TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
1 Features" @" s; H8 x Q1 }
Multiple Device Access (MDA):# b$ f! J0 E- r8 S; O5 x( v
Global Read/Write Operations
) a& L- I3 @# l$ hI2C™ and SMBus™-Compatible InteRFace$ c7 }1 ^2 K5 @. I, o. _8 }
Resolution: 8 Bits
! X6 v, c- ?. Q8 |; v" o. z; c$ _3 Description$ A( q& l* a* i% k% F {1 g! `' i
The ZCC103 is a digital output temperature sensor in" I4 W1 { h8 C |5 `) j6 S
a four-ball wafer chip-scale package (WCSP). The
G6 C8 y9 S" V' j |# dZCC103 is capable of reading temperatures to a
+ R- s' P3 R% mresolution of 1°C.
* E; d) V, F; ?/ _& g2 f" g8 ZThe ZCC103 features a two-wire interface that is
+ W6 x8 V0 H9 m6 {$ f+ a. |2 K7 s( Wcompatible with both I2C and SMBus interfaces. In
& s' |! z! L/ j) `5 Zaddition, the interface supports multiple device
; E0 P C& H! O: ]: M% L0 `" a$ f# Zaccess (MDA) commands that allow the master to* T- Q% L- @3 S. }! {: i7 |
communicate with multiple devices on the bus& o* A2 n3 R! f9 B5 |
simultaneously, eliminating the need to send
4 `# C, `7 a9 D/ Zindividual commands to each ZCC103 on the bus.9 I! _. Q; P2 _5 d! q$ k
Up to eight ZCC103s can be tied together in parallel
& X3 M( a9 [9 j9 iand easily read by the host. The ZCC103 is
7 d- o p% E, W+ ?! w& t; a1 Yespecially suitable for space-constrained, power-
) h$ t9 b6 G; m% ^sensitive applications with multiple temperature
4 r/ \' E$ ~4 }! {measurement zones that must be monitored.. E" W' d5 x* c, U! K9 y
The ZCC103 is specified for operation over a
, G$ C: o3 b# I8 I2 t& itemperature range of –40°C to 125°C! V7 T$ V% K( ]) A% }3 h0 B
.Device Information(1)
1 \% Y8 E0 I6 G1 A; y' L5 S6 yAccuracy: ±1°C Typical (–10°C to 100°C): M+ q' `. Y1 C# d
Low Quiescent Current:
: a" i; O4 [1 u# i4 E" W( ~3-μAActiveIQ at0.25Hz
3 c" Z- N$ b: b% o }4 B6 O! `1-μA Shutdown
0 o$ G7 d* O. Z; f* X6 c+ _Supply Range: 1.4 V to 3.6 V
) r0 E! g/ t- U5 X( s& X4 d, ]Digital Output% s( o) i, v8 u( y# \
