TA的每日心情 | 开心 2022-8-5 15:55 |
签到天数: 11 天 [LV.3]偶尔看看II
本帖最后由 Heaven_1 于 2022-11-8 09:42 编辑 % z0 u, I" t& S, o, ^
) X7 k0 Y6 N) F6 q. |4 {0 X, Y
1 Features: X) L2 g5 N) |" r8 Z2 O0 |
Multiple Device Access (MDA):
4 h( J8 Y% M* A7 g% K" PGlobal Read/Write Operations; |* H- C0 {& E, ]1 `! r
I2C™ and SMBus™-Compatible InteRFace" e2 ?) H6 O1 [
Resolution: 8 Bits3 G' E! @. R) \4 Q
3 Description
( J) B7 D4 M+ ]+ @! g& V8 XThe ZCC103 is a digital output temperature sensor in
& E' y2 ?( _! _9 R9 da four-ball wafer chip-scale package (WCSP). The
0 E4 H# J+ Q2 @( @2 KZCC103 is capable of reading temperatures to a
, M/ a; u, v! W5 ~2 f: Aresolution of 1°C.( `/ N) F* D* I* I, X
The ZCC103 features a two-wire interface that is
5 D# D _' C6 h- E5 R$ [compatible with both I2C and SMBus interfaces. In
$ H' ]$ B6 v" n0 Y+ Jaddition, the interface supports multiple device( m1 p0 B1 Z" ~' {9 R
access (MDA) commands that allow the master to
s% ^* ?. ?. B4 C! J& b- Kcommunicate with multiple devices on the bus
6 n, w7 o" ^: x2 D6 a( y3 }& e+ F( jsimultaneously, eliminating the need to send$ A6 ~; F$ m( |7 N$ C* @
individual commands to each ZCC103 on the bus.
" o0 ^, }7 ]" L0 J5 [* K* x8 W& \& IUp to eight ZCC103s can be tied together in parallel0 n, k, s7 ~0 t) d
and easily read by the host. The ZCC103 is( E1 h9 c- z' F. y. ^) i2 M
especially suitable for space-constrained, power-8 E1 r+ Z- j: W6 J& J2 F0 R
sensitive applications with multiple temperature
4 A' u9 @3 I u$ j3 emeasurement zones that must be monitored.' S! R# M) }# V/ v
The ZCC103 is specified for operation over a
2 U, p8 g C; m. c0 P, S9 Ntemperature range of –40°C to 125°C
: w6 X2 v! A( Q6 K5 j.Device Information(1)
5 f7 E" X5 W. C# QAccuracy: ±1°C Typical (–10°C to 100°C)
5 \% i6 V3 {/ g! y+ iLow Quiescent Current:
9 v$ S+ P7 O. y, u7 L6 Y4 T* a# y3-μAActiveIQ at0.25Hz
% ^1 G% U) t& V0 x1-μA Shutdown
$ D% o9 B5 _, @' B) C* qSupply Range: 1.4 V to 3.6 V* x5 W0 l% V0 g4 j7 \
Digital Output
' k2 ?+ P6 T( ~0 j4 L |
