOP-8 package
) S; q& U ?* R; ?8 J6 _Applications$ @8 j! |1 w5 @+ t9 u' o. V1 W
Charger in vehicle
& e$ H& ]/ L' j: Z/ X Battery Chargers( w+ m$ D/ ]* n, c8 M- W. l0 _
Power adapter
" Y: ^5 e( a, F1 ^! B+ y CDescription
1 a) F: a& I1 v. _; i- i% F& h$ BThe ZCC1001E is a high voltage, non-synchronous- \) m7 r" a4 ^) E7 t: k
step-down converter operates over a wide range6 [% Z& U3 N; _; s. y8 m# a
input voltage 9V to 100V. The ZCC1001E
# q* V; q* m/ Bintegrates a 120-V 400-mΩ high-side MOSFET.
% M" S, X y4 ]$ _0 QThe ZCC1001E delivers 1A continuous load
/ H( m+ j) L7 C% fcurrent with up to 95% efficiency. The ZCC1001E7 a0 z' m6 B* |. E; e
operates with fixed frequency peak current control6 o, O# P& N. ~( c& t/ O! w+ J
with built-in compensation eliminates the need for
" s! \. s* D. x3 X& y2 T; oexternal components.
9 i! @6 r$ C( D0 Q! T8 w) G0 CCycle-by-cycle current limit in high-side MOSFET
6 D4 S) F5 t- M0 y! @* j% Uprotects the converter in an overload condition.
" U/ A) X5 e% s, G9 `% O" uHiccup mode protection is triggered if the over4 d5 _6 n# u, j' v; _# s
current condition has persisted for longer than the
% S8 k0 B: P' M: v6 N# s1 a' K" V$ wpresent time.
7 `9 W2 z6 z: G; t8 \1 u. y5 v' ?0 jThe ZCC1001E exhibits protection features that/ v$ G. `& d. ^ X) ~
protect the load from faults like under-voltage,9 z$ J8 g4 G; G9 ^
over-current and over-temperature.
+ `* t% p8 z2 C1 hThe ZCC1001E is available in an ESOP-8 package.+ j h: X2 i/ t
