查看: 888|回复: 2
【源码】Allegro导出元件高度list
发表于 2022-8-24 19:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
allegro导出元件高度list。生成excel,09年写的17.4还能用,不错
快捷命令:CHExport
  1. ; =============================================================
  2. ;                      Comp_height_export.il  v.1
  3. ;                        Create by XD
  4. ;                         2009-10-21
  5. ;=============================================================
  6. ;Declare: display all placed component height!
  7. (defun Comp_height_export ()
  8.         symbol_db_list= axlDBGetDesign()->symbols
  9.
  10.         comp_num= length(axlDBGetDesign()->components)
  11.
  12.         axlClearSelSet()
  13.         _Comp_Height_Report = outfile("./Comp_height_report.csv" "w")
  14.
  15.         fprintf(_Comp_Height_Report ",,Comp_height_report V1.0\n\n")
  16.
  17.         fprintf(_Comp_Height_Report "======================================================================\n")
  18.
  19.         fprintf(_Comp_Height_Report "* BoardFile Name:  %s               Allegro Version: %s\n" axlCurrentDesign() axlVersion('fullVersion))
  20.
  21.         fprintf(_Comp_Height_Report "* Time:  %s\n" getCurrentTime())
  22.
  23.         fprintf(_Comp_Height_Report "* The Number of Component: %d\n" comp_num)
  24.         fprintf(_Comp_Height_Report "* Remark:  Please make sure that all components have been placed on the main board!\n")
  25.         fprintf(_Comp_Height_Report "======================================================================\n")
  26.         fprintf(_Comp_Height_Report "Refdes,Footprint,Height_Max,Layer\n")
  27.                 setof(symbol_db symbol_db_list
  28.
  29.                         refdes = symbol_db->refdes
  30.
  31.                         if( (refdes!=nil) then
  32.
  33.                                 mir = symbol_db->isMirrored
  34.
  35.                                 if(mir then
  36.
  37.                                         Fl = "Bottom"
  38.
  39.                                 else
  40.
  41.                                         Fl = "Top"
  42.
  43.                                 )
  44.
  45.                                 shapefound=0
  46.
  47.                                 propfound=0
  48.
  49.                                 twoshapes=0
  50.
  51.                                 shape_bot_found=0
  52.
  53.                                 children_db_list = symbol_db->children
  54.
  55.                                 if( neq(children_db_list nil) then                        ; checks if symbol has attached shapes
  56.
  57.                                         setof(children_db children_db_list
  58.
  59.                                         isShape = children_db->objType
  60.
  61.                                         shape_layer = children_db->layer
  62.
  63.                                                 if( equal(isShape "shape") then ; checks if shape is on package geometry/place_bound_top
  64.
  65.                                                         if( equal(shape_layer "PACKAGE GEOMETRY/PLACE_BOUND_TOP") then
  66.
  67.        shapefound=1
  68.
  69.        if( (shape_bot_found==1) then
  70.
  71.        twoshapes=1
  72.
  73.        );end if
  74.
  75.        proplist= axlDBGetProperties(children_db)
  76.
  77.        foreach(prop proplist
  78.
  79.        propS= symbolToString(car(prop))
  80.
  81.        if( (propS=="PACKAGE_HEIGHT_MAX") then
  82.
  83.        fprintf(_Comp_Height_Report "%s,%s,%s,%s\n" refdes symbol_db->name cadr(prop) Fl)
  84.
  85.        propfound=1
  86.        );end if
  87.
  88.        );end foreach
  89.
  90.                                                         ) ; end if package geometry
  91.
  92.                                                         if( equal(shape_layer "PACKAGE GEOMETRY/PLACE_BOUND_BOTTOM") then
  93.
  94.        if((shapefound==1) then
  95.
  96.        twoshapes=1
  97.
  98.        );end if
  99.
  100.        shapefound=1
  101.
  102.        shape_bot_found=1
  103.
  104.        proplist= axlDBGetProperties(children_db)
  105.
  106.        foreach(prop proplist
  107.
  108.        propS= symbolToString(car(prop))
  109.
  110.        if( (propS=="PACKAGE_HEIGHT_MAX") then
  111.
  112.        fprintf(_Comp_Height_Report "%s,%s,%s,%s\n" refdes symbol_db->name cadr(prop) Fl)
  113.
  114.        propfound=1
  115.        );end if
  116.
  117.        );end setof
  118.
  119.                                                         ) ; end of package geometry
  120.
  121.                                                 ) ; end of is shape
  122.
  123.                                         ) ; end of setof
  124.
  125.                                 ) ; end of if children
  126.
  127.
  128.                                 if( (shapefound==0) then
  129.
  130.                                         printf( "%L has no Place bound shape! \n" refdes)
  131.
  132.                                         Entries=1
  133.                                 );end if
  134.
  135.                                 if( (propfound==0) then
  136.
  137.                                         printf("%L has no Place bound height property! \n" refdes)
  138.
  139.                                         Entries=1
  140.
  141.                                 );end if
  142.
  143.                                 if( (twoshapes==1) then
  144.
  145.                                         printf("%L has two Place_bound shapes! May highlight improperly!! \n" refdes)
  146.
  147.                                         Entries=1
  148.
  149.                                 );end if
  150.
  151.                         );end if refdes=nil
  152.
  153.                 ) ; end of foreach symbol_db
  154.         close(_Comp_Height_Report)
  155. axlHttp("Comp_height_report.csv")
  156. )
  157. axlCmdRegister( "CHExport" 'Comp_height_export)
复制代码
显示结果:
SH_Comp_height_export.zip
1.28 KB, 下载次数: 3, 下载积分: 贡献 -30 , 威望 -10
发表于 2022-8-25 09:28 | 只看该作者
看一看,学习学习
 楼主| 发表于 2022-8-25 13:35 | 只看该作者
上传附件怎么取消贡献和威望设置,好尴尬
GMT+8, 2025-10-12 05:51 , Processed in 0.171875 second(s), 27 queries , Gzip On.
