查看: 254|回复: 1
3节锂电池同步升压充电芯片带NTC-ZCC6983
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-11-17 17:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    , c- b6 n# j( R' b9 ^1 p* h* \9 N
    " t: x* j0 H* T# l1 \特性
    $ V# J* q6 C( k" o■ 3.0V to 9V Operating Input Voltage
    ' f7 Y: c9 @. ^* }& T8 d■ Up to 26V Sustainable Voltage) G* R" r9 X5 R3 ?$ C5 g
    ■ Up to 1A Configurable Charge Current for Battery, B2 U+ C* Q, O/ l
    with 3 Cells in Series8 E2 Q, N! k! q" l  L
    ■ Configurable Input Voltage Limit  L" ^2 @2 I2 Q4 ^1 }1 L6 }
    ■ Charge Status Indication& B! }8 q& A# ~4 ^* k
    ■ Constant Voltage Selectable
    ' x6 `# `! B7 @1 q: T■ Programmable Charge Timeout
    " \% Z5 `: W. u  g5 q■ Thermal Regulation Protection. N- E5 `' P9 B0 H' ^
    ■ External Shutdown Function
    1 W) ~. b. S4 @) @■ Input Voltage UVLO and OVP
    # I/ B$ M( V# M; o, W■ Over Temperature Protection( d4 y% O8 C) s4 j
    ■ Output Short Cir cuit Protec tion Normal
    4 W5 B$ r- V# `% mSynchronous Boost Operation When Battery- `# \; n1 h; X  U) V% d
    Removed/ `  v7 d! s- t( m1 Q( {/ u1 C
    应用; U3 Y/ P4 e+ l7 A8 t5 G7 j
    ■ Power Bank9 V. `. \- ?( v& o" W; w
    ■ Cellular Telephones,MP3Players,MP4 Players
    2 H0 q2 G/ J7 o) l' V( u■ PSP Game Players,NDS game Players5 ?5 }$ L. r: f" U0 z5 }9 ]
    ■ Notebook( z. u/ z0 S% K4 G7 v7 H  g+ k
    描述$ P( i$ C% P8 B  A' r$ K; ]1 f* `+ u  g
    ZCC6983 is a highly integrated synchronous boost4 c9 h$ F6 E7 `4 n6 y
    charger IC for Lithium-ion batteries with four cells in$ P& c: p/ H* U, ^. @
    series . The charge current up to 2A can be
    + \' ~9 C9 A7 _+ r( E$ |0 ]. ~: ]4 Yprogrammed by using the external resistor for different
    ; w/ Q$ T6 M7 E& f/ t: _portable applications.
    ! p- q0 R, e  V5 v6 VRobust protections include input over-voltage
    ) h7 `1 b" O( w: [7 A5 bprotection (OVP), battery OVP, battery short protection,* ]2 z" s) {, G9 G
    thermal shut down, battery temperature monitor, a6 H# U3 v% t7 I' ^" s, u  n! R5 ^0 W
    configurable timer to prevent prolonged charging of a1 F6 \9 d1 w5 v
    dead battery.
    + l* p( M3 m& }
    发表于 2022-11-17 17:48 | 只看该作者
    输入电容尽量靠近芯片的 VIN 端使芯片的输入端,减小输入纹波,CIN,COUT 选择贴片电容
    GMT+8, 2025-10-11 20:23 , Processed in 0.140625 second(s), 23 queries , Gzip On.
