TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
本帖最后由 Heaven_1 于 2022-11-15 18:43 编辑 # U: V/ T) i$ t0 c- ?8 D# l
; b$ g( V9 m. M. {6 Z5 cFeatures K1 }( T5 T4 F0 D
9V to 100V input voltage range
( n& F9 O" {0 T2 t3 r& n" y/ ^4 M 1.5A/5A continuous output current
2 Y* K* ^* T. q0 T: x 95% Peak Efficiency
- _4 P9 a7 I/ U0 ? U 400μA operating quiescent current
4 l" f5 f1 p2 M L/ x) W# R. ? 100V 400-mΩ high-side MOSFET
& T7 V8 c- {' k' G Peak Current mode control. ^& R0 r7 t, r* Z# v6 d
150 kHz Fixed Frequency
5 w/ |7 s# P: ?. G9 d G& s: q Internal compensation for ease of use) z* }! N( Q) _1 m
Up to 92% duty cycle
: c& k) e+ I4 ?8 h) N( Q4 E 0.8V voltage reference
* s* q0 u z% ?/ ]/ Q 1μA shutdown current
2 h# Q: A% V5 d( U! i7 S$ l 3A/6A cycle-by-cycle current limit; k/ |0 g& V. F* H; Y
150ms Hiccup mode short circuit protection$ {8 r% g: A% I& U
Function
/ C' F( P# R4 E, Z' i: b" {8 [ Thermal shutdown Function
% ^4 R9 i+ `1 T) T ESOP-8 package. @3 ]$ J+ V1 p. d: @- [' m' k9 A4 g
Applications0 F; @% e i. F$ Y$ P
Charger in vehicle
4 T3 c% ?$ V S) t7 w9 W Battery Chargers
) h8 u, W. u' e Power adapter
5 q6 N& c- X- G5 D# k: g" y. {Typical Application
. L% @3 H2 }7 u) x7 K; vDescription9 C `4 u% C% ?$ v
The ZCC1005 is a high voltage, non-synchronous# I: ^+ d# _0 m' H* P' h6 c( a
step-down converter operates over a wide range f2 y+ z5 q! p2 h
input voltage
+ ?: W9 L( a' s9 g5 [. n6 |8 g9V to 100V. The ZCC1005
: ]3 d" E' E9 F7 l+ g. y1 Q3 w5 Gintegrates a 100-V 400-mΩ high-side MOSFET.
7 { p! c2 P7 QThe ZCC1005 delivers 1.5A continuous load
) K. U- c& H) z" b4 j# Ycurrent with up to 95% efficiency. The ZCC1005) z f* {& i; H! F5 V7 \
operates with fixed frequency peak current control, G( L: ` F5 H4 }5 ^$ |' V
with built-in compensation eliminates the need for, {3 Y3 k6 O: U$ Q& Y- E0 U; B
external components.6 ~- R8 H" ` E" T, p% S
Cycle-by-cycle current limit in high-side MOSFET
& u7 N# W2 `+ I" A; {% E) Oprotects the converter in an overload condition.8 w) @ P n1 I2 z- e
Hiccup mode protection is triggered if the/ D- r) f. M0 Q* y* Y* S
over-current condition has persisted for longer than
# j7 x/ P! X0 P. h$ N* o" ]the present time.
6 Z' ~. c3 R7 @1 d; c' i1 V6 lThe ZCC1005 exhibits protection features that
! I9 M9 ?- B5 s: {3 R# y2 Cprotect the load from faults like under-voltage,
( ^/ u+ [2 T% k0 Y5 r0 Bover-current and over-temperature., x6 `+ l$ ]* T
The ZCC1005 is available in an ESOP-8 package% S S8 p0 \3 O5 U- v
