本来两个单独的工程,一个核心板一个底板,生成网表都没有问题,也能正常导入PCB,但是把两个工程的原理图合并到一个工程里面,想做成一块板,生成网表出错 如下 请帮忙分析是什么原因,谢谢0 Y9 d# t& A C6 \2 h/ M
* o7 ]- g S3 |% s( ]: ^. {# ]
#205 Warning [ALG0040] Value of Property "Device" missing from instance RN8: HI3511DMEB, P02 DDR2 (271.78, 15.24).0 q4 D, K1 K1 J6 g1 ~$ @
#206 Warning [ALG0040] Value of Property "Device" missing from instance RN9: HI3511DMEB, P02 DDR2 (127.00, 25.40).
3 B; H0 v6 ?( Q3 k# S Z% K#207 Warning [ALG0016] Part Name "LTC3780EG_SOP24-26-208_VOLT. REG." is renamed to "LTC3780EG_SOP24-26-208_VOLT. RE".
. v. \: }. v) z& J% ^/ u#208 Warning [ALG0040] Value of Property "Device" missing from instance U22: HI3511DMEB, P02 DDR2 (172.72, 15.24).
2 v( S9 `* k- v7 e#209 Warning [ALG0016] Part Name "HI3511_6_BGA441-32-2323_HI3511_DDR2_" is renamed to "HI3511_6_BGA441-32-2323_HI3511_".8 ~. m" H3 R/ ?
#210 Warning [ALG0040] Value of Property "Device" missing from instance U24: HI3511DMEB, P01 POWER&GND (273.05, 340.36). W4 s" \# H! b5 R/ T
#211 Warning [ALG0040] Value of Property "Device" missing from instance U25: HI3511DMEB, P02 DDR2 (132.08, 157.48).0 N- H9 [! A; s6 M* I( Q& b
#212 Warning [ALG0016] Part Name "K4T1G164QA-ZCE6000_0_BGA84-32-1509E_K4T1G164QA-ZCE6000" is renamed to "K4T1G164QA-ZCE6000_0_BGA84-32-1".
/ G$ i) P4 `3 P/ a- `9 G6 X#213 Warning [ALG0040
$ z+ T% u8 i8 f% p" _] Value of Property "Device" missing from instance U26: HI3511DMEB, P02 DDR2 (452.12, 165.10).
8 o3 F6 E6 E& I#214 Warning [ALG0016] Part Name "K4T1G164QA-ZCE6000_0_BGA84-32-1509E_HY5PS1G1631CLFP_Y5" is renamed to "K4T1G164QA-ZCE6000_0_BGA84-32_1".4 |9 I$ X$ u3 i5 S
#215 Warning [ALG0040] Value of Property "Device" missing from instance U28: HI3511DMEB, P05 BOOT FLASH (266.70, 55.88).
h" y" E$ q0 j* Y/ |! j#216 Warning [ALG0016] Part Name "AM29LV256MH123RE_0_SOP56-20-720_AM29LV256MH123RE" is renamed to "AM29LV256MH123RE_0_SOP56-20-720"." L# d# Z2 d2 R
#217 Warning [ALG0040] Value of Property "Device" missing from instance U29: HI3511DMEB, P05 BOOT FLASH (45.72, 190.50).
* E0 R. ~. r- h) K4 f7 Q#218 Warning [ALG0016] Part Name "AT88SC0104C_SOP8-50-157_AT88SC0104C" is renamed to "AT88SC0104C_SOP8-50-157_AT88SC0".# x# L& j: Z% d& w$ g+ K
#219 Warning [ALG0016] Part Name "ISL1208IB8-TK_0_SOP8-50-157_S-35390A" is renamed to "ISL1208IB8-TK_0_SOP8-50-157_S-3".* X; R# A, Q, h. X
#220 Warning [ALG0016] Part Name "SII3114_MISC_QFP128-040-1414LH_SII3512" is renamed to "SII3114_MISC_QFP128-040-1414LH_".
9 h: h, B: O7 p7 R m9 W#221 Warning [ALG0040] Value of Property "D
: @& F4 ]7 \% ~5 k' `' Tevice" missing from instance X6: HI3511DMEB, P03 JTAG&CLK&RST (1.90, 2.10).
- `( k1 p o2 f9 d! q& ~( P#222 Warning [ALG0040] Value of Property "Device" missing from instance X7: HI3511DMEB, P03 JTAG&CLK&RST (1.90, 3.10).
+ V# J2 A/ _, K& `2 K) w- f2 ?- YScanning netlist files ...4 d6 T& F4 Q) I
Loading... F:\KEHUZILIAO\MDVR_MBOARD_V2_0\SC\allegro/pstchip.dat x$ X5 D5 W( f
Loading... F:\KEHUZILIAO\MDVR_MBOARD_V2_0\SC\ALLEGRO/pstchip.dat9 I5 X$ v* y2 F/ `2 c
Loading... F:\KEHUZILIAO\MDVR_MBOARD_V2_0\SC\ALLEGRO/pstxprt.dat3 ~3 o+ q- Z+ L+ c" _) P. |
Loading... F:\KEHUZILIAO\MDVR_MBOARD_V2_0\SC\ALLEGRO/pstxnet.dat
- Q& o' c# \2 OError: Line 3254 in file F:\KEHUZILIAO\MDVR_MBOARD_V2_0\SC\ALLEGRO/pstxnet.dat:
) u( U. U. m# q Could not create new pin inst <logicalPinName> ! r Z( Z' k0 A
Detected in function: pstReadNodeSec 7 M. \2 T. C6 c- L; W9 J
- d/ e* g: {4 W5 Y0 a Error loading the net list file
7 B' d7 @8 i9 Z& S1 u2 [6 N Detected in function: ddbLoadPstXFiles
' a- Y3 V0 n+ ^* |#223 Error [ALG0036] Unable to read logical netlist data.
. _7 a& F- j2 D0 R/ b
# {; a$ t) l' `7 Z& |8 O$ @Exiting... "D:\cadence\SPB_15.5\tools\capture\pstswp.exe" -pst -d "f:\kehuziliao\mdvr_mboard_v2_0\sc\mdvr_mboard_v1_0_1129.dsn" -n "F:\KEHUZILIAO\MDVR_MBOARD_V2_0\SC\ALLEGRO" -c "D:\Cadence\SPB_15.5\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
) \; p6 f/ S$ |8 `# U9 C7 l: g0 [5 l; `$ k7 b7 G! ?
