今天用orcad画好原理图后,导出pads_LAYOUT 网表文件ASC. 用LAYOUT导入网表文件后保存为:1.PCB
5 i* z( Z. [* t8 I U; m$ H# }0 `2 f4 Y3 S# }0 i8 ?
然后再用LOGIC 导入画好的DSN文件. 点ECO TO PCB同步到现理图上,这时再把PCB文件另存为: 2.PCB
% ]$ [9 j# E9 E. ~1 J4 C
2 _4 r: x8 A+ L- s+ M/ u对比两个PCB文件Compare/ECO
( k5 E- i) z; p. o2 k
, ?1 D9 z# f& `! n*PADS-ECO-V9.1-METRIC*
5 k- h9 |5 O3 b2 V O0 ]5 `*REMARK* old file: C:\PADS Projects\ecogtmp0.asc
4 D R- F9 Y& `8 d1 h2 {*REMARK* new file: C:\PADS Projects\ecogtmp1.asc3 Z: H3 G \7 @6 g& h% a
*REMARK* created by ECOGEN (Version 6.4v) on 2011-12-27 15:40:31
7 i$ f$ Y7 Q$ P! {% }' |1 j" W5 V8 G6 a7 Y- i
PART DIFFERENCES7 F3 Q( c' Z; X+ o2 c. v+ w- s
----------------7 z) A H9 I* j* }
OLD DESIGN NEW DESIGN
A+ i6 L" r5 H/ K2 U' C% xRef-des Part-type ecal Ref-des Part-type ecal& l3 ]9 q" O1 k: M' D0 ?
3 s! c; I, i( P2 _' m/ n; uNET DIFFERENCES
3 V" F+ j/ p! X8 _ {. q----------------) u7 q q% ^1 y
4 u5 K( l) C8 I! TAB0_DDR3 AB0_DDR27 ?& ^/ e+ H; e7 _( G( v# Y
AB10_DDR3 AB10_DDR2
, t! H( R6 e' D- m9 {* ZAB11_DDR3 AB11_DDR2& }, t$ H5 d% |( r
AB12_DDR3 AB12_DDR2
1 }2 I+ V$ y" o8 f, I5 ?AB1_DDR3 AB1_DDR23 ?) {. Z1 r9 r. e: z
AB2_DDR3 AB2_DDR2" F! x( e- R: Q8 Y& [
AB3_DDR3 AB3_DDR2
6 i$ L5 q" _$ Q( F' E2 x/ L& xAB4_DDR3 AB4_DDR2
) B3 a" s I1 e3 s3 V# AAB5_DDR3 AB5_DDR2
9 l3 o. u# o6 jAB6_DDR3 AB6_DDR2
+ U5 L! c. e! ~3 {0 RAB7_DDR3 AB7_DDR2
) w1 @$ ^: w; w: T( l* ^AB8_DDR3 AB8_DDR2
$ ]( K3 j2 e8 G7 `AB9_DDR3 AB9_DDR2( H/ R2 \- F% {$ a2 q0 v( Z
3 {" ]* b1 G, ?1 y, C: x
SWAPPED GATE DIFFERENCES* O; C5 V% _! Z* c) A0 P
8 j# Z5 c" d* T7 \OLD DESIGN NEW DESIGN
( |7 o1 t6 l8 b/ T
) M, Y' ~9 C! p' QSWAPPED PIN DIFFERENCES( u1 J! Z7 ^1 o6 h
------------------------9 X9 Q7 @ o, g+ @
OLD DESIGN NEW DESIGN" J J) C: `/ t3 \( a, `! r& r
' E/ [/ F X2 t' D
; b/ ^7 K9 a" d) l
UNMATCHED NET PINS IN OLD DESIGN
+ f* }4 M# U' \/ e, H% S5 M$ w--------------------------------$ s5 N% u+ I) q' m8 ~8 O: u5 D
) A1 ?& ^" u+ K& O5 U uUNMATCHED NET PINS IN NEW DESIGN9 d4 {/ P; C, _! U2 I
; L3 @+ @. `: V$ G6 c/ aAB0_DDR2 RN1.1 9 b+ W, w q+ E5 P
AB10_DDR2 RN3.3
8 Q$ ?% s6 b$ rAB11_DDR2 RN3.4
" t) k; y' U, }AB12_DDR2 R16.1 * M4 y0 k! j2 G) n
AB1_DDR2 RN1.2 / ]; k6 S, }8 k7 w9 }
AB2_DDR2 RN1.3 5 V! a* s) W! z' Y% q& Y6 a5 Y
AB3_DDR2 RN1.4
# G5 e5 B& E6 t% o+ e0 IAB4_DDR2 RN2.1 0 P" r4 o6 R" o: [5 p
AB5_DDR2 RN2.2 a% W: @% v& _: Z! b2 |1 ^$ D# D" k
AB6_DDR2 RN2.3 " s* W; W7 y2 o3 N
AB7_DDR2 RN2.4 % U0 t4 x) F* p! w# z* G
AB8_DDR2 RN3.1 4 E) H- ], E5 ]! O! w: u V
AB9_DDR2 RN3.2 3 h5 O- q3 n0 C# ^/ w4 R
* |3 D) Y4 y& G7 h+ L. {$ vATTRIBUTE DIFFERENCES
+ Z7 @1 P) H- A0 o---------------------( B( B- w9 P6 y" @" e; H# c! A
Attribute Level [ OLD DESIGN Parent -> NEW DESIGN Parent ]( j( p$ j/ C9 Y. J l
- B8 \7 X r) O Attribute Name Old Value New Value/ l& S7 i5 e# f* t$ L7 |
$ W0 g% }+ ?: U
1 C7 C6 W, U9 p% u" s c/ _4 r/ b g! S% L- X b& i. y
注意到没有, PCB网络以发生变化,# X, H+ s7 J' o6 L+ F$ q
3 G- [( v$ j2 B" h9 K
由于pads logic不允许同一网络有多个网络名,而orcad caprute cis 允许同一网络有多个别名,故pads logci在打开dsn文件时对其网络名的识别会有问题。他会将 同一张sheet中 连接在一起的多个网络别名只用其中一种来表示,其余别名全部丢失。如果其他sheet页中还有该网络,那一页的网络名将是这些网络别名中的另一个。而在由dsn打开的logic文件中,这些幸存的网络别名间竟不是同一个网络(因为人家是以 名称 识别的),与layout对应时所有网络别名中也只有1个可以与layout中的网络名对应,其余全部丢失。不过由于是从orcad直接生成网表画出pcb,这些网络别名在pcb上实际是连在一起的,即pcb不会有问题。
, s+ ]- D6 D8 D( [. V" Q5 o知道这些后,可以放心,orcad + pads layout不会出问题。pads logic最多只能用来参考,logic 与layout相映射方便大部分对应查阅功能,但不能百分百信赖之。比如上面的多网络别名的情况。
/ V$ F% ?7 J. F( L
- E7 W/ ^. k- F6 J. l) ^+ R3 a: t8 h1 s: g0 D% ?8 Q! d; ?
" Q$ F9 p3 a' H+ D; q2 C
想用LOGIC同步PCB的朋友使用该功能要注意了哦, 最好同步前将文件跟之前ORCAD网表文件对比下.确认设计的完整性.) f& A! |, A: m' ?2 ?$ }% w
( K f2 x* Z7 V4 g" r- K |
