SYM_NAME | COMP_DEVICE_TYPE | REFDES |
BAT600 | BATTERY_1_BAT600_BATTERY | BAT1 |
C0603 | CAP NP_C0603_100PF | C7 |
C0603 | CAP NP_C0603_104 | C29;C30;C139;C141;C142;C145;C146;C150;C155;C156;C157;C158;C160;
0 a. i5 t7 F! i3 _& ZC161;C163;C165;C169;C170;C173;C174;C181;C186;C188;C196;C225;C227;
, c; \8 P1 n# d eC235;C237;C238;C244;C245;C246;C247;C352;C362;C443;C445 |
C0603 | C_C0603_100NF | C63 |
C0603 | CAP NP_C0603_33PF | C75;C76;C77;C78 |
C0603 | C_C0603_104_1104.00100 | C135 |
C0603 | CAP NP_C0603_100P | C137;C243;C349;C350;C353;C354;C355;C356 |
C0603 | CAP NP_C0603_20P | C147;C149 |
C0603 | CAP NP_C0603_100N | C148;C152;C167;C168;C175;C176;C177;C178;C183;C184;C191;C192;C197;, P _7 Q% c% Z0 E& j
C200;C201;C202;C203 |
C0603 | CAP NP_C0603_4.7U | C162;C164;C166 |
C0603 | CAP NP_0_C0603_104 | C182;C185;C190;C193;C194 |
C0603 | 18PF-50V-5%-NPO-0402_C0603_15P | C332;C333 |
C0603 | CAP NP_0_C0603_1U | C334;C377 |
C0603 | 0.1UF-10V-10%-X5R-0402_C0603_10 | C339;C368;C369;C370;C371;C372;C373;C374;C378;C390;C391;C394;C395;C397;C398 |
C0603 | CAP NP_C0603_1U | C357;C358;C359;C360;C361 |
C0603 | CAP NP_C0603_47P/NC | C410 |
C0603 | R_C0603_2.7K,1% | R93 |
C0805 | CAP NP_C0805_10UF | C143;C144;C153;C171;C172;C179;C180;C195;C204;C205;C206;C207;C208;C209;
- E4 z# w n3 RC240;C241;C242;C248 |
C0805 | CAP NP_C0805_10U | C151;C154;C159;C187;C189;C228;C229;C230;C231;C234;C236;C239;C351;C375;C376 |
C0805 | CAP POL_C0805_10UF | C446;C447 |
C0805 | CAP POL_C0805_10U | C448;C449 |
C1206 | CAP NP_C1206_22U | C253;C254;C255;C256;C257;C258 |
C3528 | CAP_C3528_47UF | C79 |
CAP-D10L16-DIP-2 | CAP_CAP-D10L16-DIP-2_1000UF/16V | C8 |
CON4-B | CON4_CON4-B_CON4 | CON13 |
CON-FPC-P05-40P | LCD-888_4_CON-FPC-P05-40P_LCD-8 | LCD3 |
CON-FPC-P05-45P | LCD-888_1_CON-FPC-P05-45P_LCD-8 | LCD1 |
D1206 | DIODE_D1206_IN4148 | D1 |
D1206 | DIODE_1_D1206_1N4148 | D2 |
DB9RA_M | CONNECTOR DB9_2_DB9RA_M_CONNECT | COM0;COM3 |
DC023B | JACK/3PIN_4_DC023B_JACK | CN1 |
DFN10-19P7X111-2TH | MMA7660FC_DFN10-19P7X111-2TH_MM | U7 |
DO-214AA-SMB | DIODE ZENER1_8_DO-214AA-SMB_6.3 | D6 |
DP3-5 | CON3_DP3-5_CON3 | CON11 |
EARJACK5 | PHONEJACK STEREO SW_EARJACK5_PH | MIC2 |
EARJACK5 | AUDIO_1_EARJACK5_AUDIO_3F37-4 | SPK1 |
F3528 | R_F3528_FUSE 2A | F1 |
H1 | CON1_H1_CON1 | H1;H2;H3;H4;H5;H6;H7;H8;H9;H10;H11;H12;H13;H14;H15;H16;H17 |
HD2X5BOX_100 | IDC10_HD2X5BOX_100_IDC10_2007.3 | CON5 |
HDMI0119-20-RM-A | HDMI_0_HDMI0119-20-RM-A_HDMI | CON8 |
HR911105A | HR911103A_5_HR911105A_HR911105A | J3 |
IDC20S | J2X10_IDC20S_J2X10 | CON10 |
IDC44S2 | CON40A_0_IDC44S2_CON44A | LCD4 |
KEY-A06 | KEY2PIN_0_KEY-A06_RESET | K1;K2;K3;K4;RESET |
LED | LED_LED_GREEN LED | D4 |
LED0805 | LED_LED0805_LED | LED6 |
MIC2 | MIC_MIC2_MIC | MIC1 |
MICROUSB_ANT | MINIUSB_0_MICROUSB_ANT_MICROUSB | MICROUSB1 |
MINI_PCIEX1-52P-4H | CON50A_5_MINI_PCIEX1-52P-4H_MF2 | CON9 |
OSC2PR-1 | CRYSTAL_OSC2PR-1_25MHZ | Y1 |
OSC2PR-1 | CRYSTAL_OSC2PR-1_24MHZ | Y2 |
OSC2PR-1 | CRYSTAL_OSC2PR-1_12MHZ | Y3 |
PADC15 | TP_PADC15_TP | PERST_N |
QFN32-19P7-2TH | WM8960GEFL_0_QFN32-19P7-2TH_WM8 | U50 |
QFN48-19P7-TH | USB4640_QFN48_2_QFN48-19P7-TH_U | U35 |
QFN48-19P7-TH | DM9621_1_QFN48-19P7-TH_DM9621 | U66 |
R0603 | FB_R0603_0R | FB1;FB2;FB3 |
R0603 | R_R0603_10K/NC | R2;R23;R203;R211;R236;R242;R399;R400;R433;R434 |
R0603 | R_R0603_100K | R3;R27;R100;R110;R275 |
R0603 | R_R0603_0R | R4;R5;R13;R24;R106;R107;R108;R113;R115;R128;R173;R197;R244;R276;R277;
. q" Z2 N: q, V% |% D0 g0 o! WR278;R279;R281;R284;R285;R286;R302;R303;R343;R344;R350;R389;R390;R401;( a8 a O# N6 O) O8 n: u* ]
R402;R407;R418;R419;R420;R421;R422;R423;R424;R425 |
R0603 | RESISTOR_R0603_NC | R6;R90;R91;R92 |
R0603 | R_R0603_10K | R7;R11;R75;R101;R103;R105;R142;R143;R146;R147;R148;R149;R150;R151;R152;
* i0 N: _ e9 O( u* ZR153;R154;R155;R156;R157;R158;R159;R160;R161;R162;R163;R164;R165;R166;
# E$ O0 s7 j; V+ PR167;R168;R169;R170;R171;R172;R174;R175;R176;R177;R178;R179;R180;R181;
( X8 v- n2 m3 FR183;R185;R190;R191;R194;R195;R198;R204;R212;R218;R219;R220;R221;R223;0 L s# J/ l/ e* g" M% b- y
R237;R243;R397;R398;R403;R426;R427;R428;R429;R430;R431;R432 |
R0603 | RESISTOR_R0603_10K | R8;R86 |
R0603 | RESISTOR_R0603_4.7K | R9 |
R0603 | RESISTOR_R0603_1M | R10 |
R0603 | R_R0603_120R/NC | R28 |
R0603 | R_R0603_10R | R30;R35 |
R0603 | R_R0603_4.7K | R31;R32;R144;R145;R196;R200;R202;R205;R206;R207;R208;R209;R210;R213;* y8 o$ y5 E8 a! J4 a7 d
R214;R216;R217;R224;R226;R228;R229;R230;R231;R232;R233;R234;R235;R238;
( q) ~* g+ E+ A- q6 `* RR239;R240;R241 |
R0603 | R_R0603_1K | R33;R188;R215;R222 |
R0603 | R_R0603_2K | R34;R186;R415 |
R0603 | R_R0603_1K_1004.00017 | R48;R49;R50 |
R0603 | R_R0603_200R | R76 |
R0603 | R_R0603_10K_1004.00009 | R77;R78 |
R0603 | RESISTOR_R0603_51K | R83;R84;R85;R87;R88;R89 |
R0603 | R_R0603_22R | R95;R184;R187;R417 |
R0603 | R_R0603_NC | R99;R104 |
R0603 | R_R0603_20K | R102 |
R0603 | R_R0603_0R/NC | R109;R111;R124;R125;R126;R134;R245;R341;R342;R345;R346;R347;R348;R391;6 U6 v& b! Y( E& Z3 C
R392;R393;R394;R395;R396 |
R0603 | R_0_R0603_49.9R,1% | R127;R129;R132;R133 |
R0603 | R_0_R0603_330R | R130;R131 |
R0603 | R_0_R0603_0R | R137 |
R0603 | R_R0603_47K/NC | R416 |
R0603 | 1.0MEG-1/16W-5%-0603_R0603_1M | R463 |
R0603 | 100K-1/16W-5%-0603_R0603_100K/N | R464 |
R0603 | 100K-1/16W-5%-0603_R0603_100K | R465;R466 |
R0603 | 12.0K-1/16W-1%-0603_R0603_12K,1 | R467 |
R0603 | 10K-1/16W-5%-0603_R0603_10K | R468 |
R0603 | 100K-1/16W-5%-0603_R0603_0R | R469;R487 |
R0603 | 10K-1/16W-5%-0603_R0603_0R | R477 |
R0603 | 100K-1/16W-5%-0603_R0603_47K | R478 |
R0603 | 100K-1/16W-5%-0603_R0603_10K/NC | R479 |
R0603 | 100K-1/16W-5%-0603_R0603_75K | R480 |
R0603 | 100K-1/16W-5%-0603_R0603_12K,1% | R481 |
R0603 | 100K-1/16W-5%-0603_R0603_10K | R482;R483;R484;R485;R488;R489;R490 |
R0603 | 100K-1/16W-5%-0603_R0603_6.98K | R486 |
R1206 | FB_R1206_0R | FB4 |
RN-8P4R-31P5X062A | R_PAK4_RN-8P4R-31P5X062A_0R_? | RN16;RN56;RN57;RN58;RN59;RN60 |
SDCARD | SD_0_SDCARD_SD/MMC CARD | CON12 |
SIM-0011 | SIMCARD_0_SIM-0011_SIMCARD | P1 |
SIP4-FA | CON4_3_SIP4-FA_CON4 | CON7 |
SIP6-FA2 | J1X6_2.0PH_SIP6-FA2_J1X6_2.0PH | CON1;CON2;CON3;CON4 |
SIP30S | CON20A_0_SIP30S_CON20A | CON15 |
SKD_C0603 | CAP NP_SKD_C0603_100N | C98;C99;C100;C101;C102;C103;C104;C105;C106;C107 |
SKD_R0603 | R_SKD_R0603_10/NC | R135;R138 |
SKD_R0603 | R_SKD_R0603_10K | R136;R139;R141 |
SKD_R0603 | R_SKD_R0603_10K/NC | R140 |
SOD-323-12 | DTVS_DUAL_CA_KKJ_1_SOD-323-12_T | DN2;DN3;DN4 |
SOIC16-50X204 | MAX232SOP_SOIC16-50X204_MAX3232 | U14 |
SOP8 | SP3485_SOP8_SP3485 | U3 |
SOP8 | AT24C04N_SOP8_AT24C04/08_1407.0 | U13 |
SOT23-5 | XC6209_SOT23-5_XC6209-1.2V | U30 |
SOT23-6 | RT9011-MGPJ6_SOT23-6_RT9011-MGP | U16 |
SOT-23-Q | NPN-BEC_SOT-23-Q_MMBT3904AL | Q1;Q3 |
SPEAKER | BEEP-2_SPEAKER_TMB-12-A05 | BP1 |
SW35 | CON5_0_SW35_S300 | S1;S2 |
TINYPRO | TINY210PRO_TINYPRO_TINY210PRO | TINY4412 |
TO-252 | AMS1117_TO-252_AMS1086CM-3.3 | U17 |
TO-252 | LM1117-33_1_TO-252_AMS1086-1.8 | U18 |
TO-252 | LM1117-33_1_TO-252_AMS1086-3.3 | U67 |
TPC1 | T POINT R_TPC1_CLKOUT | TP3 |
TPC1 | T POINT R_TPC1_INT_1.2V | TP27;V_1.2 |
TPC1 | T POINT_TPC1_TP | TP44 |
TPC1 | T POINT R_TPC1_DEBUG_14 | TP69 |
TPC1 | T POINT R_TPC1_DEBUG_15 | TP70 |
TPC1 | TP_TPC1_TP | TP71;TP72 |
TQFP100-19P7 | ALTERA_EPM240T100 | U73 |
TSSOP14-25P6X228 | CON14A_0_TSSOP14-25P6X228_NTS01 | U71;U72;U74;U75 |
TSSOP20-25P6X228 | TXB0108_TSSOP20-25P6X228_TXS010 | U68;U69;U70 |
TSSOP28-25P6X228 | CON28C_1_TSSOP28-25P6X228_FE1.1 | U52 |
TSSOP48-19P7X295 | SN74LVC16T245_TSSOP48-19P7X295_ | U38 |
USB-A2 | USBPORT_0_USB-A2_USB A | USBH1;USBH2;USBH3 |
VR3_7X7 | RP_0_VR3_7X7_10K | W1 |
