<span]APPLICATIONS
Profi WiFi hotspot coverage
Commercial radio coverage
Hotel Wireless application
Country coverage
Internet for passengers (bus, train, plane, …)
Security Surveillance
Some special scene application
Heavy-duty industrial environment use Qualcomm-Atheros IPQ6010 Quad-core ARM 64bit A53 @1.8GHz Processor 1GB DDRL3L System Memory 32MB NOR Flash, 256MB NAND Flash Supports Dynamic Frequency Selection (DFS) 2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate 2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate Support: QUECTEL RM500Q-GL Support: QCN9074 WiFi 6E Card
Parameter
| Rating | Unit | Supply Voltage
| 24V~48 | V | Operating Temperature Range
| -40 to +70 | oC | Storage Temperature Range
| -45 to +105 | oC | Operating Humidity Range
| 5 to +95 (non-condensing) | % |
Symbol
| Parameter | CPU
| CPU Frequency
| Quad-core ARM 64 bit A53 @1.8 GHz processor
| System Memory
| 1GB (2x 512MB) DDR3L 16-bit inteRFace with 32-bit memory bus design
| Ethernet Port
| 1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
| | SFP Port | 1x SFP port | NGFF Slot
| M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
| SD Card Slot
| 1x SD Card Slot
| USB /header
| 1x USB 2.0 Port
| POE
| 24V~48V passive POE/Active POE(Suport 802.3bt)
| DC Jack
| 24V power supply
| LED header
| FFC/FPC Connector
| Serial Port
| 1x Serial Port 4 Pin Connector
| Wireless
| On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
| | Bluetooth | CSR8811 BLE 4.2 | Nor Flash
| 32MB
| Nand Flash
| 256MB
| DDR
| 256MB~512MB
| Dimension
| 185mm x 116mm
We'll start with a quick review of how Wi-Fi has changed over the years. In fact, the earliest generation of 802.11 standard can be traced back to 1997, when the wireless speed is very low, only 2Mbps, it is an original standard of the first generation . With the introduction of 802.11b in 1999, the physical layer speed was increased to 11Mbps and there were very few commercial applications. At that time, Wi-Fi was still far away from people's lives In 2003, the third generation of the standard, 802.11a/ g. Laptop began to configure wireless network card and home wireless router appeared in large quantity . Wi-fi comes into ordinary family. EMAIL:sales@wallystech.com WEB:https://www.wallystech.com/ Youtube:https://www.youtube.com/channel/UClmu7LBz_OWxe2VckkQr3tw
