查看: 394|回复: 3
51单片机的74HC164驱动六位数码管动态显示程序
发表于 2022-11-16 10:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
8 ^; r3 \4 z  m6 E! q#include<intrins.h>
  X; j& N$ G9 [
' F' @* y2 e! O" S3 q, K" k8 l#define uchar unsigned char) g, W. h( ]( U2 G$ ~
#define uint unsigned int
8 I8 r7 I7 Q- S4 Q//74HC164
& u2 O( \3 r0 X& L7 {0 vsbit CLK=P1^0;        // μíμ&ccedil;&AElig;&frac12;μ&frac12;&cedil;&szlig;μ&ccedil;&AElig;&frac12;±&szlig;&Ntilde;&Oslash;′¥·¢
- S) j) t  }7 f- r' Usbit MOSI=P1^1;         //         êy&frac34;Yê&auml;è&euml;* V! v" ^* `7 V$ S
- P* V  X$ [1 Z$ R7 F8 _
unsigned char code Tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,$ m/ N5 N" J  y1 _
                          0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};        //12ò&otilde;êy&Acirc;&euml;1ü
% B  h0 F# g3 Z" {/ \* n0 ~unsigned char DS_data[6];
5 Y5 ]! |4 i7 |% z5 x0 _% i. ^8 O/*****************************************************
; J& r9 n/ c# D$ S$ b1 eoˉêy1|&Auml;ü:êy&Acirc;&euml;1üé¨&Atilde;è&Ntilde;óê±×óoˉêy
! d6 O8 Q. c: R* T. D4 c, yoˉêy1|&Auml;ü:&Ntilde;óê±1ms
/ e  C  j4 ~2 B# Q
% v9 L9 U1 A' V4 l$ X***************************************************/
' u& b/ `7 h0 n, N  yvoid delay1ms()" v2 \. g' s: |# V4 y
* i' c+ O. a5 X5 P4 }   unsigned char i,j;
9 V( c; a! `, @% |         for(i=0;i<10;i++)1 n& u$ |- z8 [; G- L8 A
          for(j=0;j<33;j++)% j9 q  H- M& H+ O
& G% |0 p' {$ j}
, A* v8 F( f; ^% \" Z7 |. }2 jvoid separateData(unsigned long dat)         // dat&Icirc;a6&Icirc;&raquo;êy
7 D1 ~2 `1 K4 ?* N{
) B* S1 Y: L! o7 A, {2 ~   DS_data[0]=dat%10;0 D4 M, \0 @% C
   DS_data[1]=dat/10%10;( g) N8 |$ i0 A6 ^/ Y
   DS_data[2]=dat/100%10;
( N1 c' _& f! M. P   DS_data[3]=dat/1000%10;
1 D' y" T1 D' F. {" A! {1 M   DS_data[4]=dat/10000%10;# c% O" C* S0 Z* N" v
   DS_data[5]=dat/100000%10;& p9 x; V. n5 R% P; E, \0 G
- s6 G* J) v, h& F( {$ ?) d& Vvoid write_164(unsigned char dat)
3 ]6 H6 \6 ^9 V  y3 t5 I{7 F# ]1 {: x8 h! L' l/ S/ Y
   unsigned char i;
' m  Q7 {6 o* J3 c. F( g   for(i=0;i<8;i++)
+ d6 n1 X! @% d" D1 k   {
1 B# {- k( W. G- H$ I     CLK=0;             9 X0 U9 X) R- I, L3 f
     if(dat&0x80)  MOSI=1;4 b4 Y1 x* m$ n& S$ c
     else          MOSI=0;) h. _& p( F; |' k+ W) V7 S
     CLK=1;               # B/ \! `0 V7 P2 C7 z# X
     dat<<=1;
3 B0 Z( ^! G5 A5 }; V. L/ u  }$ w$ B% ^) F3 {9 F' u, M
- v. A, v" n+ P/ n$ T& ?7 w9 p' j: ]( }' Y9 z
void display()
8 f0 y, G; v# }{
6 m; b6 J  q; t+ M6 B  P   unsigned char i;  G/ F. }' D$ R2 g$ B
   for(i=0;i<6;i++)) S! w  P2 j  q: d. X( [7 S
9 f% q$ @3 C) j- r7 R                        write_164(Tab[DS_data]);. j6 C' B/ r  y
                        P2=0x3f&(~(0x01<<i));     //êy&Acirc;&euml;1ü&Icirc;&raquo; 12ò&otilde;μíμ&ccedil;&AElig;&frac12;&Ntilde;&iexcl;&Ouml;Dseg1&para;&Ocirc;ó|P2.5 seg6&para;&Ocirc;ó|P2.0' i7 Y( r9 @9 ?+ q
                        delay1ms();
" {$ @' v1 }+ F3 D                        P2=0xff;        //êy&Acirc;&euml;1ü&Atilde;e
8 \4 N+ f: f6 r* W6 T0 x   }0 e6 N  B6 i( f4 U* I" J  W; D8 x; m
8 d5 w  i/ N; m9 J! A$ u}
2 a, \9 d( I2 z/ R$ ]/ P$ d* }7 _( Y( w& i/ D- Z+ {" X  m0 U* y, o
main()
2 p' y) g" C1 u1 m2 R/ C{
; C) @, H( a& a1 ~7 z5 d- Z' C   separateData(654321);1 Y" u, Y8 B4 l- ]2 H/ X1 r
   while(1) % ~4 y( |5 ?2 f- V
5 L. p& }* R0 ^2 r4 d# e     display();" @4 C- y4 g$ u  S" u- L
' _7 ?5 |/ H2 B7 Z* {$ q}
; Q& F% P8 L8 i  p) a, G: l
4 m& c* b; t; |& E5 \1 @5 n#include<reg52.h>1 K* W0 w, B  [1 f
#include<intrins.h>: m' H; s/ ^* e/ x3 t. X
7 ?( l; n& Z: {: Z
#define uchar unsigned char3 F/ O6 z) e; _% a! b7 K% Q
! b3 u% `, H9 k//74HC164# g4 d" c/ M  n% W0 p! U; Q
sbit CLK=P1^0;        // 低电平到高电平边沿触发9 X* R7 |8 C- A
sbit MOSI=P1^1;         //         数据输入
% k: h4 e, l4 \1 C" c
0 W) d3 ^, Y/ Punsigned char code Tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,6 O9 U; M) {' B- I  Q
                          0x7F,0x6F,0x77,0x7C,0x39,0x5E,0x79,0x71};        //共阴数码管
% o( S1 j, l% \5 a& I0 ]unsigned char DS_data[6];
7 ?7 [8 y3 ^2 o( {) |6 Z7 y% h/*****************************************************
& c5 \: @# J5 v+ u: n函数功能:数码管扫描延时子函数# L  C' r: v* p3 O! _4 _
函数功能:延时1ms0 E% Z6 ~/ s8 X; Y
# Q  [$ t: e- d8 L
***************************************************/8 m; @: i6 f4 p0 F/ }
void delay1ms()/ @1 e$ F5 x1 H/ u
{. L3 y& @- `2 M# _
   unsigned char i,j;
7 K. F- P* _, T4 B8 G! R5 v" h         for(i=0;i<10;i++)
. C5 d2 e- @8 _' W- y! Q          for(j=0;j<33;j++). I1 Y! b  ?% i. N4 U' G
# h& N6 J( L/ n1 N}, ?8 C! `5 C1 l+ @: P. \4 I, f7 s/ S
void separateData(unsigned long dat)         // dat为6位数
, y  m4 |1 q9 J! I. J: w2 G{
* c; {  c5 Z- |& m" q   DS_data[0]=dat%10;7 f1 m  I5 E8 V7 \- X5 V; _+ f
4 |6 ^8 @. {; c6 F1 J   DS_data[2]=dat/100%10;
" W' G) S# d* h- L# N& F   DS_data[3]=dat/1000%10;; n4 N# |& _% r3 w
) Q, m3 f( N& u1 C: D) T/ G5 E   DS_data[5]=dat/100000%10;
& }/ t6 A: N; S  j3 v}
% _& A+ U4 {0 evoid write_164(unsigned char dat)
  q3 O3 k, D% I( K! O{
7 D0 h# H9 H( R1 y) W0 ^# |   unsigned char i;; [5 L' O1 I$ U: I1 p( Z9 ^
   for(i=0;i<8;i++)0 P& I% g) ?+ f
& O" a' P) s% b: I$ U     CLK=0;
/ Q- B( ^# ]$ A0 x1 ?3 q     if(dat&0x80)  MOSI=1;0 ?* B9 c/ r. o  w0 a( A6 V
     else          MOSI=0;$ g7 S, n6 g( m8 L
     CLK=1;                 n8 \* [) Z) \6 d  L/ N
     dat<<=1; " j# ^9 T0 h6 O. ?4 q: H
2 V: r8 M6 ]: o( Y}
5 m) O6 K5 d! z- H0 I, Q- Q8 V) g  i2 [2 L0 J, T; _2 Y# o4 |
void display()2 t5 ^0 ~# L( d2 l; S
{' k: i! D5 V, U1 K& J) A2 h
   unsigned char i;
+ f- j% V8 b6 n! K( l* q   for(i=0;i<6;i++)+ R! Q4 R6 S& G8 A6 r
; S% w6 R, ?4 w                        write_164(Tab[DS_data]);
, e4 A" L3 ~6 a$ T5 ?                        P2=0x3f&(~(0x01<<i));     //数码管位 共阴低电平选中seg1对应P2.5 seg6对应P2.0
2 h. }0 [" _6 c  A" q                        delay1ms();
2 {# o% R6 `1 X9 d' C1 w2 p                        P2=0xff;        //数码管灭# G" t4 c5 x& y+ f4 }8 V- [7 }
% `  r  A& B" E4 @) H. ~& _  t# p
% g$ c  T; i; x# `2 |* l}, X  Z  m* @( v* F  f& D
3 ~4 W- [! l# ^3 ^: |main()5 v7 _* N2 j7 y' o: K1 W
{, ]  `, r. H: B: |' v  `5 _6 L
   separateData(654321);) }0 w7 ~; Z" P7 v) f' F, p
   while(1)
6 h7 Q) a- j! k! ?' j3 S* L   {) Y6 K6 E3 \  W" ?9 T6 J) k5 A4 L
     display();( \3 h& `) D! Z) @  T; B4 q
   }" T  u1 V, e* Q& O# h& O2 H- b3 _
}- O- k: s) X/ @3 W; I1 f8 W1 q
( x# e6 y! Q8 V- e, j9 ^% l+ l7 i
拓展并行口电路仿真.zip
76.67 KB, 下载次数: 0, 下载积分: 威望 -5
发表于 2022-11-16 13:16 | 只看该作者
位选控制亮不亮,而段选控制显示数字,利用了人体肉眼观察的能力。$ G# f8 {9 k- A8 H  j5 }, \, l
给人的感受是第一位数码管并没有灭(实际已经灭了),因为时间太短人体肉眼无法识别。这样就会发现数码管动态显示是向左或向右一位一位点亮。
发表于 2022-11-16 13:29 | 只看该作者
高速硅门 CMOS 器件,与低功耗肖特基型 TTL (LSTTL) 器件的引脚兼容。
7 K& ?/ l* U0 L$ v% X* w  m是 8 位边沿触发式移位寄存器,串行输入数据,然后并行输出。数据通过两个输入端(DSA 或 DSB)之一串行输入;任一输入端可以用作高电平使能端,控制另一输入端的数据输入。两个输入端或者连接在一起,或者把不用的输入端接高电平,一定不要悬空。
发表于 2022-11-16 13:45 | 只看该作者
动态显示:动态显示占用CPU时间长,只要不执行显示程序,就立刻停止显示。动态显示使用硬件少,占用 I/O较少。
GMT+8, 2025-10-8 18:52 , Processed in 0.125000 second(s), 26 queries , Gzip On.
