shark4685 发表于 2012-1-13 17:26 ![]()
$ Q5 V8 j! A- j C" s9 i把模型发上来,做个简单的说明!帮你看看! ; Q4 x& q: b o
公司里的东西发布出去我把我写的那部分给你粘上来看看
" k8 `0 A9 X( Q l2 M("macromodel_mipi.dml" ( Y9 v" a7 G. G* H; m2 C
(IbisIOCell
3 z/ _4 [- v% }" O5 ~ (mipi $ S; @0 `6 K: R6 W# t/ o
(MacroModel 5 ~4 {0 u( a8 Q9 {
(MacroType DiffIO )
# [ r1 h6 V7 i. i M0 W' C (NumberOfTerminals 8 ) 6 d$ \4 z! {" d. ?4 F1 ^) e' U
(Language hspice )! d: c" m. x( F, h; ?6 B$ [
(Parameters 1 r& T/ ~( P3 b6 t! L
(Buffers
) {6 s! Z# s, c/ S (BUFF CDSDefaultOutput ) ) )
' E( o4 k& G/ @& [2 N0 ? (SubCircuits "2 E( u9 h$ i: s, m% u8 `- }
.options search='D:\\1810\\Model\\TSMC40LP_DPHY_HS_TX_TB' 0 q0 q2 T! d# R4 l: x- g s) b2 T) a
.subckt MIPI 1 2 3 4 5 6 7 8 BUFF=CDSDefaultOutput
: j9 S/ ]- I9 }& g4 x0 Y xdphyhstx 7 6 3 dn dp 1 4 hstx_sim
9 z( |2 \1 a3 n& K5 L% F" q3 ]$ t) v xpackage 8 2 7 dn dp dphy_package
- q: ]7 u* o) d. H/ O .ends mipi
7 I( Q. r1 t9 d0 J " ) )
: N* U' X7 M+ t( N% R S) [; g (Model 7 v9 G% ` |- u# ], M6 Z6 W
(ModelType Output ) ) 2 v# N$ \. b, V8 P% ]+ F; H
(PullUp ; B! w. w/ M9 [3 e- V
(ReferenceVoltage
/ l! Z' g& t. b5 `# X: e1 m (maximum 1.1 )
- Y1 ]# j( U& k: l8 s (minimum 1.1 ) . d' I3 h8 N3 c) F5 N- L
(typical 1.1 ) ) )
[$ s# v/ n4 y0 b! M8 A (PullDown
/ O* E7 S! W$ O2 U (ReferenceVoltage ; e9 T% [. R9 f& `3 X7 A$ l& U
(maximum 0 ) # O( v2 g) o N/ F
(minimum 0 ) 6 g- k; @# b+ v. q% y$ m# Z3 E8 D
(typical 0 ) ) ) ' @ F9 i7 }. O
(GroundClamp 5 q% j/ N8 @# {
(ReferenceVoltage
# J0 o- r' H8 H7 Y7 i" [ (maximum 0 ) : m& n0 K" E3 ]& R% B
(minimum 0 )
- f; r( P r) O6 O( E (typical 0 ) ) )
, w& R( W8 t+ H. L- H (PowerClamp
; d+ s) N7 J | Z (ReferenceVoltage 7 u2 @' j$ @ |- }$ h
(maximum 2.5 )
2 B3 T* _- p! O8 G (minimum 2.5 )
; y3 [# s% ^, M5 W9 Q8 T5 B5 Y (typical 2.5 ) ) ) 8 H& A2 m# c! p
(Ramp ( J* x8 }9 I5 u! j# t1 G6 i
(Fall " o: V3 [" _, w( |. G6 Q
(maximum
3 U0 Z. @7 B6 a, E; Z6 y0 ]) _ (dt 5e-011 ) ( y9 G X7 V* O3 P3 u
(dV 0.36 ) )
9 G( W3 j. J! j (minimum
# _, j4 v8 C1 ?& q& k (dt 7e-011 )
t; k- A: G k; Y (dV 0.24 ) )
5 Y$ x$ [/ g. }* ]( c (typical
; D0 f* h# n+ }$ O' F (dt 6e-011 ) $ ^/ ^! G8 g7 \2 W9 y* Z+ A" \
(dV 0.3 ) ) ) 1 C( q. ~# q R) b
(Rise 7 {) L% M3 C# l8 M
(maximum
' S1 z% a8 Q+ }/ ^; U- r3 b (dt 5e-011 )
$ M5 `& w" V2 U( P ^ (dV 0.36 ) )
9 i- b9 w# j) y6 F" [ (minimum
! l# D: G$ [) L8 U' n/ Q! O (dt 7e-011 )
. O/ j" o! N, J (dV 0.24 ) )
. d) }# u5 R1 B. H6 R (typical / I5 p$ M5 Z& q' S
(dt 6e-011 )
4 D( t+ ~2 z& o: t' }. m& r1 C (dV 0.3 ) ) ) ) 3 L, O0 b4 A" @
(DelayMeasurementFixture ( [9 K3 Z8 A2 v4 N6 ]% C, \
(V 0 )
; Y) r, ~6 ?& W/ }# }! m (R 500.000000 )
n9 f ?/ v( Q" _. m# a (C 0 ) ) + N3 U- @' I/ A7 j; b6 a
(DifferentialDelayFixture 9 d9 |( \' J$ Z! }! [% ]6 `
(DifferentialFixtureModel DEFAULT_CAPACITOR_1pF_2_1 ) " z4 C9 j+ o }3 B, o. `5 w, n) \
(Threshold
: K3 P. A0 ~5 A (minimum 0 ) # d4 a' h. r. }# A X: E
(typical 0 )
' X5 {) t1 g, L7 X: k) }0 Y" d (maximum 0 ) ) ) ) ) 3 i I- |$ L' K) [! p1 v: T7 Q7 g
(PackagedDevice ( `/ k: {7 X0 M& \, k( a
(mipi_Device ( r( U5 n* f2 `( V; B
(EstimatedPinParasitics
/ W3 l7 `0 H1 r# ]. K (R & ]& n2 G) R5 p$ H% ~- s( d3 W" j
(typical 0.3 )
# _# R) @8 t+ |. v5 Z/ r1 [1 g (minimum 0.3 ) ( t. v, ~$ Y0 S: o
(maximum 0.3 ) )
1 y6 d0 |. h$ z n9 ~5 \ (L ) i) _% o2 R+ y! g* G
(typical 5e-9 ) " o9 A& Y+ l3 A' a0 c
(minimum 5e-9 )
7 i5 x; F+ p) A# z" |. V (maximum 5e-9 ) )
# `0 A4 [6 U9 r% l1 P (C - E0 l5 L0 y- R0 c
(typical 6e-013 )
E! i2 j% e5 p; K% R (minimum 6e-013 ) 4 `9 B5 e" j/ Z" I! e) N; p; j J
(maximum 6e-013 ) ) ) 2 Q/ ~5 \% c0 n0 c1 m: G7 f
(IbisPinMap
7 G B% F4 L) [) p7 s4 `2 W (2 ) `4 @% Z0 @, I$ z s
(signal TXP )
, }' {: [7 v. ]& k (signal_model mipi )
9 P# U, u0 G" y (WireNumber 1 ) ) * Y; r, d6 E# x0 V
(1 2 E* Q) I4 [6 r/ i9 j5 a: V# ^! ?
(signal TXM )
9 Z/ ^- r) o g" t2 ? (signal_model mipi )
7 E6 V [0 h C (WireNumber 1 ) 2 Z1 g* B k3 {2 V, }5 N
(bus pwrbus ) ) )
5 F2 r) u, m3 i (DiffPair
( @0 g! d+ c& W i' e (2 # A2 r& W& r& P9 l9 }
(InversePin 1 )
) `( G) s0 K$ E& O (LogicThresholds 7 u9 K. v- }4 l9 ^ y
(Output
7 P( M; _' L1 w! ^' E9 E* _ (High
+ K- }# M2 Q& m+ |1 K' @ (minimum 0.2 )
* Y: E9 K- b1 q: p$ a (typical 0.2 )
- }, n. P, e$ E V (maximum 0.2 ) ) M( M8 D$ j' G( v8 U
(Low * g: R5 m; V# I0 ~- V
(minimum -0.2 )
* z8 Y7 D; V$ q (typical -0.2 )
) u4 n. Q K0 P/ f3 ~ (maximum -0.2 ) ) ) ) 2 |+ h: ^7 i" {! K$ L1 N
(DifferentialBufferDelay 9 f. f4 @! c+ U& \0 {7 }2 l }1 q
, j8 H7 \- [! r, {+ [ (DifferentialFixtureModel "DEFAULT_CAPACITOR_2.2e+07pF_2_1" ) * ^- |7 Z& o4 s+ Z9 v4 z* l8 P
(Threshold
6 R8 e+ W! Y$ H9 _' Y5 Y$ P+ H4 M (minimum 0V )
e! z' x7 L. Y; y/ R) j3 o5 ] (typical 0V )
/ V D7 |! E0 @ (maximum 0V ) ) ) ) ) ) ) )
+ a( h# t2 h- i+ x6 t+ k (LibraryVersion 136.2 ) ) |
