EDA365欢迎您登录!您需要 登录 才可以下载或查看,没有帐号?注册  我看到一个verilog驱动LCD1602的程序,代码如下: module LCD1602(                //50Mhz         clk,rst_n,            //input         lcd_en,lcd_rw,lcd_rs,         lcd_data);input clk,rst_n;output lcd_rw;output reg lcd_rs;output wire lcd_en;output reg [7:0] lcd_data;//-------------------------------------assign lcd_rw=1'b0;     //设置高延迟 就不check busy 无需读取状态//--------------input clk 50000,000----------------------//---------------2^16==65536>50000 1ms-------------------//------------------------分频成1ms---------------------reg [15:0] cnt;always@(posedge clk or negedge rst_n)begin    if(!rst_n) cnt<=16'b0;    else if(cnt==50_000) cnt<=16'b0;    else cnt=cnt+1'b1;endreg [3:0] ms;always@(posedge clk or negedge rst_n)begin    if(!rst_n) ms<=1'b0;    else if(cnt==50_000) ms<=ms+1'b1;end//--------------------------------------------------------//初始化以及显示字符  只初始化一次 一直显示一个字符parameter lcd1=4'b0000;parameter lcd2=4'b0001;parameter lcd3=4'b0010;parameter lcd4=4'b0011;parameter lcd5=4'b0100;parameter lcd6=4'b0101;parameter lcd7=4'b0110;parameter lcd8=4'b0111;parameter lcd9=4'b1000; //状态转移reg [2:0] current_state,next_state;always@(posedge clk or negedge rst_n)begin    if(!rst_n) current_state<=0;    //一开始设置的条件是  ms==15 但是时钟是clk 所以状态会一直转移 无法正确驱动lcd    // add cnt==16'h0000   确保状态只转移一次    else if(ms==15 && cnt==16'h0000)           current_state<=next_state; end //判断下一个状态 初始化完了之后一直循环1个状态always@(posedge clk or negedge rst_n)begin    if(!rst_n) next_state<=lcd1;    else     case(current_state)      lcd1:next_state<=lcd2;      lcd2:next_state<=lcd3;      lcd3:next_state<=lcd4;      lcd4:next_state<=lcd5;      lcd5:next_state<=lcd6;      lcd6:next_state<=lcd7;      lcd7:next_state<=lcd8;      lcd8:next_state<=lcd8;                //lcd9:next_state<=lcd9;     endcaseend //根据状态输出相应数据always@(posedge clk or negedge rst_n)begin    if(!rst_n)     begin        lcd_rs=0;    end    else     case(current_state)      lcd1:begin lcd_rs=0; lcd_data=8'h38; end      lcd2:begin lcd_rs=0; lcd_data=8'h08;  end      lcd3:begin lcd_rs=0; lcd_data=8'h01;  end      lcd4:begin lcd_rs=0; lcd_data=8'h06;  end      lcd5:begin lcd_rs=0; lcd_data=8'h0c;  end      lcd6:begin lcd_rs=1; lcd_data="h";  end       //cs      lcd7:begin lcd_rs=1; lcd_data="a";  end       //show      lcd8:begin lcd_rs=1; lcd_data="h";  end       //cs                //lcd9:;       //cs                    //default:;     endcaseend//----------------lcd_en使能1ms---------------------assign lcd_en=current_state==lcd8?1'b0:ms==15?1'b1:1'b0;//assign lcd_en=current_state==lcd8?1'b0:ms==15?(cnt[15]==1?1'b1:1'b0):1'b0;  //以上会多输出一个aendmodule & ^: g0 |# Y. Z4 S+ Q! x
 程序下载进去,按道理讲应该显示"hah",可是显示“haa” 还有这一句: assign lcd_en=current_state==lcd8?1'b0:ms==15?1'b1:1'b0; 这条语句应该怎么理解?我被她绕晕了。谢谢!$ \6 \, B9 t4 ]$ j+ G* l7 i
