查看: 75|回复: 1
ZCC5160 同步降压 60V 3A V2.0
    2022-8-5 15:55
  • 签到天数: 11 天
    [LV.3]偶尔看看II
    发表于 2022-9-22 18:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    / p9 R% K! O6 T
    1 i* \. A' M& u1 cFeatures" y9 f4 U0 m% L3 P) Z5 l, p- J# h
    / Z( c; [: B* t3 a  ~8 z, C: i
    20-μA Quiescent current in regulation0 M! [4 H3 V( W! L
    ! y8 u5 G6 m/ D# y% T8 ~
    Input voltage range: 4V-60V
    * q- Y# u1 c% k2 `$ Z( g/ h
    7 c2 t, s/ a( wOutput voltage range: 1V-VIN9 p9 s( Q5 _* c* R- u& Q
    $ o8 @5 Q- a7 x% H4 bIntegrated upper and lower power MOSFET7 O4 a; d5 Q6 w2 k$ S
    maximum current: 5A
    * M/ d( E3 I4 E8 B
    & C$ X# |6 h* y% b0 @& f7 Q% GAdjustable frequency range: 200KHz~2MHz, k5 ^. o5 Y. B; Z
    3 D) P) n5 `% u/ U& y2 GAutomatic switching of CCM/DCM/PFM mode, {- ]/ Y2 M# R  L6 s+ ^
    5 a* Q. g4 h% t  A+ r
    Adjustable soft-start time and Output voltage5 e: n/ ~" f* l, D0 \) B
    tracking capability
    # o5 e7 {& u; \. n; K+ ^. U  ^2 e' R% J* q9 N0 e' ~+ _& U
    Automatically switched bypass linear power: ~* M6 P. ]" `6 Y9 F. H+ n
    supply
    * x5 D9 F4 t2 q2 r+ i& X* O! @& t  |$ W2 b. m8 D
    Provides ultra-low input and output dropout
    ! m, u- S2 \  p, e& @( s5 Uvoltage close to 100% duty cycle
    1 ^  j5 k6 B; c  q- N# N: R, g- {* f# l7 y4 ?& W
    Internal Compensation
    6 I& ?) |6 f6 o7 T) q, D
    6 \/ B( h3 {* h+ W5 fPower-good flag
    9 g, K: g  h/ Z+ e
    7 k( t; ?5 w9 C. U" [Dynamic Frequency Stretch Technology, ~; `' m* I/ _1 ]) m
    % o+ j' z! Q0 p  l; vSupport large capacitive load start-up% K3 o+ _# p4 d: K( z. P# y8 k9 f4 f
    # v8 o& ?0 K; X. t' m) e! s
    Protection function: UVLO/OCP/SCP/OTP/OVP
    ( x/ R" p- n0 v! |" H( S
    4 d0 R7 M0 t5 @2 M* Z+ yOperating junction temperature range: -40℃ to3 K/ u0 X8 _2 ]$ T6 s0 M- b9 Q
    +125℃3 X: a' D( y7 l& q
    9 t+ [% S8 H  _1 W. H: d7 \All pins have ±2000V (HBM) ESD protection
    - B" W% F( ?" w% L
    2 i7 z1 s- g; v- `& [& AETSSOP 16-Pin Exposed Pad Package
    * Q; ^7 F7 I% f/ b  y6 Z, R1 p" WApplications
    8 p# _9 w4 {- P1 C7 t" e3 Y  T2 O! b
    3 _' @# d+ x+ J( F- m2 _Industrial power supply
    - O: w( |2 m* V) \! w* K0 L! @  g
    9 V: \' a( x! F! xWide voltage input range power supply
    * D( j! e: ~1 X
    & O! P7 ?! F! E0 R, F- LLow ripple low noise power supply. ~( W! U; e  ?6 t' v, }2 h0 H
    : Q. [% r9 f% {9 Y6 H7 L9 O& W6 e
    Automotive electronic power supply
    2 x+ O% N% V* lFigure. 1 Typical Application Circuit2 T6 }5 ~$ `* w: I" z% `  o
    Description
    ( t4 Y9 n. t3 M+ `4 {0 ~3 V9 YZCC5160 is a step-down DC/DC regulator with an
    ! }" N4 ^6 ~4 s) Uinternal switch, featuring SKIP control mode, which
    / j1 _* d: s+ h1 Y& z7 icombines low quiescent current with high switching1 J) o% C2 }5 Y' y
    frequency to achieve high-efficiency regulation over a
    2 @2 L9 \  \5 f& H0 ^7 mwide range of load currents. SKIP mode uses a short4 E2 i, F  D: }' T
    "burst" cycle to switch the inductor current through" Z/ f" j6 X2 M5 e
    the internal power MOSFET, followed by a sleep
    9 t2 V$ w: ~2 h/ Hcycle in which the power switch is turned off and the0 I# L- L2 c& ]  e& ]
    load current is provided by the output capacitor. At$ P$ ]; t' T9 l2 {  t8 x: U
    light loads, burst cycles are a small fraction of the
    - ~. K0 g5 i% T) Vtotal cycle time, minimizing average supply current- q$ P2 N. ]5 m5 }5 Y
    and greatly improving efficiency at light loads.
    - J: s% T  E7 i# qZCC5160 has a wide input voltage range of 4V-60V,/ n) [& u- G9 R* d" G# w
    thus minimizing the need for external surge$ d% \  Z% K0 C7 q
    suppression components. Making it the best choice9 e9 ?- }& x) q
    for wide input power range industrial and high cell6 c6 O' p( m" h+ _7 Y& a/ @9 a6 t
    count battery pack applications. ZCC5160 is ideal for
    # J' [5 c1 Y' X6 n. g' k: v" ^use in the 48V automotive power bus range.! p3 g. R$ e! u# X, j
    ZCC5160 features low-value 100mΩ high-side and  ^9 F  l. C: U  v
    80mΩ low-side MOSFET that provide at least 3A& [* d7 d- c6 v7 r
    output current capability with excellent load and line! P( ]) L; U. A% m. b5 W( @
    transient response.
    " o1 s: @; b# ~& _Additional features include: soft-start, thermal! f* U; M3 b! I8 H8 t5 I
    shutdown, UVLO undervoltage lockout, gate driver# d! z+ P- u' E& j" Y( {
    undervoltage lockout, maximum duty cycle limit timer,; s0 y: U* E/ ^
    and current limit shutdown timer. It also integrates, b8 M% N! N3 h- h* o8 t1 f$ A+ [/ A
    output short-circuit protection, providing HICCUP( h+ V: Q- ]% ^2 h# s( o6 r$ @
    mode when the FB voltage is low to avoid
    / ]' D* D: B, s9 \& t8 Y$ Noverheating during short-circuit.- i1 U* O' a. |( ?- A; B$ J& i5 T7 C; |
    发表于 2022-9-22 20:31 | 只看该作者
    多多分享实际的例子、有实际用处的。
    GMT+8, 2025-5-31 19:19 , Processed in 0.062500 second(s), 23 queries , Gzip On.
