TA的每日心情 | 开心 2024-3-26 15:26 |
签到天数: 11 天 [LV.3]偶尔看看II
Link between PDF schematics and allegro pcb layout
Just copy the text in pdf and then you type command into allegro.The skill will automatically highlight the refdes, net, symbol name, pin number, and return a list file at the working dir.
And more the skill support find xy in your design.
[backcolor=rgba(0, 0, 0, 0.05)]
Skill name: HighlightClipboard.cxt
;Command: ha - Highlight: Refdes, Net, Component pin, symbol name;Command: hc - Highlight Refdes
;Command: hn - Highlight Net
;Command: hx - find xyuse find xy you must add hot key into env file with format
alias hx "findXY; replay Findxy.scr"
1. Run the SSKILL.cmd.
2. Run the GetDriver.bat file for get Drive.
3. Send me this file to get license.
4. Copy the license inside to <HOME>/SSKILL folder.
