查看: 233|回复: 1
耐压100V同步降压最大5A输出电流 ZCC1005
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-10-21 18:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    本帖最后由 Heaven_1 于 2022-10-21 18:24 编辑 ; ^9 w! H: R, |: t) k
    * @2 q. B7 V$ ^  ?
    Features
    8 U' i" p" g* X3 n" o7 r7 _ 9V to 100V input voltage range$ U& g* p( {/ u
     1.5A/5A continuous output current0 l* F2 z7 P' l0 `- {8 e, G( q9 G
     95% Peak Efficiency# X6 S2 D2 j7 h- N  T# ]4 E2 x$ ~
     400μA operating quiescent current0 x, |! W0 c  |0 R
     100V 400-mΩ high-side MOSFET
    , D: o3 D& j+ P6 w, n3 f" n Peak Current mode control+ H5 R( q  r0 v8 B2 [1 V+ ]4 O! p
     150 kHz Fixed Frequency: ]9 O! z; s- C9 ~
     Internal compensation for ease of use
    ; H/ ^0 v4 F9 N+ t3 e Up to 92% duty cycle' C) K9 b( g  k5 J9 t
     0.8V voltage reference
    4 O  o8 S& E" n$ a) y 1μA shutdown current4 D4 x9 b/ O% ?5 p5 F
     3A/6A cycle-by-cycle current limit7 c/ J: Z8 l: X4 y0 e4 u- S
     150ms Hiccup mode short circuit protection! |0 M$ l& [# P# A# I# v% b- N) Y
    Function* Q# Z0 S- L$ Z7 N' u- j9 `4 y, J% x
     Thermal shutdown Function) y2 c, ?7 r" s  Y
     ESOP-8 package
    + `/ F2 }$ [. F, ^, J* GApplications8 m  \' U7 e4 S$ J' r5 ]
     Charger in vehicle  {9 }1 l) i2 l6 @: N# w! x
     Battery Chargers
    ! ?2 z+ V' |* h. n" Q% L) V- @ Power adapter
    & v/ E- N1 h* Z" b5 YTypical Application$ d+ W0 M9 n9 V% v3 ^% O5 O6 L
    Description
    - N2 d2 r. z& A/ u' t+ G4 A' BThe ZCC1005 is a high voltage, non-synchronous
    3 T& l& u7 t! L) m1 ~, ]6 v" rstep-down converter operates over a wide range: V# w$ G2 Y" [* _) i
    input voltage- ?& Y+ [1 f' B# {7 k, R7 N
    9V to 100V. The ZCC1005
    : e8 P9 s0 `3 }9 O9 Y' Qintegrates a 100-V 400-mΩ high-side MOSFET., Q3 Q1 `7 `1 [& j) w6 F% s
    The ZCC1005 delivers 1.5A continuous load
    " K8 Z) x% A. Q9 q% Xcurrent with up to 95% efficiency. The ZCC1005  G2 ]- [  p" e0 g/ T- l" r5 p( g# k; S
    operates with fixed frequency peak current control7 R( }3 g( N9 i* l% E/ T$ H
    with built-in compensation eliminates the need for( V1 @: P7 Q- c* A. D
    external components.7 g- c" N0 A' I/ S* O# z
    Cycle-by-cycle current limit in high-side MOSFET
    % U% `0 W6 v( yprotects the converter in an overload condition.
    . S! A9 H& z, o2 cHiccup mode protection is triggered if the# u" m4 i$ c6 n2 @2 l" I4 |2 y
    over-current condition has persisted for longer than: K- ^* M) b, k9 i
    the present time.
    : R4 G1 d) E' @The ZCC1005 exhibits protection features that
    . u4 }4 R2 M! K3 R; Lprotect the load from faults like under-voltage,. {2 y4 Y: v, O! E. Q. F3 {
    over-current and over-temperature.
    & A9 |2 k* g( jThe ZCC1005 is available in an ESOP-8 package" h7 w& A1 `# i8 @, h
    2022-1-29 15:04
    发表于 2022-10-21 18:26 | 只看该作者
    ZCC1005是一种高压非同步降压转换器,可以提供1.5A连续负载,效率高达95%。
    GMT+8, 2025-10-11 20:42 , Processed in 0.156250 second(s), 23 queries , Gzip On.
