查看: 118|回复: 1
100V 输入同步降压最大5A输出电流 ZCC1005
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-11-10 18:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    + l% q- [2 X5 X! [* T$ _  ~5 R# r" U, [6 |0 v+ K
    Features9 x$ a+ }5 B$ k0 K8 x
     9V to 100V input voltage range
    / [* g4 m1 d$ q3 }- p 1.5A/5A continuous output current+ V! E3 |! O# _, @
     95% Peak Efficiency
    + u0 j/ y2 w* w 400μA operating quiescent current8 P& I% O' S1 R) }
     100V 400-mΩ high-side MOSFET+ t4 u9 P  S' F* v1 U
     Peak Current mode control! c) m$ W+ e4 \, [
     150 kHz Fixed Frequency
    7 ^, Z! ?; p; R, I4 J$ I Internal compensation for ease of use
    " P/ N0 f8 v" J- T5 Z Up to 92% duty cycle
    9 T7 y& v' E+ u* [6 U3 e* g3 N 0.8V voltage reference4 O: `0 x( H. s4 S
     1μA shutdown current
    , R# R' F* t5 J; T 3A/6A cycle-by-cycle current limit  `1 X& G4 H8 j
     150ms Hiccup mode short circuit protection
    6 \. s( t) ?$ R2 OFunction  q- e% t5 G3 D  w
     Thermal shutdown Function
    2 W; X6 B9 B$ I, u5 O! H ESOP-8 package
    $ {3 B& W" |  D# l0 U8 Z0 b6 OApplications
    2 U  E; e* Z, x: y Charger in vehicle0 _* d0 X, {# b  \- n- }( @
     Battery Chargers
    5 c1 [# p' k2 H7 M  n Power adapter8 }% ?& r/ E& v9 U/ L" f# j! o
    Typical Application
    6 P; z. c" k- b* t4 MDescription; ?1 m- q, x7 S! ]6 |4 K
    The ZCC1005 is a high voltage, non-synchronous; l3 x1 J, v, [$ p$ A
    step-down converter operates over a wide range
    % N' U! C9 O' d- \input voltage
    $ S! D. t9 e- d5 T/ h. W9V to 100V. The ZCC1005
    / ?0 C% O4 A* \7 R  N% A  Tintegrates a 100-V 400-mΩ high-side MOSFET.& Q) i- Z$ n5 ^$ |0 ~
    The ZCC1005 delivers 1.5A continuous load& y) P. [* e/ v4 O, ^7 y7 ^
    current with up to 95% efficiency. The ZCC1005
    1 Z8 c$ j9 ?- `/ W) hoperates with fixed frequency peak current control
    6 N7 I4 j4 w( i/ ~' _" iwith built-in compensation eliminates the need for; l* T5 S$ S2 \3 }: W5 O
    external components.
    8 D' Q. \1 c/ P2 V6 d5 \) O! j9 I3 }4 ^Cycle-by-cycle current limit in high-side MOSFET
    2 ?( E: V  p' y( ^1 L' Lprotects the converter in an overload condition.) U1 }3 E8 u$ R) E- w
    Hiccup mode protection is triggered if the
    7 j; n: V/ V  J, v9 k; xover-current condition has persisted for longer than
    , b3 l) D9 D4 Q9 L, x) o8 hthe present time.
    $ J# p: t+ F( [! e* r4 ]9 IThe ZCC1005 exhibits protection features that
    ' G6 c: ~( n" |* z. C! w' hprotect the load from faults like under-voltage,6 e3 `; x) q4 U- L) [8 i
    over-current and over-temperature.
    0 ?$ Y8 ~  _$ `4 s) U- bThe ZCC1005 is available in an ESOP-8 package.3 [  m' P2 }$ u. ^6 j2 f, r
    发表于 2022-11-10 18:44 | 只看该作者
    输入电压范围9-100V,很宽了!
    GMT+8, 2025-5-26 09:50 , Processed in 0.093750 second(s), 23 queries , Gzip On.
