[allegro16.3][2层]NFC读卡器(CHIP_AU9541)pcb文件
; A: I5 _- U' [1 |文件描述:6 R( Z. |; ~6 U; @5 N
1. 作品用途:NFC读卡器 2. 软件版本:allegro16.3 3. 层数:2层 4. 用到的主要芯片: CHIP_AU9541 5. PCB尺寸:42.6*57.3mm
! I2 q2 N# j. a7 N
" @3 g9 P; \9 T; F/ J作品截图如下:6 M n T6 q) F* [; @& E" {2 G
, I# M7 u f# z8 P: N
顶层截图:7 x" R# V' r' b8 w% ?
9 {' X6 |3 a2 k* q& h2 b1 o) ]% l+ D( t* y9 W7 Y
/ z. u/ }; }% Q3 @ E底层截图:
$ r+ C6 x( t) t+ Q1 K: S( L* N) q; d8 R# r' A; X) s3 h- e7 l9 y% V
& s8 l# Y6 N! y" z' `& A0 }$ c- F0 l1 R, V2 M0 R8 K
全部截图:3 C; n. U. n: t$ r( D
2 u( Y; S7 t* f0 D
- b; i/ |6 j0 s0 ^: h ~4 D) K; o/ V: j/ u0 U3 R, N
PCB文件:
' }1 [, ^2 X/ _. `4 _6 Q+ ]+ v7 z) f8 q4 O' I- W
# r) r2 P5 r3 t/ ^4 q
7 J$ K/ w. l7 x# Z( q' PBOM:8 W+ k7 s- N; l+ b3 Q
3 A. A' n2 F; W9 | PSYM_NAME | COMP_VALUE | REFDES | AIC1896 | AIC1896 | U12 | CHIP_AU9541 | AU9541-28 | U2 | CHIP_HS32U2_E48 | HS32U2-E48 | U11 | CHIP_LDO_SOT23-5 | LD0-SOT-23-5 | U8 | CHIP_RC531 | SHC1509 | U4 | CHIP_SOP8-ALL | W25X20 | U7 | C_0402 | 0.033UF | C7 | C_0402 | 0.1UF | C8;C9;C10;C11;C12;C13;C14;C15;C16;C17;C18;C19 | C_0402 | 18PF | C31;C32 | C_0402 | 10P | C36;C37 | C_0402 | 1UF | C42;C43;C44 | C_0402 | NC | C51;C54 | C_0603 | 4.7UF | C3;C4;C5;C6 | C_0603 | 0.1UF | C20;C21;C22 | C_0603 | 122PF | C25;C26 | C_0603 | 15PF | C27;C28 | C_0603 | 160PF | C29;C30 | C_0603 | 15PF | C33;C34 | C_0603 | 1NF | C35 | C_0603 | 0.1UF | C47 | C_0603 | 100PF | C48;C49;C50 | FPCR26-TOP-1 | FPCR26 | J10 | IC_CARD | 7816-CPUCard | U3 | JP9 | SIP9-TF | J20 | L_0805 | 1uH/0.6A | L2;L3;L5;L6 | L_0805 | 10uH | L4 | OSC_3_2X2_5 | 12MHz | X1;X2;X3 | R_0402 | 0R | R1;R2;R3;R4;R5;R6;R73 | R_0402 | 1K | R7;R8 | R_0402 | 1M | R9;R10 | R_0402 | 330R | R11;R12;R13;R14 | R_0402 | 10K 1% | R16;R17 | R_0402 | 10K 1% | R18;R19 | R_0402 | 4.7K | R24;R25;R32;R33;R34 | R_0402 | 470R | R65 | R_0402 | 8.6K | R70 | R_0603 | 1R | R20;R21 | R_0603 | 2.7K | R22 | R_0603 | 2K | R23 | R_0603 | 910K | R66 | SIP3-2 | CON3 | J18 | SOD-323 | diode | D5;D7 | SPK | Buzzer | J9 | SYM_D_MICROUSB | MICROUSB | U9 | SYM_SMD_LED0805 | LED | D1;D2;D3;D4 | TP0_8MCIR | CLKOUT | INT0 | TP0_8MCIR | rst | INT1;ISSP_CLK;ISSP_SDA;RST;VCC5V | TP_1 | TP_SMD | TP1;TP2;TP4 | TP_2 | TP_SMD | TP3 |
0 ~8 T# P( m3 s. Y" u; C
4 m9 F. ?: j8 ^8 z/ p4 E8 M( e y! g, x2 `
* z9 A% L9 m# Q9 Z |
